Small pin holes in frame?
Thread Killer
Quoted: 3149 Post(s)
Liked 1,714 Times
That does seem unusual…
Quoted: 9656 Post(s)
Liked 6,366 Times
Can you stick a needle all the way through, or is it just in the paint?
Likes For Mojo31:
Quoted: 6972 Post(s)
Liked 10,971 Times
I know this is a crazy idea, but: maybe take it back to the shop and ask them?
Likes For Koyote:
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 646 Times
non- branded Frame? use a toothpick to shove as much epoxy as possible into the hole, smooth surface, ride until ... whenever/whatever...
Branded Frame - should be covered by usual Lifetime frame warranty of most bike companies.
Ride On
Yuri
Ride On
Yuri
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I'm not a carbon fiber guy, but I found these:
From a welding/fabrication forum: "Pinholes in vacuum bagged carbon fibre parts are very common."
From German Advanced Composites: "With the standard vacuum resin infusion process the permanent existing vacuum drives the resin out of the laminate into the bleeder fabric and/or resin trap. That leads to voids in the surface caused by pinholes. Pinholes are tiny holes on the surface which are hard to fix and require post treatment, resulting in additional labor costs. This is particularly evident with visible carbon fiber parts. These parts are just clear coated and pinholes affect their post treatment costs tremendously."
Quoted: 18378 Post(s)
Liked 4,512 Times
I wonder if those holes naturally get filled with surface prep. Some of the vintage frames have a layer under the upper finish that is really thick.
Doesn't seem right to me either. I'd take it back to the shop you bought it from. Maybe call the frame manufacturer and ask them. I can't think of one reason a hole should be on the top side of any tube. Steel frames often have weep holes but I don't think carbon do.
Guest
Liked 3,270 Times
On the alu frame, there's big holes inside where the chain and seat stays and top tube meet the seat tube and same goes to the head tube and BB as well. The holes are as big as the diameter of the chain and seat stays and the top tube.
The "nail holes" look and placed exactly the same spots as on a steel frame but I doubt were made for expanding gas because there's big holes in the seat tube and head tube already where these tubes meet.
Likes For couldwheels:
Are you saying it's impossible for water or mud to get inside a CF frame, dispensing the need for weep holes? I doubt retaining water is good, even for CF frames.
You can ofc, remove the seatpost and drain it upside down but not sure if that's a good thing to do quite often especially if you ride in the rain or wet conditions often.
couldwheels,
Maybe you didn't quite understand what I said:
It was open to correction. Where's the problem?
Steel frames often have weep holes but I don't think carbon do"
Guest
Liked 3,270 Times
I once poured nearly a cup of water out of the seattube of a steel bike after I got caught in a downpour; there's no way it was going to magically escape or evaporate through the tiny holes in the stays.
I put some water drops on the hole and the hole remained filled which make me believe it's just paint deep.
Either way Giant has a lifetime frame warranty so il just ride until it becomes an issue if at all!
Although it's hot where I live 90 to 100 F common so water evaporates eventually.
Not sure how you deal with such issues in carbon bike, is the frame completely watertight? In that case, you don't need to do anything but I doubt it is watertight.
Guest
Liked 3,270 Times
Water in the frame can get to the BB. Although BB's are supposed to be sealed and waterproof, the metal parts of BB probably won't tolerate water exposure for long periods and water may eventually get through the seals.
Ofc, you can remove the seatpost, drain the water. But the inside won't dry out completely for at least a few days without the seatpost and if you put the seat post back and there's still moisture inside, that moisture would stay there indefinitely and may affect the BB and headset components with high humidity inside the frame. At least if it had a hole, you can put the seatpost back after you drain the frame, use the bike the next day and the inside will dry out eventually. At least that is my experience with aluminum frame with drain holes. I often ride in the rain, water gets inside the frame, I drain it. The one time I had to tighten the BB after getting lose when I struck a kerb with the crank, I also removed the BB for inspection, it's bone dry inside the frame. Drain holes seem to do their job pretty well.
Quoted: 1461 Post(s)
Liked 1,486 Times
On the topic of drain holes, my carbon Zipp 303 S wheels have tiny drain holes in the sides of the rims. So, it's definitely a "thing" on some carbon products.
No idea on frames - also I don't think I've ever noticed water being trapped inside any of my bike frames (steel, aluminum or carbon), so I presume there's a hole somewhere that lets it evaporate/weep out?
Liked 6,366 Times
If you get resistance a few mills down, My guess is that it might just be a paint defect and not a carbon layup defect. Pinholes can form in paint coatings due to entrapped air, solvents, or other materials escaping during the curing process.
If it’s just a paint pinhole, it will likely just be cosmetic.
Likes For Mojo31:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Likes For Kapusta:
