Tire sizing
Old 05-28-19, 02:46 AM
Cyclist0084
Cyclist0084's Avatar
Quoted: 184 Post(s)
Liked 353 Times in 90 Posts
Tire sizing
This isn't really a mechanical question per se, but was unsure of where else to put it, so.....
I own a Fuji Absolute 1.4 that has 700X28 tires on it. Would 700x32 tires fit on those rims, or would new rims be needed? Thanks in advance for any info provided.
Cyclist0084 is offline
Old 05-28-19, 03:56 AM
krecik
Quoted: 137 Post(s)
Liked 86 Times in 54 Posts
krecik is offline
Likes For krecik:
Old 05-28-19, 06:52 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
They will fit the rims. Check the clearance EVERYWHERE and ensure that you have at least 2mm additional clearance; on two of my bikes the front derailleur mech is the tight spot for the rear tire. Be aware that "32mm" tires vary quite widely in their actual width so figure that into your calculation as well.
Easiest might be to buy the tires from a local shop and have them test-fit them. Then if they don't fit you will not have to deal with returning them to an online vendor.
dsbrantjr is offline
Likes For dsbrantjr:
Old 05-28-19, 07:12 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
The specs that krecik cited above show that the rims are "Vera". Vera Corsa 32h, fitted with 28mm tires. A search for Vera rim specs yielded very little. You could measure the inside width of your rims. I would bet its 15 or 17mm. Either width will accomodate the wider tire but as dsbrantjr points out, the tire must fit in the frame as assembled. Do you have 2 extra millimeters of clearance at the fork, and the rear brake bridge, and the seat tube (with derailleur?). Given variability in tires, you may want to ensure you have a bit more than 2mm extra.
WizardOfBoz is offline
Likes For WizardOfBoz:
Old 05-28-19, 07:24 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
The rim shouldn't be a problem. The larger concern is frame clearance, as @dsbrantjr noted above.
JohnDThompson is offline
Likes For JohnDThompson:
Old 05-30-19, 04:51 AM
Cyclist0084
Quoted: 184 Post(s)
Thanks for the replies. I appreciate them all.
Just by eyeballing the frame and parts mentioned, it looks like there will be enough clearance to accommodate the wider tires, but I don't have a ruler, so this is just a guess. There are a couple of shops in my area, so I'll probably do my tire shopping this weekend. I've looked online at the myriad of tires available and I'm hoping between the two shops, I can find something I like with a "slight" tread.
Old 05-30-19, 06:52 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6192 Post(s)
Liked 4,190 Times in 2,351 Posts
The only limiting factor is going to be if the tire fits in the frame. The tires you can put on the rims could be just about any size...even up to 55mm. You'll find lots of confusing charts that tell you that you can't put xxmm size tires on XXmm width rims but, in practical terms, those charts are extremely conservative. For example, I'm running 35mm tires on 14mm rims. Every chart says you can't do that but I've had no issues with it. I also regularly run 55 mm mountain bike tires on 15 to 17mm rims without issues. The only problem I've ever had is with frame clearance.
Stuart Black
cyccommute is offline
Likes For cyccommute:
travelinhobo
Bicycle Mechanics
18
12-09-17 01:53 PM
Shaqo_Wyn
Classic & Vintage
9
04-03-17 04:03 AM
BartmanJ
Bicycle Mechanics
9
03-07-13 03:07 PM
mogi
Commuting
3
06-05-12 12:09 AM
b0dyman11
8
04-09-10 03:22 PM
