Travel case for track bike?
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Club mate had a Trico Iron case I picked up for $75. Even if I don't use it figured I couldn't go wrong at that price. It definitely is sturdy... and I think with proper padding/taping everything so it doesn't move, it'd be pretty hard for TSA to put it back in any way but correctly. A friend has the Biknd Helium he said I could borrow as well. It looks great but I see a good number of folk have had trouble with the air pockets deflating.
Speaking of Biknd, the Oxygen wheel bag looks like a good setup to take the Discs in since they are separate from each other. It seems like that or the Triall3 Wheel safe pro are the options that would fit... Anyone got thoughts on that? (I guess the Oxygen has the same concern as the Helium)
1 note: Make sure to use spacers for both the fork and rear track ends to keep them from getting smushed. A front can be obtained from any bike shop for free. They come with new bikes before they build them. Most shops just chuck them into the trash. The rear won't work on your track bike. The rear is 130mm. Your track ends are 120mm. If you jam the 130mm into 120mm track ends, you are stretching it 10mm wider than it's designed to sit. So, you will have to fashion one yourself. When I bought my 2 Tiemeyers, Mr. Tiemeyer simply whittled them out of a wooden dowel.
Thanks, good to hear. It seems like a tough box to screw up so long is it isn't loaded down with tons of free moving crap
I was thinking just a threaded rod, 4 nuts and some washers would do a fair job.
(Good time to mention that I find it odd that the Track Elite has carbon dropouts in the fork. Seems like slightly silly bling...)
Quoted: 43 Post(s)
AmahlAmahlAmahl
Track Cycling: Velodrome Racing and Training Area
7
04-22-19 08:11 PM
carleton
5
03-20-19 09:11 AM
hadaiwai
Singlespeed & Fixed Gear
27
06-03-13 08:58 AM
