Chain slipping on e-bike
I have accustom build e-bike with a 8 speed hub drive so a single cog on the rear wheel with chain tensioner. When I put it under load for example tacking off from a stop sign the chain will slip. The chain is not stretched and the teeth on both front and rear chain rings are fine. I do not know how to fix this. Maybe a different chain?. Another thought is setting up a belt drive system but do not have a clue what is involved? Any help appreciated
Quoted: 878 Post(s)
Liked 813 Times
Stronger spring in the tension system might alleviate the problem and a narrow/wide chainring could help. Doubt that a belt will solve the problem and belt-drive requires that the frame has a "break" in order to install as well as other challenges.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I don't understand how that will slip. Is it slipping at the rear cog? How many teeth are in the cog? Does the chain really match the drive train? I would take it to a LBS. I'll put 1000w through my legs into a single speed drive train (49x14) and never slip. The only way I can see this being a problem is if there is a problem with your chain compatibility to the cog (unless you have some kind of tension issue).
I have a belt drive on one of my bikes (not an e-bike). The belt slips once in a while under heavy acceleration, so I don't think that would solve your problem.
Thanks for that I believe the chain tension er is fine as it sits at full tension.I think I need to go to LBS and see what they think
Randomhead
Liked 3,687 Times
chain line maybe? Otherwise it's either tension or wear
it occurs to me that you could be using a 1/8" chain on a 3/32" component, but I feel like that should be ok.
