Kick stand
Kick stand
I'm looking for a good kickstand should I pick one that would go on the back wheel area or one that is more center in the bike like near the pedals ? I've seen both before but never used kick stands before I also was looking at a 2 post kickstand but don't want to spend that much I'd like to be around 10 15 at most if it's possible and it needs to be good for my 19 inch Fran 29er bike
Any suggestions
Also does anyone here use bell or showing helmets question I was at the bike shop today looking at helmets but just can't afford the 50 and up prices they have there so then I when's to walmart and tried a few on that would be around 24 dollars each and found one bell anda swing that fit good
Did find a bottle holder at the local shop that would hold my daily water bottle that it fit in so picking that up when I take it in for a check up to make sure I put it together right
I already talked to the shop they said 44 for a basic tune up or if they look and see it's all good then it would just be like 8 dollars. For each component that might need to be set or adjusted right
Like the brakes and the gearing
Also plan on getting a bigger seat from the local shop
Any suggestions
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Bikes: All Treks - fitness and road
Thumper- A benefit of hanging out here to read and ask questions is that communication skills improve over time. Most of us can stand some skill polishing, and someone is always willing to point out our errors. Welcome to the editing room.
I've only used the single post kickstand style that mounts just aft of the bottom bracket. If you need a kickstand, this type works very well. Lots of cyclists don't use a kickstand, but thats up to each individual.
Your Walmart helmet should work fine if it fits well. Keep the chin strap from drooping when you're riding.
An $8 bike shop check up to see if your bike needs adjustments sounds like a fair deal.
Good luck. Ride safely.
thank you My issue is that sometime i forget to use spell check but i do have legitimate issues with punctuation but sometimes i forget to try and fix it when im in a hurry .
when you say just after the bottom bracket are you talking about the ones that is down under near the medals ?
or are you talking about bracket near the back wheel ? im confused about that
Bikes: Cannondale F29, Cannondale Trail 29 ss, Cannondale CAAD8, Specialized P1
Where the arms attached to the pedals meet the frame. That's called a bottom bracket (where the round bearings are located) and it's typical for kickstands to be mounted right behind there.
Your local bike shop should have a kickstand available cheap or free because most people on mountain bikes do not use them due to 1) weight and 2) they could drop down while jumping/turning and 3) the pedal arm can smack into them if they become loose. Most bikes ship with one, but rarely are they installed, so they may have one lying around for you to use.
Here ya go, Thumper. This short UTube video shows how to install a kickstand.
https://m.youtube.com/watch?v=lTZCRqTstaE
Quoted: 67 Post(s)
Liked 83 Times
Than post the question in the commuter forum, where it makes sense, rather than the MTB forum which is filled with rad bro/brahs like myself who wouldn't pee on a kickstand if it was on fire.
Quoted: 453 Post(s)
Liked 104 Times
It's nothing about being cool but you posted this on an MTB forum, kickstands don't belong on MTB's end of story.
If you had posted on say the commuter forum., then you would have got more positive replies.
Bikes: 2011 Surly LHT 2005 LeMond Zurich
yes... the kickstand positive negative ratio does vary on the different forums :-)
Ok thanks
the thing is if I was going to use and abuse in mountain and rocks I'd get something other than a hard tail I'm going to be doing some off road but not as much with this now if I had one I was going to use for heavy riding full suspension then I'd not do this
Quoted: 67 Post(s)
Liked 83 Times
Ok thanks
i didn't mean for it to be a bad statement about not using a hard tail at all offroad like that
should have been more clear for me i wouldn't because im 300 pounds and from experience when i was even heavier the rear end would taco and id be out a frame
so for me being heavy like i am i wouldn't
sorry for the conffusion
You definitely don't want to buy "race" components (i.e., light weight parts made for 150lbs guys) nor a race frame, but a good quality hardtail should have no problem holding up to you IF your technique is good (i.e., not sitting down all the time, esp. downhill)
I've got a buddy who is well over 300 and he rides a Niner hardtail on all of the same trails that I ride. Granted, he doesn't bomb down trails at the same speed as some of us, but he carries more weight and the frame and components have all held up well.
i was specificaly looking for a good strong sturdy but light weight frame
the bike i got the frame is a material called DP780 i researched it a bit and found out ill give it a try and see how it works out
once it comes i need to look at the fork now will the company that made the fork but on the fork anywhere since its comming from a bike company not just the fork company ? i mean its branded with Alton the brand of the bike but i didn't see in pictures anywhere that is said who makes the fork
is there any way i can tell when looking where it would say that ?
Bikes: Canfield Yelli Screamy, Pivot Mach5, Specialized Roubaix, '65 Hercules, '79 Schwinn Stingray Lil Chic, '68 Schwinn Stingray Fastback, '89 Specialized Allez Epic, '86 Battaglin World Champion
Do you have a link to the bike you bought?
I just did a little research on Alton and watched their promo video on DP780 steel and I'm just a little suspect of their claims. Also, their bikes seem to be equipped on the low-end of the spectrum. Not Wal-Mart low-end, but Shimano Altus/Acera derailleurs on their high-end 29er makes me suspicious of what kind of no-name suspension fork and other questionable components are part of the package.
But if it works for you, cool.
I'll be interested to read a review once the bike arrives and you've had time to ride it a few times.
i for sure will wright a review i got it because the frame comes with a 2 year warranty and the other parts all have 1 year warranty
i wanted Shimano i know that its lower end shimano but its still quality stuff
and not going to be cheap like walmart or target items
and i can always upgrade at a later time
I was wondering thought can i upgrade the spring in the front fork to be a better quality and resistance for me or ist he only way to upgrade that by replacing the fork itself with better quality like Rock Shok ?
Pedals, Paddles and Poles
Bikes: Santa Cruz Tallboy, Ridley Noah, Scott Spark 20
Quoted: 1233 Post(s)
Liked 69 Times
Everyone has to start somewhere. The kick stand question has been asked before. You got off easy. Stick around we have lots to share. A mountain bike is the best bike in the world for any comparable price point. The whole world is your trail system, kick it hard bro!
I think its disgusting and terrible how people treat Lance Armstrong, especially after winning 7 Tour de France Titles while on drugs!
I can't even find my bike when I'm on drugs. -Willie N.
here is the link
Corsa DP-X9 29er Men?s 29" 24-Speed Mountain Bike
