Hints and tricks thread
#151
A surgical forcep, applied to the free end of a brake cable, will hold it in position on the caliper until it can be tightened in place.
#152
You Know!? For Kids!
When replacing the rim tape, use a wooden golf tee to hold the tape in place. Line the hole in the rim tape up with the valve stem hole in the rim. Insert a wooden golf into the valve stem hole and press it firmly in place. This will keep the tape alinged with valve stem hole and you pull the tape firm.
After you are done, you can use the rounded end of the golf tee to rub the tape into place and make sure it not loose anywhere.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
#153
Cert. Mechanic, Consultnt
Bikes: Norco VFR 5, Ibis Ripley (Castellano Fango), Gary Fisher SuperCaliber, Trek 6700, 1980's Haro Group 1 RS-1!
Dudes, you're complicating things!
Use your finger for the rimtape!
Surgical forceps??! how mch are those?? and where does everybody get them?? WHAT?!
this forum is to make things EASIER not harder! The latter is what you're suggesting!
So please, simplify.
#154
I did simplify for me. If I try to hold tape in place with a finger, I often get back to the valve stem hole and find the tape has slipped maybe an 1/8" or so. I do not like this. I have golf tees in the garage, right by my work bench, so it is easy to grab one, shove it in the hole to keep tape aligned and have both hands free to do a quality tape job.
#155
A 30-sec internet search turned up a good pair for $12.50...bet you could turn up a better deal if you did a little searching and/or lived near a uni. They're so much better than "third-hand" brake tools that I've never priced (or owned) those, but I'll bet they're competitive.
The type needed resembles a locking pair of scissors with a "needle-nose-piers" gripper instead of twin blades. Basically, get the brakes (sidepulls is what comes to mind) to the exact place you want them, then squeeze the forceps onto the cable--it'll hold the desired setting as long as needed until you get the bolt tight. Same principle as a cable stop, but installs in 5% of the time.
IIRC, third-hand tools lock the brakes against the rims, so you have an additional adjustment to make...plus, locked brakes give no clue as to centering! (Plus, I'd imagine it could be pressed into use on a derailleur, as opposed to a typical brake tool.)
Obv. not a "must-have," but if you happen to be able to get a pair easy (maybe you're pre-med or somethin'), they're the best tool for the job.
#156
Peace and bicycle grease!
Bikes: '85 Schwinn Voyageur, Ross Mt Hood, Rossin, the Nugget
You've spent the best part of an hour trying to set the brakepads of your V-brakes or Cantilevers, but no matter what you do, either the left or the right pad touches the rim while no pressure is applied to the brake lever. You are silently going crazy.
Well, the rim might be out of true! If the only thing that fixes the problem is widening the brakepads, then that's a clear indication that this is indeed the case. Of course, if you widen the brakepads too much, you will have no braking power, so the only medicine is to true the wheel.
#157
Video pls.!
Yo, thnks for ur patience and not retaliating back! I was alil annoyed initially but, now i see some potential. BUT, please, send me/us a GOOD VIDEO of how to use these forceps pls.! This could save ppl time n trouble and/or merely be a refreshg new way to do things!
Thnks!
Send video to dextao@gmail.com
Thnks!
#158
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
The nice thing about a third hand tensioner is that it pulls the cable taught as it ratchets to hold it in place. I've never had one that was really good, but it still makes brake work much easier. Foreceps are great for the holding, but not the tensioning.
On the other hand, I usually install with the brake pads right up against the rims. I find that one or two good squeezes on the lever backs them off enough without adjusting as long as the rims are true.
#159
* when you get a flat and have no pump, patches or new tubes. you can take your tire off and pack grass or leaves where your tube was then put your tire on and carefully ride to the nearest place to fix your tube. you have to be extra carefull to not damage your rim, but it will get you out of a jam.
#160
punk kid.
Bikes: 1970's Nishiki, Late 70's Centurion Super Elite
when installing pedals, hold the rear wheel with your hand to apply easy, maximum torque! (does not work for removal unless you have fixed gear)
tire wont seat correctly on your old rims? spray some pledge or simple green along the bead!
#161
Location: Rancho Cucamonga [Home]/San Luis Obispo [School], CA
Bikes: 1974 Raleigh Grand Prix
Wasn't even late for class.
#162
Mechanic, Wheel Builder
Bikes: At least 35 bikes and most are antiques
Building/converting a singlespeed, but have vertical dropouts and no chain tensioner? Use an old rear derailer/derailleur, it'll work great! Not only does it have really good springs and pulleys (generally much better than separately buyable chain tensioners) and is MUCH cheaper than a separate chain tensioner, even if bought new, but a derailer has the most comfortable way of adjusting the chainline - just adjust the H limit screw!
The only drawback is that a derailer is usually heavier than a chain tensioner, but you can always get rid or a few little parts on the derailer, to make it a bit lighter.
#163
I hope the following is an okay tip, because I'm still an amateur, and I only just picked it up from a 9-year-old! But it worked for me this morning.
When installing the back wheel of a singlespeed, where the chain tension is adjusted only by the placement of the axle on the dropouts (such as a kids coaster-brake bike), you can use any blunt tool as a lever between the bottom bracket (as the fulcrum) and the wheel so that you can keep the wheel pushed out with one hand while you ratchet the axle nuts with the other.
Another newbie (and I mean it) tip for working on kids' bikes that I just figured out myself last night: If you turn the bike upside down to work on it and the back wheel is resting on the floor so that you can't work with it, turn the bike back upright and raise the seat so that, when upside down, the seat rests on the floor instead, leaving the back wheel free to turn.
#164
punk kid.
anyone tried filing their axles to make a fixed gear with vertical dropouts?
other tip for setting brakes. assuming you have something like a third hand to hold the calipers taught. tighten screw to hold cable just a little little bit. then squeeze brake handle to desired pull range when closed. then tighten. brakes set in 30 seconds.
#165
Dirt Bomb
Quoted: 5464 Post(s)
Liked 288 Times
Powdered mica is the best lube to use when mounting tires on rims.
You can order it from bullet reloading supply houses like MidwayUSA.
Likes For sknhgy:
#166
Those plastic squeeze clamps work as a great third hand tool, use a fairly large one to clear wheel, fenders, etc. They ratchet so you can clamp the brakes shut or leave them where you want them to be when done.
#167
Brass air fittings
Now that is a lot of brass air fittings https://www.liangdianup.com/subpages/airfitting_1.htm there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo bu
#168
Bikes: '94 DB Apex, '07 SBC Allez Elite
Forceps guy needs one of these...
the fourth hand tool pulls and locks in one motion, but the locking feature is actually kind of annoying to me and i'm faster without the thing anyhow...
#169
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Forceps are the best way to get your brakes just...right.
#170
Lol, correct! Pops used to sell surgical equipment, can't believe i missed that.
#171
To tighten the chain on the rear wheel of a fixed gear or BMX, loosen the axle nut on the non-gear side and grab the wheel near the bottom bracket and pull so the nut move toward the rear of the bike. With your other hand tighten the nut pretty snug. Then loosen the gear side, grab the wheel in the same place, and push the wheel toward the gear side. Tighten the gear-side axle nut pretty snug. At this point the chain will likely have proper tension, but the wheel alignment will be off, so loosen the non-gear side to adjust, then do a final tightening.
Now before you do this, pedal a few revolutions with the bike upside down or in a stand and see if the chain is sometimes looser and then tighter. Then, to make up for possible out-of-round freewheels, axles, crank spindles, and chainrings, pedal until the chain seems to be at its tightest point, and then proceed to the tightening procedure above. Otherwise the "loose" pedaling phase will be tight and the "tight" phase will be overtight. Better a chain too loose than too tight.
#172
punk kid.
to fix an off center chainwheel pedal cranks to tightest position where the chain is very tight, then take 1 hammer and strike front of chainwheel. pretty hard if you like.
#173
Bicycle Student
Bikes: 2008 Surly Long Haul Trucker
If you ever find yourself in position without a pump with a presta end or an adapter find a department store pump and unscrew the valve at the end and insert the presta valve into the end of the hose. I have done this twice and it worked great. I was able to get my tire to the 80 psi of 85 it called for.
The presta valve pits perfectly into the diameter of the hose. I have seen it used on two different pumps. Of course not all hoses will be the same size inside.
#174
Lives2ride
Bikes: Surly Crosscheck
Magnetic Steel Tray
Everything - including bearings - sticks to them without fail.
(Harbor Freight sells them cheap, $2-$5 - https://www.harborfreight.com/cpi/cta...emnumber=37033)
#175
Free wheel
Bikes: 1978 Schwinn Traveller III, 1985 Nishiki Prestige, 1986 Raleigh Technium 480
Cleaning out seat posts and fork stems
Double a piece of heavy wire over and hammer the loop on the end closed so that the two wires lay parallel to each other. Cut the loose ends flush and chuck the ends into a drill. Take a small bit of cloth and string it between the wires at the end where the bend is. Soak the rag in WD 40 or some other degreaser and place the rag into the tube. Use the drill to spin the rag and clean out the old grease and rust.
You can also chuck up a strip of emery cloth or sandpaper in the wire mandrel to clean out badly rusted tubes (just be sure the dust isn't dumping down the tube into a closed BB and contaminating the bearings).
Ganzen
Ganzen
