Deore XT M8000 crank + threaded BB spacers?
Building up my gravel bike with the Deore XT M8000 cranks for the lower 1x gearing options. The bottom bracket recommended with this crankset is the Shimano XT M800 BB which will need some spacers (included in BB package) with my 68MM BB shell.
How reliable are these spacers? They are plastic. Are there any metal options? Has anyone had any experience?
Thanks!
Thanks!
Quoted: 576 Post(s)
Liked 1,001 Times
The spacers are fine, the cups themselves have deeper threaded sections to compensate for the lack of shell. I think some were Al; some of mine in my pile of parts appear to be metallic and not steel.
Many, many people have run those on 68mm shells with the spacers for years, its normal. As you say, they come in the box just for this purpose.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
the spacers are mandatory no matter what kind of drivetrain you are using to space the ends of the spindle correctly between the bearings. if you don't use spacers, you'll probably end up with play in the spindle.
theoretically, you could put all the spacers on one side or the other of the BB shell, so long as the effective width of the shell is corrected by the spacers. you probably would not want to do that because it would make the pedals laterally off-center and might make the clearance between the frame and the ends of the arms uneven, but it's possible.
the plastic spacers are fine. I've installed a lot of threaded external BB cups and the plastic spacers have never been known to break. if you put enough torque on the bearing cups to damage the plastic spacers, you've gone way overboard with the torque. Shimano's instructions are to grease the threads and then torque the cups to 35-50Nm. 50 is a lot. my experience, based on instructions from the Barnet's DX manual, is to use Loctite 242 and stop at 35Nm. that's more than enough, with the Loctite, to keep everything sealed up, and it won't come loose until you ask it to.
As others have written, if you have a 68mm BSA threaded bottom bracket shell, you need to use spacers with the external bottom bracket cups to fit a Shimano MTB crank designed for a 73mm bottom bracket. If you got such spacers from Shimano with your bottom bracket, I’d think they’re fine to use. You should also be able to buy aluminum 2.5mm spacers separately for use with a BSA bottom bracket, like these: https://wheelsmfg.com/bottom-bracket...ack-alloy.html
Thanks!
Thanks!
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
I have installed that crankset and bb on my Toughroad with a 68mm BB with metal spacers. I personally think the plastic spacers would deal with corrosion better IMO.
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Your LBS probably has spare metal spacers, just ask. That’s how I got mine.
Expired Member
Quoted: 3654 Post(s)
Liked 5,392 Times
