Adding bosses for rim brakes on dutch bike
Hi!
Recently acquired a used Batavus dutch bike. It has pedal brakes which I'm not used to, and it has a roller brake on the front wheel which does nothing.
I'm going to try tweak it but I suspect the roller brake is worn out completely and I've read that roller brakes just aren't nearly as quick to stop in general. So I wanted to see if I could add rim brakes. The frame is aluminium. I saw a guy on youtube drilling holes and putting rivets for new bosses for a bottle cage. Is this doable for brakes? Am I on the right track here or would you recommend some other option? What are the details I need to look out for when shopping for the rim brakes?
Any good resources on dutch bikes in general would be helpful!
Thank you!
Thank you!
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
Your roller brake is likely out of adjustment or has the wrong ratio cable pull or some similar issue. If it needed service, they have a tendency to be instantaneously grabby & stop the wheel cold. That's not to say it can't be worn out. Just unlikely. Fortunately they are cheap and a lifetime supply of the grease is cheaper.
Adding rim brakes turns the wheel into a wear item. Ultimately wheels are the more expensive repair. Having said that: If the fork crown is heavy gauge material & you can drill a hole...Why not? You'd need to make sure that your prospective calipers will A) Have enough reach to get to the rim & B) Have enough clearance to reach around your tire.
Part of what makes a Dutch bike a Dutch bike is it's utilitarian, low maintenance, weather-proof design. Rim brakes are a departure from that ethos.
Likes For base2:
Quoted: 501 Post(s)
Liked 436 Times
Likes For grumpus:
Quoted: 980 Post(s)
Liked 582 Times
I put roller brakes on my folding commuter bikes with Nexus hubs and put an end to rim replacement. They are not "high performance" brakes, but more than adequate for stopping from sane speeds. And nearly zero maintenance... a shot of grease once a year.
Quoted: 2486 Post(s)
Liked 2,956 Times
Most Dutch bikes have fork crowns that are drilled for mounting fenders. If you don't want to go to the trouble of getting the roller brakes overhauled, you ought to be able to find a front sidepull caliper brake with the correct arm length for the rim that you can bolt through the drilled fork crown.
If the rim doesn't have parallel sides and thus won't work with a rim brake, you should have no trouble finding a suitable front wheel (with an aluminum rim, so that the rim brake will work well). Again, confirm that the brake arm length is right.
Me, I'd go to the oldest bike store in town and talk to an experienced mechanic to make sure everything works out the way you need it to.
Likes For Trakhak:
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
Take it to a shop that knows roller brakes and get it serviced. Beyond that get a bike that has the brakes you want and save this bike for certain stuff or sell it and get the bike you want. Don't modify a Dutch or Dutch style bike it generally isn't worth it monetarily and isn't going to improve by much. They are designed to be low cost utilitarian bikes with cheaper low service parts. They aren't riding like we ride here they ride short distances and to them a bike is generally just utility for small point to point trips for practical purposes. Not to say there aren't cyclists over there but most people it is a utility that they have all done since birth basically. Like we use our feet for walking they use a bike in a sense, not trying to totally push them into a neat corner there is plenty of nuance that I didn't go into.
Likes For veganbikes:
Quoted: 4210 Post(s)
Liked 3,875 Times
My experience with both foot and hand operated roller brakes is that they are very mushy and tend to have the power that a slow riding bike needs Not adequate for my needs but the bikes' owners seemed good with them. I agree that keeping the rollers and their ramps lubed helps their feel. Don't forget about keeping the cables lubed and free moving too. Andy
AndrewRStewart
AndrewRStewart
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
Oh look, the 3 roller brake fans. LOL. Throw the POS boat anchor in the garbage and get a SA XL-FDD dyno drum brake. The fork brace fits both the same.
My first one has 32,000 miles with 8,200 on a 120 lb tour bike. With both drum brakes I can go 39-0 mph in 60 feet. That's faster than the GCN guys did with a disc race bike. LOL. The only service it needs is a cable adjust once a year and maybe a few light scratches with 180 sandpaper to unglaze the drum and pads and a dab of grease on the cam.
Never squealed once in all those miles. I've done 46 mph with SA drum wheels.
Roller brakes heat up so fast, the manual says don't touch it for half an HOUR. LOL
Likes For GamblerGORD53:
Quoted: 980 Post(s)
Liked 582 Times
I don't know if I'm one of the three , but I have to comment that this (correctly quoted by Gord) is ridiculous. I've never noticed any heat from my roller brakes in "normal" riding. Maybe riding the brake down a mountain pass would heat them up. In any case, even if they were glowing red hot, it wouldn't take a half hour for them to cool down. I don't know who wrote such nonsense.
Liked 3,875 Times
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 980 Post(s)
Liked 582 Times
The thing that looks like a disc brake rotor on the back wheel is a radiator connected to the drum part of the roller brake module.
