Raleigh Sports fork question
I have a 72' Sports that has a slight problem. The fork as you can see from the picture has the piece (i dont know what its called, it connects the wheel to the fork) that is loose and I can pull it out from the rest of the fork. This in turn causes the wheel to lean into the fork and rub the tire... I never noticed because of where the fender connects to the fork, it pretty much held it in place but im sure as sh*t not going to ride it like that now that i know..
Is there any product I can put in there to glue it in place that will hold up to the stress? I thought about JB weld, but I figured someone on here would be able to help me out...I went to my LBS and they said they could measure and order a new fork (not a Raleigh fork) and install it for $60-$100 and I have had zero luck looking online for a replacement...
thanks to all
thanks to all
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
Non Raleigh 26" forks are available on Ebay for cheap. You'll need a matching headset, though cause Raleigh uses 26tpi threading while the rest of the world uses 24tpi.
What size frame is this for and how long is the steerer tube?
I have a Sports Fork that I have no use for. Measure your headtube and I'll make sure the steerer on mine is long enough. PM me for details
perpetually frazzled
Bikes: 1977 Bridgestone Kabuki Super Speed; 1979 Raleigh Professional; 1983 Raleigh Rapide mixte; 1974 Peugeot UO-8; 1993 Univega Activa Trail; 1972 Raleigh Sports; 1967 Phillips; 1981 Schwinn World Tourist; 1976 Schwinn LeTour mixte; 1964 Western Flyer
Quoted: 5 Post(s)
Liked 6 Times
If you want to go the replacement, try ebay for genuine Raleigh forks, or bikepartsusa or what not for chromed threaded forks.
You can always JB weld it - it's just hi-tensile steel.
hey Jmichael, I have to have 50 posts to PM. not sure how precise the measurement has to be but inside the chrome is 4"11/16 and from the bottom of the stem to the top of the fork is 6" hope this helps and thanks all for your help. I have been looking on ebay and haven't found a fork yet.
Quoted: 5 Post(s)
Liked 6 Times
I've JB-welded a high-compression V8 head back together...you're telling me that the fork on a Raleigh sports is going to take more power than that? Doubtful.
JB weld is your friend, my friend.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
Maybe I've been mixing it wrong, but I've never been impressed with JB Weld (or Marine-Tex,) I wouldn't trust it in that application. Besides, isn't this his girlfriend's bike?
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
JB Weld is great stuff but these forks are pretty common. be patient, one will come along.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The dropout needs to be brazed back into the slot.
Where are you located?
You gonna eat that?
Im pretty set on just getting another fork, but i went the JB route just to see what would happen. It looks terrible......ha but i am just curious if it will hold up. Gonna let it cure for a while..
Im located in Winter Park, FL right beside Orlando
Thanks for all the responses, I really appreciate everyones help.
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
I've been a Professional Auto Technician for close to 35 years, I have used JB weld on lots of things. I can tell you the drop out is not going to hold, it can never have the holding power a brazed joint has. BTW, the reason it fell out is, cause the brazing job was cold, or dirty. Have it rebrazed, paint it and you'll be done with it.
I have fixed transmission cases that were seeping fluid due to case porsity.
Mike
Mike
nans
3
10-17-12 08:34 AM
Hakbil
Classic & Vintage
6
10-19-11 09:52 PM
