Kick Stand - Nice Dutch Like Double Style for my new Breezer Uptown 8
Bikes: Bakfiets, 1999 GT Nomad Hybrid, early 70's Schwinn Cruiser 5, Bridgestone MB-3, Trek 520 Disc, Electra Ticino 8D, Ochsner blue Road Bike
Quoted: 5 Post(s)
So I have this little itty bitty stick barely able to hold the bike up on it's own, let alone if I pack a pannier or 2 in back.
I would like a double kick stand.
I have the Gary Fisher style one on my Hybrid...it is handy for light loads and jumping on the bus... but it is not really all "that" stable. Seems a little short in the stoutness.
Does anyone know of a kick stand that might have enough stout yet not hit my pedals/cranks/rear tire?
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
https://www.velo-orange.com/podolegki.html
I have installed this and it is about the stablest double kickstand I have tried so far other than the special one Xtracycle makes for their cargo bikes or the very expensive "Rolling jackass" longtail cargo bike center stand.
It does need the leg folding pivots mechanism greased as part of installation.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Location: Alameda, CA, an island city on the edge of San Francisco Bay
I'm planning to get the Pletscher installed next month on my Uptown 8. Right now the bike tips over if I've loaded a lot of groceries in the rear.
Anyone use this?
Anyone use this?
Gunnar Roadie with Campagnolo Centaur
Breezer Uptown 8
Breezer Uptown 8
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I have a couple of them and they work great. I do plan to get one of the V-O ones and give it a try.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
17yrold in 64yrold body
I got one for my touring bike, and it works great!
BTW I especially like how the two legs come to the side away from the drivetrain when up.
Gear Hub fan
I have both the Pletscher and VO center stands as well as a Hebie one on different bikes. The VO is a bit wider while lowered while the Pletscher is smoother in operation. Both have the problem of still allowing the bike to tip during loading if too much weight is placed on one side. A standard bicycle is just so light weight that too much off center weight can overbalance all center stands I have tried except the Xtracycle specific one I have on my Surly Big Dummy.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Gear Hub fan
The VO and Pletscher are different designs and on my bikes both interfere with crank rotation but this is not a concern to me as I do not try to use the center stand as a maintenance stand other than for puncture repairs. The main similarity between the two stands is that both have articulated arms. I have not read that use of the Pletscher on a loaded bike was not recommended. Certainly I would not sit on the bike with the stand down with any bicycle center stand.
The Hebie aluminum stand I have installed on one bike does not interfere with crank rotation but does stick out to the sides considerably more when folded than the VO. The Hebie is no better at holding the bike upright while cargo loading than the Pletscher or VO stands though.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
https://www.crowcycleco.com/double-le...ust-black.html
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Quoted: 840 Post(s)
Liked 336 Times
Pletscher is wobbly and a heavier load, particularly on a mild slope, is likely to tip the bike and make it fall to the side. A steel holding bolt will work its way out of an alu thread, under load and tilting, as a matter of time. Any alu stand will be wobbly under load. Complex joints out of alu, combined with steel pins, will loosen over time and likely corrode. Combing alu stands with a load is asking for trouble. When on the road, there is no luxury of choosing a stand for repairs.
Quoted: 5 Post(s)
The Velo and Crow models listed appear to be what I am looking for. Something similar of the same as what an Azor Dutch type bike would come with.
However, I wonder if they (Velo model above or the Crow) would clear the chain guard, crank arms, and my back heal okay?
If not maybe the V.O. is my best bet? Since it sits on one side like the Pletscher and that allows plenty of clearance.
I have a Pletscher on my GT Nomad Hybrid. It is falling off, loosens a lot... It needed to be mounted crooked on the mount due to the design. I wonder what the best way to keep it solid on the bike would be?
Low cost VO one is heightadjustable, the lower section is plastic, though.
Esge I have after I cut it to length a pair of D shaped pads were welded on, which greadly stabilized the support
they are D shaped so folded up the flat sides face each other..
the best way to keep a kickstand solid in a frame is to have a mounting plate for that kickstand welded on the frame either while it was being built, or later then doing a touch up spot paint.
Quoted: 10 Post(s)
Liked 6 Times
To install the crow stand all you have to watch is how much clearence there is between the tire and the "U" of the legs around it. The stand hangs down a bit but unless you jump curbs and such it will not catch on anything. Then it's a simple matter to adjust the leg length to hold the bike square and upright. I figure a decent bike wrench can install a "Crow" stand in under 5 min. they're so simple.
Quoted: 10 Post(s)
I've got a Pletscher, the one that has both legs move to the left under chainstay when folded up. I use it on my commuter/utility bike.
It works well -- especially after I trimmed the legs so they didn't raise the bike so high.
With the shorter legs, it is good and stable.
Kickstands are not popular, but I don't know why -- I sure like having one on this bike.
This, previously posted in C&V, might be mildly interesting and/or entertaining...
Good evening and welcome to Over-engineering Today. I'm your host, RMC.
We all love the Pletscher two-leg kickstand for rock-solid stability on our city and picnic bikes.
But mounting can be a problem. The kickstand can pivot on the single bolt. With repeated kicking (er, standing) the legs can move over until they hit your crank when you're riding, or when the bike is up on the stand--say, when you're trying to adjust the gearing or the rear drum brake, and you want to be able to spin the cranks while the bike is up on the stand without the left crank clanking into one of the kickstand legs.
Ideally, you can use the stand all the time and never have to worry about either of these problems.
So we have something that pivots and we want to be able to limit its travel in either direction and be able to apply fine adjustment to get it positioned in just the right place. Hmmm. Where have we seen a technological application like this before??
Ah yes!
Materials you will need:
1. Ample room under chainstays for over-mechanizing with two previously installed extra mounting points.
2. Quarter-inch key stock.
3. Tap, screws, and springs.
4. Most of Sunday.
And ... voila! The world's most over-engineered Kickstand Positioning System (tm). And it weighs less than three pounds!
Ah yes!
4. Most of Sunday.
...snip....
Ah yes!
4. Most of Sunday.
...snip....
Ah yes!
4. Most of Sunday.
I made a custom upper piece for my Pletscher, replacing the weird semi-diamond shaped top piece under the head of the bolt. I made mine from white delrin, as it was on hand. Black delrin would have been my preference. Also, I filed some grooves in the upper part of the kickstand, the part that touches the underside the chainstay. The grooves are fit to the chainstays, which locks them in. I wasn't worried about my paint finish as it is my utility bike, and it is an aluminum frame. I got tired of the Pletscher moving around as described above, and embarked on a lasting solution to the problem.
Here is a photo of the mount from the top:
The delrin block was custom shaped to wedge into the trapezoidal space right behind the BB shell and the cross member that acts as a fender mount (is there a term for that short piece that bridges the two chainstays?)
There is also a groove on the bottom of the delrin block that bears against the front of the kickstand, holding it in position.
I'll take some more pictures to better show what is happening.
It took several hours of my time, but I'm very pleased with the result. I will have to fab up some more for some other bikes I own.
So is aluminum and steel. What is your point? Sure, you don't need machine tools to cut it, but it makes it more accurate and better finished. Not to mention faster.
I've done plenty of work with a hacksaw and a file on steel and aluminum.
Location: Colorado-California-Florida-(hopefully soon): Panama
Bikes: Vintage GT Xizang (titanium mountain bike)
Isn't weight an issue to anyone? For maximum strength and minimum weight, has anyone tried a good kick stand made of titanium?
Aluminum is lighter and cheaper than Titanium . but heck its your wallet , custom Titanium propstand , go for It.
I fabricated a version of a rear wheel prop stand, from thinwall steel tube..
held the bike up on damp peat bogs.
Quoted: 70 Post(s)
Liked 15 Times
On a light weight go fast bike I most likely wouldn't have a kickstand. I consider the weight of a utility bike to be kind of like the mileage on a pickup truck...you don't worry about it, if it is doing it's job.
Aaron
Quoted: 5 Post(s)
Yeah, utility cycling and weight is hardly a concern. The wheels still spin and most people carrying groceries are concerned with ultimate speed.
