appropriate amount of seat to bar drop
What do you think would be the appropriate amount of bar drop for a person who is 5'7" with an inseam of 30 inches in a competative fit
Here are my numbers from CC
Measurements
Inseam: 30
Trunk: 25
Forearm: 13
Arm: 24.25
Thigh: 22.25
Lower Leg: 20.25
Sternal Notch: 55.5
Total Body Height: 67
The Competitive Fit (cm)
Seat tube range c-c: 49.3 - 49.8
Seat tube range c-t: 50.9 - 51.4
Top tube length: 53.3 - 53.7
Stem Length: 10.6 - 11.2
BB-Saddle Position: 67.6 - 69.6
Saddle-Handlebar: 50.4 - 51.0
Saddle Setback: 2.9 - 3.3
Measurements
Inseam: 30
Trunk: 25
Forearm: 13
Arm: 24.25
Thigh: 22.25
Lower Leg: 20.25
Sternal Notch: 55.5
pan y agua
Quoted: 1442 Post(s)
Liked 711 Times
at least 19cm.
The true answer is the amount that allows you to still be comfortable and produce power.
You should always err on the side of less drop.
Not enough drop, bend your elbows and get low when you want to go fast.
Too much drop and it's alwys going to suck.
You could get lost and die.
You could hit a tree and die.
Quoted: 104 Post(s)
Liked 5 Times
I think it depends more on your fitness level and core strength than your flexibility (except if your flexibility is really terrible).
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
whatever feels comfortable.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Indefatigable
Bikes: 09 Motobecane Grand Sprint and a couple others not worth mentioning.
My flexibility is not good, but my seat is up about 4 inches or so (I am 5'9) and I am very comfortable in the drops most of the time, almost always on flat rides. This has a lot to do with how you feel most comfortable.
Violin guitar mandolin
Bikes: Wilier Thor, Fuji Professional, LeMond Wayzata
