Recommend a good paint for plastics
Quoted: 887 Post(s)
Liked 335 Times
I am currently rehabbing a Nishiki Sport mixte. I have done the due diligence on bearings, cleaned it up, replaced the drops with upright bars, and added new brake and shifter cables.
The bike screams for fenders and a rack. I have a Pletscher rear rack that will work, but the fenders on hand are black. The bike is a dark burgundy with silver highlights, so I thought the fenders should be silver as well.
I have used Testors spray paint as a kid, and have seen plastic spray paint at Lowe's and Home Depot. I figure this is a one shot deal, so I don't want to screw it up. I plan to leave the underside of the fenders black, so I am olny painting the tops.
Suggestions?
Suggestions?
Quoted: 1641 Post(s)
Liked 831 Times
IIRC, Rustoleum has a line of spray can paints made for plastic. Supposed to work well on things like plastic outdoor patio furniture.
Not sure what color choices they have for the paint, but surely all primary colors are covered.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
You can use almost anything except latex or lacquer paint on plastic. The latex won't stick, and the lacquer can attack the plastic. If the rattle can label doesn't specify if it's lacquer or enamel, then look on the warning label for keytones. Stay away from paints with those.
Surface prep is at least as important as what paint you use. Wipe the parts down with mineral spirits, then rubbing alcohol. Now sand them with 800 grit wet-or-dry paper, then repeat with the mineral spirits then alcohol. The paper will work better if soaked in warm water with a bit of Dawn dish soap added.
Now follow the directions on the rattle can for application.
Quoted: 1627 Post(s)
Liked 630 Times
In spades. Obviously, the hard surface should be cleaned, Then scuff-sanded (anywhere from 400 to 800 grit) to give a fine texture for the paint to adhere to. I've had good luck with Rustoleum Vinyl and plastic paint, but I'm not sure it comes in silver. I'd paint those fenders a shade that matches or complements the frame. Silver is grey and grey is boring. Chrome is nice, but there are no 'chrome' paints that are any good.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Also, there are silver colored plastic fenders that you can buy. Nashbar sometimes has Zefal Paragon fenders in silver for $25 and they're pretty good.
Aluminum fenders are also quite nice.
Death fork? Naaaah!!
Planet Bike Cascadias can be had in silver.
Top
Top
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
+1 for the Rustoleum plastic specific paints.
I've used it to re-paint some electric ride-on firetrucks for my kids that had become horribly sun-bleached. Some 1/2 decent prep to clean up the surface and it turns out pretty well. Also holds up fairly well to normal use.
Quoted: 887 Post(s)
Liked 335 Times
OK, the consensus seems to favor Rustoleum plastic paint. I am not buying fenders, since I have a pair of black Esge fenders that a neighbor gave me, and I will most likely sell the bike in the spring.
I'll start shopping now. Thanks all.
