noob hub question
noob hub question
looking to buy a used freewheel hub. is there a difference between track hubs and hubs that can take a 5spd freewheel? if so, how can i tell by eyeballing it if it will take 5spds?
thanks!
thanks!
Quoted: 5793 Post(s)
Liked 2,592 Times
yes there's a difference. The biggest difference is in spacing. Freewheel hubs are offset to one side, to have space on the right side for the freewheel. Track hubs, made for a single sprocket are usually symmetrical and don't have room on the right side for the freewheel's width.
FB
Chain-L site
FB
Chain-L site
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Ditto. The flanges on a "real" track hub are about 10mm farther apart than a 5 or 6-speed freewheel hub.
Jeff Wills
Jeff Wills
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
https://www.bikeforums.net/showthread...ighlight=126mm
Post #5 give you the numbers you need to determine if a certain hub modified or with modification will work.
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
thanks everybody. what about this one? is it possible to tell by looking if it will work with a 5spd?
https://www.ebay.com/itm/ws/eBayISAPI...23#ht_707wt_83
Quoted: 145 Post(s)
Liked 35 Times
Get a bunch of spacers - 2mm, 5mm, 8mm, 10mm, 12.5mm, 14mm and 16mm...swap 'em in and out until you get what I provided in the chart in the other thread I linked to.
=8-)
Disclaimer:
Disclaimer:
Quoted: 145 Post(s)
Liked 35 Times
No problemo!
=8-)
=8-)
Disclaimer:
Disclaimer:
