Replacement for Shimano ST-M050
Rebuilding an older Schwinn Mountain Bike, was messing with these Shimano ST-M050 shifters for hours. Now that I have them freed up I find the pressed in nut on the right shifter is broken, not permitting reliable down shifting. Can anyone recommend a replacement? Like to keep the original look as much as possible. Would a Shimano ST-EF51 work? I saw something on Amazon stating that they won't work with with cantilever brakes which is the brake system I have. Thanks for your recommendations.
Really Old Senior Member
They will work IF you get the "4 finger" version.
They will have a 4 in the suffix.
You move the red plastic plug. V Brake position shown.
EF-65's are a bit "better"
It's probably more like-
What can you find in the 4 finger version w/ the correct number of speeds?
Either will work fine.
Ok. EF-65s I'll keep my eyes open. Meanwhile I got the M050 working but of course for how long. I was able to put the pressed nut back in and using a punch peen it into place. Seems to be holding. But if if find a reasonably priced replacement it is probably best in the long run. Finding the EF-51 with the cantilever option so far has been a bit of a challenge.
Thanks for all your help. Tried to post pictures but I guess I need 10 more posts before I'm allowed to upload a picture. If you interesed enough maybe I can send them directly - Thanks for your advice.
Quoted: 4172 Post(s)
Liked 3,792 Times
nb2716- I don't know where you live but here in the USA we have a whole sale supplier to many of your LBSs in Quality Bicycle Products. They show current availability of the ST-EF65 in 3x7,8,9 and with either canti or linear brake cable pulls. Part #s LD7572/LD7582/LD7588. Of course only a bonified bike shop can order from them. Andy
AndrewRStewart
AndrewRStewart
AndrewRStewart - We have an Eddy's here in Cleveland. If I can't find a decent pair in our Ohio City Bike Coop I'll stop in at Eddy's. Thanks for the part numbers that will help.
Liked 3,792 Times
nb2716- I use to own Bike One on Coventry Rd. My wife worked at the CMA in Uni Square. I don't think any of my old employees still works for Eddies, Jeff Joseph or John Mulryan, but if so tell them hi from me. Good luck hunting the used bins Andy
AndrewRStewart
AndrewRStewart
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 94 Post(s)
Liked 71 Times
V-brakes are pretty inexpensive and work better than canti's. Why not upgrade and expand your options?
Just might do that. The bike won't be a rider for me, probably donate it to the local coop. Can't really justify cost and performance wise but I do like to keep things original if I can. I'm going junk pile diving in the local places next couple of weeks. If nothing turns up I'm going to look into upgrading as you're right, it will work better and in the long run be cheaper. Thanks for the reply.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), Yess World Cup race BMX, Redline Proline Pro24 race BMX Cruiser
Quoted: 343 Post(s)
Liked 181 Times
I question that the v-brakes are easier to set up - I almost always mess with them longer and more often than my canti's, and I prefer the braking of the cantilever brakes as well.
