Good, light, silver 700c rim?
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I like CR18's too, but I don't think they are in the same league as the TB14, Brevet, or A23 when it comes to fit and finish. The VO PBP is another one I would consider.
By the way, I just use plain old zefal cloth rim tape on my A23's. I never thought much about it, but I guess it is a little harder than normal to get the tire on.
I have the following rims;
Sun CR18 are strong, economical and ideal for C&V sports/touring bikes. These are not suited for racing models due to slightly excessive weight and a bulky appearance.
Velocity A23 are stiff, moderately aerodynamic, wide and lightweight. The A23 is the best performance rim due to its wider design, superior stiffness and lightweight performance. I would avoid using these on older Reynolds 531 bikes, the aerodynamic shape clashes with older bikes, IMO.
H + Sons TB14 is lightweight, wide, and beautifully finished. It's not as stiff or as aerodynamic as the A23 but it looks perfectly correct on a steel bike.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
In my experience, if you try to use cloth tape with the tubeless version they won't just be "a little harder than normal" to get tires mounted. They're very nearly impossible. However, if you use tubeless tape or kapton tape, as rccardr suggests, it's no problem.
This issue isn't specific to A23's, of course. Most tubeless compatible rims have this problem/design feature.
BTW, to address the original question, I really like A23s. I think I've got four wheel sets with them and another pair in the garage waiting to be built. I've never had an issue with the brake track. On the other hand, the profile isn't as classic looking as the TB14.
My Bikes
My Bikes
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I ran TB14s with 700x38s for two years on my gravel bike with zero issues. Only reason I replaced them is because the brake track was finally worn -- which was due to 14,000+ miles of gravel and not any fault of the rim.
No longer active
Quoted: 89 Post(s)
Liked 6 Times
No, they're not -- they don't share anything at all in design as a matter of fact. The Synergy is (was) a box profile, eyeletted rim, the A23 is a semi aero non-eyeletted rim. Apples and oranges. Both were available in Polished and a variety of other finishes, as our most of our rims.
Granted, the Atlas isn't exactly the Synergy (it IS stronger, and a tad more wide), but it's outwardly very similar; certainly shinier.
My bad. Everyone, please Ignore anything I've posted in this thread, as it was stated based on a mistake.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I use CR18's as a full-time rim on one of my bikes, and I have another set that I'm building up this winter for a second bike. They're workhorses. I'd weigh them to let you know how much they actually weigh vs. the spec sheet, but I don't care about weight so I don't own a scale.
Hah, I went down the same rabbit hole trying to determine the same criteria last week. Landed on Pacenti Brevet's being the best option for me, with TB14's a close second.
I read elsewhere on the forums that the width of the brake track on the Velocity A23's is quite narrow. In my situation, I'm running canti's on a frame whose posts were set for 27 1-1/4 rims, so I'm not going to gamble on narrow braking surfaces.
FWIW I put in quite a few miles on my A23 wheels on pretty rough gravel and singletrack with full packs last summer. It was kind of accidental because shipment of heavier rims was delayed, but they held up fine. They don't look particularly retro though.
I wonder if Jan Heine & co will ever start pushing fat sew ups? That is maybe the next frontier.
Quoted: 500 Post(s)
Liked 466 Times
I’ve never used Sun CR18 rims, but seem to recall that they were a repeat offender in the “difficult to remove a tire” thread, although they are certainly popular around C&V. My tb14’s are OK with Compass or Grand Bois tires, but not quite as easy as any of the Mavics in that regard
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,793 Times
Order made, TB14's ftw!
Good combination of weight, looks, and strength.
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 375 Post(s)
Liked 1,081 Times
I was sitting in front of the fireplace fondling my recently arrived stash of H+ TB14: s. Picked up the phone and looked a bit at BF. Peculiar coincidence - this thread popping up today.
These are not going to be built for a while. I bought them just because I am fed up with pursuing vintage NOS rims at ridiculous prices. I have a nice selection of NOS rims for my more serious/period projects/restorations but I decided to quit hunting old rims for the "fun-projects". The projects where nothing is original or "needs" to be period correct. I looked into it and found the TB14 a good substitute and readily available. As someone has already mentioned they do not fool anyone who knows but they will look retro enough to not shame a vintage bike.
ambulatory senior
Liked 3,661 Times
I’ve never used Sun CR18 rims, but seem to recall that they were a repeat offender in the “difficult to remove a tire” thread, although they are certainly popular around C&V. My tb14’s are OK in that regard with Compass or Grand Bois tires, but not quite as easy as any of the Mavics in that regard
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
H+Son TB14 is 23mm wide, available in polished silver, and just under 500g: https://www.retro-gression.com/products/h-son-tb14-rim
Darn it, Sugar Wheel Works is only a couple blocks from my work. Why haven't I stopped in?
Jeff Wills
Jeff Wills
52psi
Quoted: 790 Post(s)
Liked 802 Times
Polished TB-14s were the final ingredient on my Paramount a year or so ago. The smoothly rounded profile complements the Campy hi-flange hubs perfectly, the ride is excellent and I just plain love 'em. They'll land on the Volare too, when the time comes, and I don't think I'll bother checking what else is out there.
Jedi Master
I just assumed it was my superior technique and amazing hand strength. I probably have the older version. I bought them used so I don't really know for sure.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
The M13 probably isn't getting much mention in this thread since the OP wants something that will support 35-38mm tires well. I've heard they're good otherwise.
I have M13's on my Peugeot. Surprisingly tough rims. I probably put about 5-6000 miles on them including some off road, and they're still dead true. I bought them because it was cheap and expedient, and ended up pleasantly surprised.
Yep, M13 is a narrower 20mm rim. Better for 25 or 28 tire. 32 is as wide as I would go. Basically it's much like an improved version of the old Rigida 1320. Rigida was more or less the standard clincher training rim at one time, and it will look just right on 70s bikes -- as long as you peel off the stickers.
I have had several CR18s and M13-IIs, and if you're going in this direction, you should choose based on tire size. I agree with Salamandrine above that somewhere around 28-32 mm is the tire size overlap for these models.
I always thought they were both excellent for the price, without being too lightweight or flashy, which is the parameter space where I make most of my life decisions.
Liked 2,568 Times
Conceptually, I think there's a lot in common between the Pacenti Brevet and Sun M13-II. Both are double-walled box-section rims but with single eyelets, available in a shiny finish. Chief differences are that the Brevet is wider and clear anodized rather than being merely polished. (Oh, and it's tubeless-ready, but many of us in C&V probably aren't going to exercise that anytime soon. )
Liked 5,793 Times
Jedi Master
ambulatory senior
Liked 3,661 Times
wow, i use those a lot. they dont feel too heavy to me but then again i am lacing the front ones to dynamo hubs. do you know what the actual weights are on the m13s?
Bikes: Peugeot PR-10, Peugeot UO-8, Boeris racing bike, AMF Roadmaster Renegade, Gitane Gypsy Sport, various Schwinn muscle bikes, Schwinn Super Sport, Panasonic DX-4000, Palo Alto Campy equipped bike
Quoted: 48 Post(s)
Liked 7 Times
I have M13II's on one of my vintage racing bikes, and they are solid rims but narrow (I wouldn't put wider than a 25mm tires on them). The CR-18 is a wider and heavier version of the M13II rim - I built a set of these up for someone's vintage mountain bike and they were okay to work with. The thing I hate about these two rims is the two sharp angles instead of smooth curves on the transition from the sidewalls to the surface where the spokes go thru. I can't for the life of me figure why they designed these rims this way.
Weinmann AS23X rims are the only other traditional looking rims other than the ones others have mentioned. They are dirt cheap and are drilled for Schrader tubes so they don't have the snob appeal of the H Plus Son or VO rims, but they can take a wide range of tire sizes since they are not really narrow or wide. They are also very light because they are single layer rims and don't have ferrules (you have to use washers under the nipples). I have these rims on my UO-8 because I didn't want to spend a lot for rims for a lower cost bike like this, and I've ridden over many rough railroad tracks and bricks roads with them and never had a problem. I don't like the dull aluminum finish on them though, but I guess if I really went nuts fixing up this bike I could strip the anodizing off the rims and polish them.
Jedi Master
Quoted: 384 Post(s)
Liked 6 Times
(In any case, they're nothing like the old Ambrosio 19 Elites. The Gold Standard for "difficult to remove a tire." I finally decided I will never use a plastic lever on one of those again.)
Liked 2,568 Times
There's just no way that a wide triple-box rim with thick walls everywhere can possibly weigh 460g in 700C. And be made of metal.
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
Another rim worth mentioning is the Mavic Open Elite. I had a set sitting on my front porch for about fifty bucks. I think Ben's Cycle has some. They are a triple box like the Sun CR18 but 20mm external width. They come in at 490 grams in 32h.
