Wheel Dishing
Wheel Dishing
Is it safe to re-dish a wheel 5mm on one side? I have a 130mm wheel that I want to put a spacer on to bring it to 135mm.
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
Yes. Put a drop of oil on each spoke nipple before you begin.
Stuart Black
Stuart Black
Quoted: 4412 Post(s)
Liked 1,566 Times
If you add the 5mm to the NDS side, the rim will need to be moved 2.5mm to the NDS side to recenter the rim over the hub's new centerline (equal distance between locknuts).
This redishing should be quite easy. Tighten the NDS spokes, and loosen the DS spokes if they become overly tight.
The redishing should give you a slightly stronger wheel, with better tension balance between the NDS/DS spokes (assuming your wheel have normal 130mm OLD specs).
This is the wheel in question. VO said it is not safe to do and would void the warranty.
https://velo-orange.com/collections/...ar-wheel-130mm
Quoted: 980 Post(s)
Liked 584 Times
This may be an ignorant question... but wouldn't the 5mm spacer need a reduced extension to engage the dropout slot? If not, it looks like the hub is held in place only by the compression provided by the quick release. I'm having a hard time visualizing this.
Liked 1,566 Times
https://velo-orange.com/collections/...ilver-and-noir
I'm sure most of us assumed you were talking about the threaded axle.
I doubt Velo Orange was talking about that 2.5mm of re-dish being unsafe. It might still void their warranty on the wheel build, but it isn't unsafe.
Really Old Senior Member
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
This page from THEIR website says you simply change the NDS endcap to switch.
And you would dish it 2.5mm.
Simply done by slightly tightening the NDS spokes.
