Bottecchia
Bottecchia
Any idea what this bottecchia might be? I picked it up last night. Ofmega headset and crankset. Super record replacement rear derailleur. CLB brakes and levers although it may have come with Universal centerpulls as a set came with the box. Decal says 1979 Carnielli so at least that vintage or later.
Couple more photos here
Bottecchia https://imgur.com/gallery/20AQVFR
Bottecchia 2 https://imgur.com/gallery/yXRywxQ
Likes For Lemond1985:
Likes For Narhay:
Quoted: 3810 Post(s)
Liked 3,335 Times
Thanks for posting.
Five images but not one of the drive side.
Is the roundish white transfer at the top of the seat tube a tubing one?
AELLE perhaps?
Is stem & bar set ITM? 3TTT?
Original pedals and hubs likely OFMEGA as well...
Original brakes may have been Super 68.
Original rims likely NISI.
Thanks for posting.
AELLE perhaps?
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
Likes For cudak888:
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
I've cleaned the frame up and taken some better pictures above. It is a square 23" c-c top tube and seat tube. Italian threads. 120mm rear dropout spacing.
Likes For Narhay:
Liked 3,335 Times
Thank you for the additional imagery.
The more I look at it the more I suspect blades may be pushed back ever so slightly.
One simple check you could make is to lay a straightedge along the centreline of the side of the headtube and see where it comes out on the lateral side of the fork blade(s).
My guess is that the centreline of the blade(s) will be very slightly aft of the straightedge.
As ever, I happily defer to @gugie in all such matters...
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
And so it is with forks I've found. Many fork crowns allow for some wiggle fore and aft so that the steerer and the centerline of the fork blades can be mismatched, but as long as the dropouts are centered, have the same offset, and the trail is adequate for the handling intended, it's not a problem.
That's not to say this Bottechia fork hasn't been bent back, but if it has, it could be bent forward again. The deal breaker is if the steerer is bent, unless, of course, you want to go and replace a steerer, which I've done a few times.
Could be just the angle the picture was taken, but the only way to really tell is to remove the fork and look at it off the frame.
Liked 4,390 Times
I wouldn't use this as an excuse NOT to verify, but I'd take the picture with a grain of salt. If you look closely enough, the lens distortion is also curving the seattube slightly forward.
-Kurt
Likes For cudak888:
Depends where I measure it but it looks tweaked in some and some not so much? Photo with wheels as well.
Liked 4,390 Times
Liked 3,335 Times
Thanks very much for the responses gugie, Narhay & Kurt.
Followup note on fork -
if you are on good terms with a local shop/co-op/frambuilder perhaps you could withdraw it and put it in their fork alignment gauge to see what you find.
the Park jig, for example, has a groove running along the side of the clamping assembly which lines up with the centreline of the steerer.
two good things will follow:
a) you get to examine steerer as well and fork and know the fork's alignment one way or the other
b) you will have an opportunity to repack the HS
have you made a check of the pillar size as yet?
as T-Mar us ever reminding us it is an indication of tubing quality
if frame quality plain gauge would expect a pillar of 26.2mm or 26.4mm
one thing which struck me straightaway regarding the frame was how few braze-ons it has for 1979 or later
by 1979 the braze-on madness was at full tilt
shall look forward to reading your next update as you work with this new arrival
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
I had a 1972 Special, that was my first thought on seeing this frame set. Not the original componentry if it is a special though. Mine had Campy Valentino dress, and a cottered steel crank set. @randyjawa has a blue one featured in his website. Beautifully done bike, I wish I still had mine, it was my gateway drug for cycling.
Bill
Bill
Eric
Similar perhaps to 1972 Gran Turismo, link: https://campybike.com/pdf/1972Bottecchia.pdf
Liked 3,335 Times
Did you look at the Carnielli transfer with the 1979 date?
Do you think it added later?
Liked 3,335 Times
The Carnielli 1979 transfer is not something which would have been readily available to the general public.
One possibility which fits the information we have is that the frame was somehow lost/forgotten/covered up at the factory and when it was rediscovered at a later time it was then built into a complete machine using the then current fittings of a similar model. This would explain the presence of the OFMEGA components, for example, versus the fittings shown on the 1972 catalogue page.
Verily an oddity...
Verily an oddity...
Quoted: 4722 Post(s)
Liked 3,036 Times
My immediate impression was a post boom, entry level model. Frankly, I was surprised by the Carnielli 1979 decal. The frame looks earlier to me, circa 1975-1976. I strongly suspect a lightweight hi-tensile steel with a post size of around 26.2mm. Had this been something like Aelle, I would have expected more braze-ons, forged dropouts, higher grade lugs and a 700C wheelset. This looks like it's designed for 27" wheels. The brakeset looks like very long reach with pads set at the bottom of the range, suggesting a later upgrade to 700C. That looks like a Bloor Cycle decal on the down tube.
Semper Fi
Liked 358 Times
Confusing me more and more ( not truly difficult though,) the rear drops say a DeLuxe model, but it lacks some things, and has chrome on the chain stays and forks, that a Deluxe wouldn't have had, IIRC.
@T-Mar reminded me that these probably had 27" wheels, I had forgotten that little fact about my Special .
Bill
*Edit: looking closer at a larger image, those are higher level drops, front and rear, than either the De Luxe or Special. My bad, my eyes just are not up to the detail stuff anymore. No further guesses forth coming form here.
Bill
It is a Bloor Cycles decal. The previous owner said when he bought it it was $600 or so, CAD. He had been looking at cinellis at the same time but his mother told him an Italian cyclist won some giros on a bottecchia and it was quite a bit cheaper.
Super record rd, a couple sets of high flange record hub 6 speed tubular wheels suggest someone who was willing to spend high end dollars on the sport and was riding big miles but to hang them all on a bottom end frame....who knows? Maybe the bike shop found the frame and hung what he wanted on it.
It came with a pile of early 80s anodized tubulars and he said he was active in cycling until he got married so a timeline of late 70s to mid 80s works for the SR rd and mavic gp4 tubulars.
leunkstar
0
10-12-10 02:54 PM
