Cable housings
Cable housings
Hi. I want to install new v-brakes but I don't have the old cable housings. How to determine their correct length?
I have seen many videos about this, but I think your explanations will help me more.
If there are general rules on how to determine the correct length of cable housings (brake cables, gear cables), I would be very happy if you could tell me them or where I can find out about it.
PS. If this problem has already been discussed on the forum, I apologize and please indicate where I can read.
Quoted: 242 Post(s)
Liked 455 Times
Smooth but not excessive lines are best for a smooth shift.
Use the new housing to measure from point A to B then cut. Better to cut a bit longer then trim to fit than to short and waste housing.
Make sure to use a proper housing cutter tool or you may be very sorry. Same for the cables.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
With handlebars, I make sure to measure when they are turned so the longest possible housing length is required (not sure if I've explained this clearly).
I go for the shortest possible, without having extremely sharp bends (though, despite the popular belief, it's the total angle change, not the curve radius that causes more friction).
For more details I wrote this article (with pictures, explanation, and Mr Mark Barrilleaux's friction test results):
Routing brake and shifter housing and cables
Relja
Likes For Bike Gremlin:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
The front's easy. You don't have to allow for wrap around the head tube when you turn. Measure a smooth arc from the lever to the noodle. For the rear, turn the bars all the way to the right and leave a few cm around the front of the head tube.
Read Sheldon Brown's article on this in his website.
Likes For andrewclaus:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The housing should be long enough to allow turning the handlebars without tugging the cables, without any abrupt bends or angles, and not so long to leave big loops of housing at the levers, derailleurs, and calipers. The housing ends should be dressed with a grinder or file after trimming, to remove any burrs and allow the housing to seat properly in the ferrule or housing stop. Use a pointed object (I use an old spoke, ground to a point) to open the plastic housing liner. Compressionless derailleur housing needs ferrules on each end to prevent the housing from splaying in use.
Quoted: 3513 Post(s)
Liked 2,927 Times
As mentioned above, do you possess appropriate cable cutters? This tool is crucial.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
A bit long in the housing is better than a bit short. A little long won't apply brakes or cause shifting when you turn tight like too short will.
Quoted: 1062 Post(s)
Liked 665 Times
In addition to the advice given here, I suggest actually looking at a bunch of bikes, to get an idea of what the right amount of curvature looks like in front.
My habit when cabling a bike (often because I've thrown it together from parts) is to route the housing from the rear brake through its guides, up to where it departs from the frame in front. Then I hold it in what looks like the correct position, more or less, cut it off, and prep it for use. Done.
"Looks about right" will get you into the ballpark.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,996 Times
Also not as an install point but just in general get the best cables and housing you can don't go for cheap stuff go for nice polished uncoated stainless cables and good stiff compressionless housing. It will greatly improve your braking for little money spent and this is true for linear pull brakes, road caliper brakes, cantilevers, mechanical disc brakes and with some different housing mechanical shifting as well (you would also need a different cable but the actual style of cable would be the same). Also good stiff brake shoes and really high quality pads (the two should be separate for better braking) will help out a huge amount again with low costs associated with them.
Everyone looks like they have given good install pointers and tips but I like to mention the above because it really improves things in a really cost effective way that actual brakes and levers may not do to the same level.
Liked 2,927 Times
Liked 2,927 Times
Clark W. Griswold
Liked 3,996 Times
However agreed that the kits are nice, it comes with everything and plenty left over for future repairs.
Jagwire doesn't do coated cables. The Park Tool Cutter is fine but it isn't the greatest of tools, Felco or Knipex is the way to go on that front. You should have issues with a decent cutter that is properly sharp and using good pressure and an even cut.
Clark W. Griswold
Liked 3,996 Times
Which one do they make that is coated? I don't see it on their website and haven't seen it in real life. Shimano and others make some coated stuff but not Jagwire as far I know and can tell from their own website. They make cheap or slick stainless and galvanized, polished or ultra polished stainless but nothing coated that I can see.
Clark W. Griswold
Liked 3,996 Times
I think this was one I got long ago. It had a dark Teflon coating. https://cambriabike.com/products/jag...kaAmt6EALw_wcB
No worries. Like I said earlier, it cut poorly and frayed easier. Having thought about it a bit, the world doesn’t need more fluorocarbons in circulation either. Sure they are more slick, but for vintage use I am not sure they are needed. I silicone lubes are plenty good and don’t attract dirt like oil lubes. Anyway, just my 2 cents
Liked 2,927 Times
Clark W. Griswold
Liked 3,996 Times
Shimano should learn from them and get rid of the coatings but they are who they are and do what they do.
I'm glad that my post has generated so many discussions from which everyone can definitely learn something, especially those less knowledgeable like me. Thank you very much.
