Drafting
Quoted: 5 Post(s)
Drafting
Just looking to get some opinions...is drafting effect a LOT more noticeable for lighter rider ?
I'm 15lbs heavier than a friend of mine. On our last ride outdoor, we did a road stretch with a headwind - when I was in front my average power was 370w and his average power was 187w. A difference of almost 200w.
On the same road stretch (same wind direction) after he passed in front of me, his average power was 277w and mine was 294w. The difference is -20w. I was still pushing more watts than him and I was really close to his back wheel. (no more than 6-8 inches). Both were in the drops when not the leader.
We both have the same powermeter, and we did test the accuracy of both power meter against a smart trainer.
15 lbs doesn't seems to be that much for such a difference...any thoughts ?
Sorry for my english.
It's not weight, its mainly height and riding position. I have occasionally ridden with a 6'8" co-worker, its like drafting behind a truck. You can be waaaaay back and still get a good draft. I've also tried drafting a 4'11" woman with an aggressive riding position, it just didn't work at all.
Quoted: 2543 Post(s)
Liked 1,811 Times
I would also guess that it's due to height and posture. Wind direction can also be a large variable.
Quoted: 5 Post(s)
Stand and Deliver
Bikes: Cannondale R1000, Giant TCR Advanced, Giant TCR Advanced SL
Bikes: 04 Giant TCR Composite 0, Public r16; old Raleigh 10sp; Felt fixie
3rd Grade Dropout
Quoted: 162 Post(s)
Liked 91 Times
I would try it again, and this time concentrate on your gearing and cadence. Try to run a chimpy gear, and up your cadence. I am a big guy, and when I draft behind my scrawny brother, I have to chimp the gears and match his buzzy cadence to maximize my draft. Basically mimic his gearing and leg speed like you are marching. Works for me sometimes.
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '05 Novara Big Buzz, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally, ‘21 Breezer Doppler Cafe+, ‘19 T Lab X3
Quoted: 1384 Post(s)
Liked 376 Times
"Chimp the gears"? That's a new one!
Thread Killer
Liked 376 Times
To the OP,
I have lots of protocol questions, e.g. what does "averaged" mean, exactly, with regards to watts, and does "same stretch of road" mean the exact same length over which you measured? It sounds like you swapped positions and kept riding, so could variations in grade and surfacing explain the variance you see?
blah blah blah
Quoted: 5 Post(s)
Maybe you were pulling on a slight uphill? Also drafting position is important in a crosswind, maybe your friend is better at riding in your wind shadow.
Quoted: 1096 Post(s)
Re-reading the first question, it occurred to me immediately that yes, a lighter person should more readily notice the beneficial effects of a draft. It seems that the benefit provided by a draft is in terms of a number of watts saved, so a lighter person would feel proportionately greater relief than a heavy person given the same draft advantage, because lighter people expend fewer watts to obtain any given speed. I don't know what the real numbers are likely to be, but for instance, 20 watts saved out of 200 is better than 20 watts saved out of 250. That's my guess.
Quoted: 38 Post(s)
Liked 7 Times
You didn't say he was pulling you at precisely the same speed you were pulling him. And are you certain the headwind was absolutely constant? A 2,3,4mph combined difference can make a considerable difference to power required.
That and you had two flat tires.
Either your power meters were not accurate or you have a much more upright riding position than your friend. Weight would have negligible impact.
Bonafide N00bs
Bikes: 2015 Cannondale Quick CX 4, 2014 Fuji Sportif 1.3C Disc, 2012 Fuji SST 2.0 Ultegra Di2
Quoted: 42 Post(s)
Sounds like he's getting less of a workout.
Its a great day for motor racing (really doesnt read the same without the accent does it?)
as a real light guy, I expect I am not much of a draft but I certainly notice a hell of a benefit behind big guys, coming from the "not much power" camp. When I have been on supported rides before, politely asking a passing tandem for a lift has always been like manna from heaven. Thankyou Lord for this fast rolling large wind blockage.
Quoted: 13320 Post(s)
Liked 1,782 Times
Any chance you could swap bikes and try your test again. You might also try side-by-side riding for a bit.
According to your numbers:
You:
Leading: 370 Drafting: 294, difference 76
Friend:
Leading: 277 Drafting: 187, difference 90
So, you both decrease the power significantly when drafting. Just, according to the power meter, you're using about 100w more than your friend.
My guess is one of several things could be happening:
You:
Friend:
- Power Meters out of calibration.
- Friends bike more aero, plus more aero/lower rolling resistance wheels.
- Are you getting a true "average"? Post analysis?
