how about this dumb question about grease.....
Quoted: 231 Post(s)
Liked 10 Times
I have one those fancy small grease guns like Park Tool sells.....(the gg-1). I run park grease in it out f my tub of grease. i recently ran into another grease gun.....that i got for free. What would you fill this with knowing you already have a tool filled with bike specific park grease/
What is everyones go to grease for reabuilds and servicing...
Id rather stay away from the mobile one or that crap red and tacky stuff.........as both appear to turn to liquid garbage from sitting. Im looking for recommendations that wont break down and turn into a nightmare to clean up in my toolbox or in my bikes...
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 228 Times
there is no such thing as bike specific grease. That's only marketing. Just fill it with another type of grease, thicker or thinner, with additives or without, whatever..
Quoted: 1562 Post(s)
Liked 1,734 Times
My tube of Phil Wood grease has separated after sitting for less than a year. And I live in a temperate zone here in San Jose, CA. In fact the Phil Wood grease also says it’s made in San Jose, CA on it. Terroir and everything.
Whereas a cheap can of generic grease has sat in my same garage for at least a dozen years and has not separated or changed in any way.
I still like the Phil Wood grease for its light and slick feel but I am not under any illusion that it will outlast generic grease.
Likes For icemilkcoffee:
Me on a grease discussion.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Likes For canopus:
I’ve been using the Park brand PPL-2 bearing grease for a long time. I’m still on my first tub. If my plan to do a bunch of bearing repacking this Winter actually happens, it’s possible that I may finish off the tub. Not so sure that I’ll be paying a premium price for the Park product and may just get some basic waterproof bearing grease from the auto parts store.
Quoted: 231 Post(s)
Liked 10 Times
Ive been through a few tubs of park grease and a few tubes of phil. Never impressed with the phil actually but never had it seperate on me.
I know red and tacky is garbage. Ive had chassis grease tubes leak all over based on that trash despite that being favored by many automotive guys.
I like that a simple question caused one guy to blow his brains out. Thats helpful.
Sounds like next time im at farm and fleet...just grab any tub of cheap stuff then...
Quoted: 2026 Post(s)
Liked 1,096 Times
My tube of Phil Wood grease has separated after sitting for less than a year. And I live in a temperate zone here in San Jose, CA. In fact the Phil Wood grease also says it’s made in San Jose, CA on it......
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 968 Post(s)
Liked 1,631 Times
Likes For zandoval:
Quoted: 1944 Post(s)
Liked 2,164 Times
I basically use Phil’s or Finish Line Teflon depending on purely unscientific and unsupported biases for the application of each.
John
John
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Oil bleed on your workbench is probably irrelevant to how that grease would perform in a bike, as the bearings would just mix the oil back in as soon as you ride again.
Maybe just store the grease differently? Like in a milk jug cut in half?
In general I don’t store POL in a toolbox. I’ve made exceptions for Superlube because it comes in a tube that seals well… but definitely has some separation if left alone for awhile.
Quoted: 839 Post(s)
Liked 1,064 Times
As mentioned above I also just use cheap Marine Grease and it seems many others on this forum do too. I use it on bearings, corrosion protection for screw threads, metal seatposts/frames, clamping surfaces, etc. Also if the grease you have starts to separate you can just stir it up to make it new again so no need to throw it away. Most greases are fine for bike use. Don't get too caught up in the "what's the best" debate. You can do a search for explanations of greases with plenty of headache inducing articles if you really want to get an understanding of what's in different greases and what ingredients work best in different situations.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
We use the Red & Tacky in the grease gun. The1 lb tub lasts about a year
Likes For JoeTBM:
I use Park grease, because my wife got me a tube a few years ago for Christmas. Before that I used marine trailer bearing grease, the red stuff, Lubriplate, it really doesn't matter as long as you use waterproof grease(I learned the hard way).
Bicycle use doesn't stress the grease that much, so almost anything will do. And with the increased use of sealed bearings, there are few things that need grease on a regular basis.
Quoted: 4236 Post(s)
Liked 2,949 Times
Quoted: 6196 Post(s)
Liked 4,811 Times
I wouldn't put anything in it until you know what other grease you might need....often.
Some pawls in freehubs might need a very light grease. But how often are you going to be lubing the pawls in a freehub? I've never had to do that. Not even on freewheels I had for many years.
So save it till you know you have need for another type grease. Then it can also be a spare incase your other breaks.
Since everybody has an A...Hole and an opinion, here is mine. I use Lubriplate EMB synthetic. I bought it at a bearing store next to the refinery where I was employed. At the time I didn't know much about grease and took their word for it. It isn't expensive and works on my hub bearings and on the bearings in my freehub bodies. The EMB stands for electric motor bearing and they turn a little faster than ours and have slightly higher loads.
Lubriplate EMB Grease / 14.5 oz. cartridge (totallybelted.com)
