Returning cyclist with a noob question
Zeke
Ok, I know this is a stoopid question. I have been away for awhile but.............Can someone tell me what the difference is between a Fixie, and a single speed? Isn’t a fixed gear and a single speed just a one speed bike? I apologize for the dumbness in advance.
Quoted: 7652 Post(s)
Liked 3,473 Times
A single-speed bike can have a freewheel mechanism which allows the rider to coast while keeping the pedals stationary. A "fixie" or fixed-gear bike has the gear solidly affixed to the rear wheel so if the wheel turns the gear turns, the chain turns and the pedals turn ---so you can never ;'coast." You always have to be pedaling as fast as the wheel is turning or pretty close to that speed.
This requires some unholy pedaling cadences on downhills.
Quoted: 18373 Post(s)
Liked 4,507 Times
A single speed has just one speed as you've guessed. However, it doesn't really specify how the rear sprocket is connected to the hub.
There would be basically 3 types:
- Freewheeling. You can backpedal. The bike requires both front and rear brakes.
- Coaster Brake. Backpedal half a revolution then uses a type of friction brake in the hub. Often found on kid's bikes and beach cruisers.
- Fixie. This is the simplest type. The rear sprocket is attached directly to the hub. However, it should have a lockring to hold it in place. The cranks turn when the bike moves, no coasting. One can stop by backpedalling, or skidding. They should have a front brake.
Zeke
Thank you! Finally I get it.
Bikes: 15 Giant anyroad 1, 16 Trek farley 9.6, 15 Trek domane 5.2 c
Quoted: 49 Post(s)
Wow I was not aware of this. Learn something new everyday.. Would seem to make sharp turning dangerous. Seems like braking would be difficult as well. Fixie no longer seems like a simple bike to ride . Things are usually more complicated in my head though
Liked 3,473 Times
The hardest part of riding a fixie is feeling comfortable with the weird hipster hairstyles you'd have to adopt.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
There was a single speed bike next to my non-fixie, non-single speed recumbent on the bike rack at work today. It had a flip-flop hub. I had to look close to determine that today the bike was a fixie. Flip the wheel and it's not a fixie.
Zeke
Zeke
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
And just to complicate things further, it is also possible to build a fixed-gear or coaster brake wheel that has variable speeds. In these cases, one will have the mechanism of a fixed gear (cranks continue to turn) or a coaster hub (backpedal to stop) along with an internal gear hub that allows one to change into different gears.
Once upon a time I thought about building a fixie with variable gears, but then got lazy and went with a single speed freewheel.
In other news, I don't think fixies are particularly cool anymore. Evidence is that most of us who got in on the original trend are pushing 40 or 50 years of age.
Liked 3,473 Times
Bikes: Ideal Hillmaster
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Fixies (fixed gear) should at least have a front brake, if not 2 brakes.
Track bikes are fixed gear, without brakes becuase they are on the track only, not the road.
Quoted: 2952 Post(s)
Liked 3,106 Times
Time-honored tradition of setting up an old road bike as a fixed gear for training/commuting/fun. I also have a freewheel on the other side of the hub but 99% I ride it fixed.
Gravel Rider
Bikes: 2019 Trek Checkpoint ALR5 | Trek Farley 5
Quoted: 93 Post(s)
Single gear is in one gear and can coast.
Nothing for nothing but a Google search and a YouTube search could answered this.
Zeke
True but that would have spoiled your fun of leaving a snarky comment. BTW The question was answered way back in post # 2
Liked 3,473 Times
Zeke
Yeah, but I was the poster of post #2 . Who would ever think that I would post a simple, accurate, helpful answer to a straightforward question?
Gravel Rider
Quoted: 93 Post(s)
Zeke
I have a question...
Why would anyone want to ride, much less own a "fixie"?
Quoted: 645 Post(s)
Liked 797 Times
It’s an interesting and arguably more challenging variation on regular road cycling. When winter closes in and I have less daylight to ride in, I might switch to the fixie to get the most “bang” out of shorter routes
