Front Rear Tire differential
Quoted: 41 Post(s)
So the front and rear tires on my mountain bike are made from two different manufactures and the front tire says to keep the tire pressure between 26psi-54psi. The rear tire says to keep it between 30psi and 45psi. So I figure to keep the front and rear tires at 30psi; is this the right idea?
Quoted: 4806 Post(s)
Liked 3,931 Times
Keep the tires below that maximum and with enough air to keep from pinch flatting. The minimums on the tire are just suggestions. Are the tires the same size? Are they similar type? If not, play with the pressure until they feel right. In general, a little less air in front works out best since you put less weight on the front. I generally use 5-8 psi less in front if the tires are the same size and type.
Ben
Ben
Quoted: 45 Post(s)
Not enough information.
Optimal tire pressure will depend on:
Tubed or tubeless
Tire size
Casing type
Rim width
Rider weight
Terrain
Aggressiveness of the rider
Tubed or tubeless
Tire size
Casing type
Rim width
Rider weight
Terrain
Quoted: 45 Post(s)
What tires are they using (size, casing, tubes/tubeless)?
What rims?
Are they riding buff singletrack at mellow speeds or charging nonstop chunk?
Do they "ride light" or are they proverbial bull in a china shop?
Depending on the answers to those questions, ~25 psi may or may not be reasonable.
Quoted: 5224 Post(s)
Liked 3,584 Times
exact #s aside, maybe squeeze them with your eyes closed? the front should feel softer. I like to look at the rear tire as I roll, to see how much it is deforming under my weight. I don't want a pinch flat but I also want some strength & weight bearing. plus if the trail is a harder pack variety I can go a little faster if the rear is a little harder than what I would use on softer ground. it's been surprising for me to see how low I can ride w tubed 29x2.25 Riddlers. I think they're at 21 front 25 rear
For best traction on technical and soft surfaces I usually keep lowering my tire pressure until they either start feeling squirmy on the corners, or start getting pinch flats on obstacles. I run Maxxis Ardents on one bike and Maxxis Minions on the other, both with tubes. For me this ends up being 20 to 22psi front and 25 to 28psi rear.
Quoted: 2976 Post(s)
Liked 1,182 Times
How much does the OP weigh?
What rims?
What rims?
Quoted: 45 Post(s)
Here's my buddy riding 30 psi on his Knolly, why is 30 psi too high for him? He's run lower but had issues with squirm and flatting.
Again, there are many variables that come in to play when getting to the right pressure. Variables that you either don't understand or choose to ignore.
Quoted: 45 Post(s)
Here are some general recommendations-
"Optimal tire pressure will depend on:
Tubed or tubeless
Tire size
Casing type
Rim width
Rider weight
Terrain
Aggressiveness of the rider"
Liked 1,182 Times
Ugh. You are obtuse. I'm not denying all of that comes into play. Those are hard and fast recommendations for the biker that is a tire geek.
For the general public that doesn't want to deal with figuring all of that out...25 psi is a good safe number for traction and rolling resistance. Assuming we aren't talking about a 300 lb rider.
And generally speaking 30 psi is too high. Especially on a hard tail as it would be like riding a bucking bronco.
Quoted: 45 Post(s)
For example:
The rigid bike in the video above is running 40f/45r which are good pressures for a 175 pound rider running 40mm tires on tubeless i25 rims on that trail. On the same trail (below, starting at 0:14), 18f/20r are good pressures ona FS bike when running 2.5 tires with reinforced casings on i35 rims.
Tubed or tubeless
Tire size
Casing type
Rim width
Rider weight
Terrain
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I've never had the same tire on the front and rear of any of my bikes at the same time. Is that even possible?
Seriously, I usually run a slightly wider and softer (less pressure) tire on the front and a more aggressive and heavier tire on the rear. Everyone has their own preferences and what works for them may not work for all.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
There is no “generally speaking” with tire pressure without knowing at the minimum rider weight and tire size and to a lesser extent tubed or tubeless.
Bit if you are going to make an across the board rec without taking into account tire size, tubeless/tubed, and rider weight, 25 is too low. That is going to leave a lot of people with flats. Also rear should be higher than front.
Its like recomending size 10.5 shoes without knowing anythinng about the individual because that is the average men’s shoe size.
Advanced Slacker
Liked 2,537 Times
Liked 1,182 Times
25 psi front and rear would leave me with near constant pinch flats in the rear with a tubed tire up to 2.4”. I weigh 175. I know this from experience.
How in the hell are you pinch flatting unless you have thin sidewalls on your tires.
Advanced Slacker
Liked 2,537 Times
I just did a 13 mile ride yesterday on my hardtail with 29 x 2.4 tubed tires on old school single track...lots of rocks and roots. Rear was at 25 psi and front was at 23 psi. I weigh close to 190 lbs geared.
In any event, there are a number of possible reasons:
Maybe I have more square edged hits. Maybe I ride faster. Maybe my sidewall or tubes are in fact thinner. Maybe you are a smoother rider.
I will say this though, I think my situation is more common than yours. Back in the day when we were all running tubes, I usually got away with lower pressure than most people.
Just because something works for you, does not make it the norm “generally speaking”. Telling the OP that his pressure is too high without knowing at the very minimum his weight and tire size is truly shooting in the dark..
Liked 3,931 Times
And if you believe any of this, well I don't know what to say.
Ben
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
It is but you have to find one of those rare 700I tires. (The English version. 700 tenths of an inch or 70" diameter. They made those tires 140 years ago for high-wheelers. ) Twist it into a figure 8. Now you can have one loop going around the front wheel and the other around the rear. It's not ideal. Tends to rub on the BB. But you do have real all wheel drive. Problem is that the front rotates backwards. It's still a concept in progress.
Ben
Ben
Really tired (yes it could be a pun) of hearing how 25 psi is too low.. I weigh 200 without gear, and always wear a backpack/hydration-pack, so I am at about 225 total. I have been running 25 front and 23 rear on both my trail bike with 27.5 x 2.25 tires and on my enduro bike with 27.5 x 2.4 tires now for four years. I have had 3 pinch flats, all on my trail bike, and all because I was trying to navigate 10 in high trail obstacle with a sharp edge and did it incorrectly.
Advanced Slacker
Liked 2,537 Times
Why do you run more pressure in the front than the rear?
Liked 1,182 Times
https://www.jensonusa.com/Q-Super-Light-29-Tube
In the end the reality of the situation is that whatever pressure is chosen you are choosing a trade off between rolling resistance and grip.
Advanced Slacker
Liked 2,537 Times
What I've been trying to say along along is that 25 psi is good starting point that works for most of the general public all the time. But some people try to dissect it too much when all I was doing was making a generalization. Start there than go out and experiment and fine tune. Optimum for 29er tires is between 18 and 28. 30+ is way too much unless you are riding gravel trails or smooth machine built single track with little to no features.
And you are wrong about what the trade-off is. In mountain biking, it is not rolling resistance vs traction: The primary drivers are traction vs pinch flats and loss of stability, which means that you may need to run higher pressure in rougher terrain and for more aggressive riding. Look at what most DH or Enduro racers are running: 2.3-2.5 tubeless tires, with sturdy sidewall. Visit some forums and look at the pressures they are running: mid 20s to low 30s is typical. Some higher.
The proper advice was given elsewhere in this thread: start high, and slowly lower until you find where you are either getting pinch flats or tires squirming.
Liked 1,182 Times
I understand what you are saying, and what I am saying is that it is not true. You are giving out bad advice, based on bad assumptions. Without knowing someones weight and tire size, you have NO IDEA what the optimum tire pressure is, and you had absolutely no basis to say that 30 was too high for the OP. You were shooting blindfolded in the dark. The range that "most people" run (which are numbers you are just making up based on almost no data), regardless of weight or tire size is utterly meaningless to any individual trying to get an of what pressure to run or even where to start. 30 PSI is ABSOLUTELY withing the range that some people end up. You just heard from a several in this thread. Were I running 2.1-2.2 tubed, I would be around 30, if not a little more.
However I do know 30psi + is too much for the normal mountain biker riding single track trail system.
Some of you are overthinking this and it's rare that pinch flatting is an issue these days with the wheel, tire, tube combinations now available and isn't an issue at all if tubeless...which I am on the fat bike and my full suspension bike.
