Creaking pedals
Creaking pedals
Old 08-19-19, 12:42 PM
TKJava
Bikes: Canyon Endurace, Kestrel RT1000 Ultegra
Quoted: 56 Post(s)
Liked 14 Times in 11 Posts
Creaking pedals
I have a set of Shimano M540 pedals on my bike which has Ultegra cranks on them. Shortly after installing these they started to creak when I put some decent pressure on them. I had to take them to a LBS because I could not remove them with a short 8mm wrench. The shop got them off cleaned the threads, re-greased them and put them back on using a torque wrench to get the proper tension/tightness. After this the bike was silent, all was great. Fast forward to me washing my bike and going out for a ride the creaking returned. I'm not sure what washing the bike did if anything it could have been a coincidence or not.
What I would like to ask the community here is what is the remedy for creaky pedals. I don't want to put lock-tite or teflon tape on them or something like that but this drives me crazy.
TKJava is offline
Old 08-19-19, 03:20 PM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
Maybe the problem isn't the interface between the pedal and the crank, but the interface between the pedal and the cleat/shoe
alcjphil is offline
Likes For alcjphil:
Old 08-19-19, 03:53 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
I agree with alcjphil that the shoes/cleats may be causing the noise, but what is wrong trying with PTFE tape on the threads? If you don't like it, it will peel right off. BTW, I use Tef-Gel and pedal washers on my pedals. No noises and easy to remove.
dsbrantjr is offline
Likes For dsbrantjr:
Old 08-20-19, 05:02 AM
djb
Quoted: 2739 Post(s)
Liked 971 Times in 794 Posts
Buy yourself a proper pedal wrench, it's worth it.
Make sure everything is clean and regrease pedal threads.
But yes, it could very well be shoe cleats.
Process by elimination if possible, diff pedals etc
djb is online now
Old 08-20-19, 07:28 AM
55murray
55murray's Avatar
Quoted: 207 Post(s)
Liked 108 Times in 58 Posts
SPD creaking is the shoe- the cleat sets in a recess in the sole and when put into the pedals the outer edges of the pedals can rub against the rubber sole just out from the cleats. Trim a bit of rubber away or put a touch of grease on the soles just out from the cleats. I went through this and did the pedal tightening, cleat tightening, lube on the cleat all to no effect. Yep, drives you nuts it is the loudest noise from the bike by far, and irritating as heck.
55murray is offline
Likes For 55murray:
RoscoeP
Touring
5
07-09-17 10:22 PM
TL2
General Cycling Discussion
17
04-04-16 10:25 AM
SHIM_105
Road Cycling
6
07-09-14 04:11 PM
KonaRider125
Bicycle Mechanics
15
02-08-14 08:20 PM
chrisrook
13
06-22-13 08:16 PM
