What is the black paste on the chain and sprockets?
Old 11-26-20, 09:33 PM
Eliz
Quoted: 5 Post(s)
When I clean my bike, I'm always struck by the stark difference between:
  1. the dirt on the frame and wheels, which takes the form of ordinary brown grains of sand
  2. the dirt on the chains and sprockets, which takes the form of a very fine-grained grimy black paste
(1) makes sense to me, because the dirt I ride on is also brown and sandy. But where does the black paste come from? What does it consist of? What makes it black when the dirt is brown and my chain lube is white? And why is it such a fine grained paste? How does it get on the chain and sprockets and nowhere else?
Thanks!
Eliz is offline
Old 11-26-20, 10:08 PM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 1844 Post(s)
Liked 589 Times in 420 Posts
Magic. Just wait until it gets on your white pants.
Not being a smartass; it also happens with clear chain lube.
thumpism is offline
Old 11-26-20, 10:13 PM
unterhausen
Randomhead
Liked 925 Times in 683 Posts
It's road grime. Doesn't stick to your frame very well, but the chain is sticky
unterhausen is offline
Old 11-26-20, 10:14 PM
fooferdoggie
Quoted: 183 Post(s)
Liked 182 Times in 105 Posts
its supposed to be metal. but I doubt its all metal. its a lot less with a dry lube verses wet.
fooferdoggie is offline
Old 11-26-20, 10:15 PM
Troul
:D
Troul's Avatar
Liked 480 Times in 340 Posts
the grim grime grease got you I read. Nothing prevents it, but the rate that it happens can be manipulated based on the type of products being used & how often you deep clean the moving wear items.
If you have ever used tools to work on a vehicle that has been used often up to that point, you may find that your hands will attract that similar black paste. Just in a lesser volume per area.
once a month the moving wear items are cleaned to remove that nastiesness & in between those cleanings, a quick detail is done as needed.
-Oh Hey!
Troul is offline
Old 11-27-20, 07:07 AM
timgriffin2
Bikes: 2020 Specialized Sirrus 3.0
Quoted: 61 Post(s)
Liked 34 Times in 19 Posts
I started using dry lube and there's a very noticeable difference with the reduced amount of black mystery crud on my drive train! It took a couple of cleanings/relubes to get it to this point. I guess it takes some time for the new dry lube to fully displace the old stuff deep in the chain. My chain maintenance has gone
Spray degreaser (I use Orange Clean) on drive train and let sit a while. Spray more on and scrub the chain and drive train with brushes/rags/chain cleaner tool. Wash the drive train with hot soapy water, wipe dry and let it then air dry completely, re-lube with wet chain lube and wipe off excess oil.
to:
Spray degreaser on a rag and wipe the chain while pedaling backwards. Wipe with clean rag, add dry lube to each chain roller top and bottom and let sit for a while. Wipe off excess with a clean rag. Add dry lube in between cleanings and wipe off excess.
Not a perfect solution but my point is that there's a noticeable decrease in the black greasy crud buildup on the drivetrain between cleanings using dry lube in my experience. For some reason it bugs me to "hear" my drivetrain as I pedal, hence my quest to make my life easier by finding easier/better ways to maintain a quiet ride.
timgriffin2 is offline
Old 11-27-20, 07:25 AM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 537 Post(s)
Liked 294 Times in 208 Posts
Metal dust from chain wear suspended in oil.
You get the same black dust inside pinball machines from solenoid plunger wear.
Drew Eckhardt is offline
Likes For Drew Eckhardt:
Old 11-27-20, 08:00 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3409 Post(s)
Liked 664 Times in 453 Posts
You get the same black dust inside pinball machines from solenoid plunger wear. It needs to be remove
Seems correct. But many chains aren't black metal, indeed often shiny silver, but still dark blackest black grime.
Sy Reene is offline
fooferdoggie
Quoted: 183 Post(s)
since using rock and roll lube I just need to wipe my chain each time I use it and clean the jockey wheels everything else stays pretty clean. it only lasts a week and a needs re applied after a rain ride or two.
Old 11-27-20, 08:42 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2439 Post(s)
Liked 950 Times in 611 Posts
The "black paste" is a mixture of chain lubricant, road grit, and wear particles from the sprockets, chain links, and chainring.
JohnDThompson is offline
Likes For JohnDThompson:
Old 11-27-20, 09:07 AM
Drew Eckhardt
Quoted: 537 Post(s)
While also shiny silver, pinball solenoid plungers produce the same black, conductive, slightly magnetic dust.
Old 11-27-20, 10:25 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 472 Post(s)
Liked 504 Times in 294 Posts
^This^...It's also a sign that there's too much lube on your chain. It shouldn't be there.
cxwrench is offline
Old 11-27-20, 11:21 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 3901 Post(s)
Liked 1,336 Times in 824 Posts
Itís not 100% metal particles but it is a high percentage of them and the color comes from the metal. The black color comes from the very small metal particles that are worn off the chain. As the particles get smaller, the way that they reflect light changes. It likely has something to do with the number of surfaces light is reflecting off. As the number of surfaces increase, the light is reflected in more of a random pattern which looks like the light is being absorbed. We are talking very tiny particles...close to nanometer scale.
Any minerals from the grit that lands on the chain would also undergo a similar random light reflection.
The same wear particles are there but they arenít mixed with a liquid and thus donít have the same physics. The dry lubricant is also more likely to flake off than a liquid lubricant which carries the wear particles with it. The dry lubricant also doesnít trap the grit and pump it into and out of the chain in the same way. The result is wear but less trapped metal particles.
Finely divided metals arenít shiny. Iron powder, for example is black but iron plate isnít. Aluminum powder is silver but not shiny. Grind anything and the properties change quite a bit.
No. Not really. The amount of lubricant on a chain has little to do with the color of the wear products. Additionally, oil, because it can flow, will move on the chain. No matter how often you wipe it off, more will flow until there isnít any oil left.
Thanks!
Your frame is just picking up dirt particles from the roadway. The color will often depend on the surface and what is on that surface. If you ride in dry sandy areas, the material on the frame will be brown dust. If you were to ride in a volcanic area, the particles on the frame probably be black. But the particles on the frame are just dirt particles and donít change colors much.
The chain and drivetrain, on the other hand, are wearing down the metal each time the chain engages a tooth on the front or rear. The pins of the chain wear and the teeth on the cogs and chainwheels wear. Each particle that comes off gets churned and ground and further reduced. The limit of how far down this material can be ground is the size of the atom of the metal. The sand that you are throwing on your frame is also thrown into the chain where it grinds away at the metal. Use oil and you get more particles stuck to the oil which get pumped into the chain where they can grind away at the chain and drivetrain.
And, just because thereís no free lunch, if you use a dry lubricant, the lube doesnít provide a vehicle for dirt to stick to the chain. Thatís good. But the lubricant also doesnít flow like oil does. The result is more metal to metal contact that also wears the drivetrain and chain. The parts still wear so you donít end up with superior chain or drivetrain life. in fact, the mileage is similar between the two lubricants. One just happens to be cleaner than the other.
All things being equal, I choose to use a lubricant that doesnít need constant cleaning...or the dry lube if that isnít clear.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 11-27-20, 12:27 PM
vane171
Quoted: 143 Post(s)
Liked 44 Times in 31 Posts
All things being equal, I choose to use a lubricant that doesn’t need constant cleaning...or the dry lube if that isn’t clear.
The cleaner condition is at the expense of the need for way more frequent re-lubrication, I suppose some lubricate before each ride, unless they ride only short spins of 10-20 miles.
From what I read around here, some take lubricant along for the ride to lube the chain after some 30-40 miles on longer rides.
vane171 is offline
Old 11-27-20, 04:43 PM
cyccommute
cyccommute's Avatar
No, it is not. I donít lubricate my chain before every ride and my lubricant lasts a whole lot longer than 20 miles. Iíve gone as far as 700 miles without having to relubricate my chain. I donít usually track the mileage but I did a tour around Lake Erie and had happened to install a new chain right before the tour...as in the chain having zero miles on it. I lubricated the chain 3 times in 1500 miles...at the beginning, at about 200 miles, at 900 miles and when I got home. The reason I lubed at 200 miles was because of about 70 miles of rain riding. I lubed again at 900 miles because I washed my bike after nearly all of the 700 miles was dirt path riding. I lubricated again at home just because.
I just happened to have kept track of the mileage on that chain just for this kind of discussion. I got 3500 miles out of the chain which I find to be about average from what Iíve read. Prior to this experience I was lubricating far more often than I do now. I go 200 to 500 miles between application. Thatís what most oil based users do. The only thing Iíve given up by using dry lubricants is constant cleaning.
Stuart Black
Old 11-27-20, 08:23 PM
MudPie
MudPie's Avatar
Quoted: 42 Post(s)
Liked 35 Times in 27 Posts
Interesting reference!
MudPie is offline
Old 11-27-20, 08:49 PM
veganbikes
Clark W. Griswold
Quoted: 2036 Post(s)
Liked 945 Times in 664 Posts
You sound like some sort of Pinball Wizard or something ; )
In terms of chains, get yours nice and clean along with the rest of the drivetrain and then I recommend using a nice wax lubricant or if you are feeling frisky, actually give it a nice wax bath (but for that you need to get it extra clean). It will keep things pretty clean and help prevent a lot of nasty grit and grime from accumulating.
This is my preferred lubricant but in the end they are probably all decent. I do notice I don't need to lubricate my drivetrains as much and of course the above cleaner drivetrain over all. I don't like a really dirty drivetrain, bike I can deal with as I am lazy at cleaning the whole shebang sometimes but not the drivetrain.
veganbikes is offline
Old 11-27-20, 09:10 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2713 Post(s)
Liked 895 Times in 650 Posts
I sometimes smile while I shake my head at some of these posts. One of the three Holy Grails of our activity is chain lube and grime. Figure out how to eliminate grime build up while extending a chain's life and not doing maintenance after lube application and we'll beat a path to your door. Like those other two grails this one is a repeated question that for the 47+ years I've been doing this stuff has never been answered (and, no, I don't think a drive belt is the answer). Andy
AndrewRStewart
Andrew R Stewart is offline
Old 11-27-20, 09:50 PM
cyccommute
cyccommute's Avatar
I donít see the problem as so difficult to answer. If oil based lubricants increase the longevity of the chain significantly (at least by 50%), Iíd use it in a heart beat. I have used oil in the past and had to deal with the mess. I probably still have the grease in the cracks of my fingers. About 20 years ago I tried something else and discovered that I didnít have to deal with the mess. It took quite a while...and not a little experimentation...to discover that I really didnít have to use as much as I initially thought.
I may not be able to answer both parts of your Grail but Iíll take one over the other.
Stuart Black
Old 11-28-20, 09:08 AM
davidad
Quoted: 489 Post(s)
Liked 100 Times in 88 Posts
Chain care, wear and skipping by Jobst Brandt (sheldonbrown.com) Simple truths.
davidad is offline
Old 11-28-20, 01:19 PM
Eliz
Quoted: 5 Post(s)
Wow, thanks for all the useful information!
If metal particles coming from metal-to-metal wear make up the bulk of the black grime, does that mean that a carbon belt drive won't have this black grime? Or do carbon belt drives maybe get black grimy carbon paste instead?
Eliz is offline
Old 11-28-20, 01:57 PM
veganbikes
Clark W. Griswold
The Gates Carbon Belt drive can get dirty but not greasy unless you add grease or pick up grease from somewhere. It is quite a clean drivetrain system but of course limited in frames you can use and gears.
Carbon paste is for things like a carbon seat post or handlebars to prevent them from slipping and acting as an anti seize/grease.
