Alternative to Park DT-5.2
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 222 Post(s)
Liked 364 Times
Need to face the flat mount rear brake caliper mounts, Frame is a Spesh Aethos. Can’t get the 5.2 setup to establish parallelism due to not enough space. If I get the cutter head setup aligned I can’t get the blue handle onto the post to turn the cutter.
Is ther another method?
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Senior member
Quoted: 945 Post(s)
Liked 662 Times
I thought the design of the 5.2 was meant to solve this exact issue. Must be something about your frame design Park did not foresee.
Unless you actually have a 5 and not a 5.2.
Likes For Dan Burkhart:
Resident PIA
Quoted: 222 Post(s)
Liked 364 Times
Definitely 5.2
Shad
67'er
Shad
67'er
Quoted: 4475 Post(s)
Liked 1,619 Times
Leave the handle off and turn the post with a drill extension.
Or warranty the frame.
You can turn it with a regular 6-point (as I've done in a pinch). I can't recall the size off-hand. 8mm? 10?
8mm drill extension. Screw that stupid blue knob.
