Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
I crashed (road rash question)
Old 08-23-15, 09:15 PM
  #151
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
Liked 4 Times in 4 Posts
grab a boom handle to bite down on and htfu.
Ygduf is offline
Old 08-23-15, 09:21 PM
  #152
spdntrxi
Bikes: not enough
Quoted: 189 Post(s)
Liked 86 Times in 52 Posts
^ that's what I use on paper cuts
spdntrxi is offline
Old 08-26-15, 10:39 AM
  #153
globecanvas
Ninny
Quoted: 686 Post(s)
Originally Posted by HMF
Don't bother using the Tegaderm patches if the road rash area you're trying to cover is larger than the patch itself. The Tegaderm needs probably one inch of undamaged skin on all sides in order to stick for more than 24 hours. If you apply a Tegaderm patch to a spot of road rash that's larger than the patch itself, you're just wasting your money. The ooze will make it slide off by the next day.
+1 to patchwork tegaderm not being useful. For days 1-3 I used 5 of the 2.5x2.5 tegaderm bandages to cover one area, but the tegaderm really needs to adhere to undamaged skin on at least 3 sides or it just slides all over the place. It probably ended up only covering half of the road rash at any given time, so kind of a waste of money. Finally today (day 4) I got the big tegaderm bandages and I can cover the area with 2 of the 4x4.75 bandages with undamaged skin contact on 3 sides of each, and it is staying in place.
globecanvas is offline
Old 04-10-16, 09:42 AM
  #154
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Quoted: 967 Post(s)
anyone else ever used colloidal silver gels?
I got some after my neighbor recommended it to me for the puncture wound, but honestly I feel like my road rash healed more yesterday under the silver solution than it had in the previous 3-4 days with careful tegaderming.
Ygduf is offline
Old 04-17-16, 11:38 AM
  #155
burger0014
Bikes: Tarmac SL4
@Ygduf where did you get this giant roll of tegaderm, I can't seem to stop crashing this year.
burger0014 is offline
Old 04-17-16, 12:02 PM
  #156
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Quoted: 967 Post(s)
https://www.amazon.com/Smith-Nephew-5...ustomerReviews
that's the tegaderm. Let me tell you though, after my last crash my neighbor recommended to me silver colloid gel. I looked it up an it seemed sort of homeopathic or something, but I gave it a shot and I swear to god it's better than tegaderm. Put the colloid gel on, it gums up but creates a seal. Then slap gauze over that (just to keep the gel-layer clean). My knee made as much progress in 1 day with the silver colloid as it did with 3 days of tegaderm with significantly less fuss.
I was taking bandages off to ride and the knee was fine. The gel collects grime but soap/water and it comes right off in the shower. Get out, dab dry and re-apply.
I feel weird because it isn't popular and doesn't seem to be well known so it feels like I'm advocating for powerbalance or copperfit or some sham product, but spend the $10 for 2 tubes and give it a shot.
Ygduf is offline
Old 04-17-16, 12:26 PM
  #157
burger0014
Bikes: Tarmac SL4
thanks, I'll try anything, I hate the oozing
Old 07-24-16, 07:23 AM
  #158
globecanvas
Ninny
Quoted: 686 Post(s)
Another tip for covering large areas or difficult to wrap areas (like high on the hip) without going the mummy/wrap/miles of tape route, which always comes apart anyway. I got a couple pair of panty hose from the dollar store and cut them apart so I had one leg plus waistband, and another leg which I used as an arm sleeve. It worked great for holding on the gauze while the wound was still exuding and continues to work great for covering the tegaderm to keep it from rubbing off while exercising or sleeping. Also it nicely shapes and tones the legs
Old 09-05-16, 01:15 PM
  #159
king_boru
The Moose
king_boru's Avatar
Bikes: 2016 Giant Roam 2, 2004 Norco Torrent, 1969 Raleigh Grand Prix
Quoted: 108 Post(s)
Liked 3 Times in 2 Posts
I swear by vinegar. Soak a clean cloth, bite down on thick piece of caramel, breathe deeply and apply vinegar cloth. It will clean that rash up pronto. I've done it lots. Even applied it to my face after making out with the road for a few tens of meters.
Hurts worse than the crash though.
king_boru is offline
Old 01-18-17, 12:22 PM
  #160
dcwldct
Quoted: 17 Post(s)
This man^^ has HTFUd
dcwldct is offline
Old 06-28-17, 05:56 PM
  #161
krumvis
No, it doesn't work like that.
krumvis is offline
Old 07-20-17, 08:52 AM
  #162
TimmyT
Keener splendor
TimmyT's Avatar
Bikes: Black Mountain Cycles Road and canti MX, Cannondale CAAD12, Bob Jackson Vigorelli
Quoted: 297 Post(s)
Liked 80 Times in 51 Posts
Vinegar is antibacterial and antiviral. You can do that, but rubbing alcohol (isopropyl or ethanol) will do the same thing.
1. Clean out the gunk and grit.
2. Clean it with alcohol (or vinegar, if you like)
3. After that, clean it with betadine. I use cotton pads soaked in betadine.
4. After that, put a salve on it, such as an antibacterial ointment ... something from the neosporin/bacitracin shelf in the drug store.
5. Finally, cover with tegaderms or non-stick pads.
Change the dressings 1x or 2x daily.
TimmyT is offline
Old 07-20-17, 10:43 AM
  #163
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Quoted: 967 Post(s)
again, silver colloidal is the bomb.
if you want pain, go with new-skin spray. You'll get some relief when you pass out from the pain. Best applied while over a padded surface.
Ygduf is offline
Old 07-24-17, 04:24 PM
  #164
trainsktg
trainsktg's Avatar
Quoted: 51 Post(s)
Liked 22 Times in 13 Posts
Originally Posted by JPradun
I'm a pro at this, unfortunately. Here's what you should do after cleaning it up:
Buy these (or the generic version) at Target, Walgreens, Walmart, etc:
https://www.walgreens.com/store/produ...&id=prod727947
Buy a tub of vasoline (it's cheaper than Neosporin)
Smear the vasoline over the whole bandage, then stick the bandage to your wound. Tape it up afterward. Even non-stick bandages will stick, so the vasoline prevents this. Also, keeping it moist means it heals faster and with less scarring.
It should only need to be changed 1-2x/day. Do this for about 10-14 days and it should be good enough to remove.
This is pretty much in concept what I did when I rashed my whole right shin from ankle to knee, but I went a bit cruder.... I vasolined the the whole area, applied a couple layers of folded wet paper towel, and covered with duct tape, with the edges attached to good skin. It was pretty much healed within two weeks and I didn't even get any pink scarring.
Keith
trainsktg is offline
Old 08-08-17, 02:06 PM
  #165
TimmyT
Keener splendor
TimmyT's Avatar
Quoted: 297 Post(s)
Keith
Duct tape is not hypoallergenic, and I've developed contact dermatitis using it on skin.
YMMV.
TimmyT is offline
Old 08-16-17, 01:23 AM
  #166
mattm
**** that
mattm's Avatar
Quoted: 1099 Post(s)
Liked 104 Times in 30 Posts
I feel like this thread should be in the 41.
cat 1.
my race videos
mattm is offline
Old 08-16-17, 10:56 AM
  #167
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Quoted: 967 Post(s)
silver colloidal gel!
Ygduf is offline
Old 08-16-17, 02:20 PM
  #168
rideaz
rideaz's Avatar
Bikes: Giant TCR, Giant Anthem, Felt CX
Quoted: 65 Post(s)
This is what happens when they patch you up when you crash mid ride. Gauze and electrical tape: do not recommend because after the adrenaline wears off, you have to peel it off
rideaz is offline
Old 08-24-17, 10:10 AM
  #169
dz_nuzz
Rides too much bike
dz_nuzz's Avatar
Quoted: 232 Post(s)
Oh man, I made that mistake once where you use gauze on open wounds....that is one of the most unpleasant experiences in the world. I feel for ya @rideaz !
dz_nuzz is offline
Old 08-24-17, 10:31 AM
  #170
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Quoted: 967 Post(s)
just wear the gauze into the shower and let it soak a bit. the only times I've had gauze on fresh road rash was from race medics applying it, so I needed to do a deeper clean anyway.
Ygduf is offline
Old 09-13-17, 10:16 AM
  #171
mecheng
Captain Slow
mecheng's Avatar
Just wanted to give a thumbs up to Ygduf and Silver colloidal gel for wound treatment. I have/had a deep open wound (through the skin, down to the muscle) from sliding on pavement, and it kept on bleeding with Tegaderm. After one night with the silver gel, the bleeding pretty much stopped (knock on wood). If you're skeptical, for $10 it's worth a try. Cheaper than a pack of Tegaderms, anyway.
mecheng is offline
Old 11-09-17, 09:44 PM
  #172
scheibo
once a runner
scheibo's Avatar
Bikes: n+1
Quoted: 270 Post(s)
so... i crashed again (5th time this year, 3rd 'serious' crash). while i didn't learn from my past mistakes about not riding on bad roads, i did go see the doctor right away this time (as opposed to waiting two weeks until i was infected). one thing im having trouble with is that this doctor wants to keep the wound dry vs. last time for almost identical injuries (like scary how similar the wounds look) where the wound care specialist i ended up having to see wanted the wound to be moist during healing.
i'm not above second guessing medical professionals (probably the same hubris that is resulting in all these crashes), and my web searches seem to indicate keeping the wound moist will end up with better results. am i crazy for thinking that i should be following the procedure the wound care specialist at the hospital had me using last time as opposed to just listening to the doctor at the clinic i saw today?
scheibo is offline
Old 11-09-17, 10:48 PM
  #173
Ttoc6
Cat 2
Ttoc6's Avatar
Bikes: Tarmac, Why Cycles R+, Evil The Calling
Quoted: 605 Post(s)
Liked 194 Times in 87 Posts
Do you want scabs? Let it dry. Do you not want scabs? Keep it moist.
No matter what you do, keep it covered and keep it clean. If you see any sort of debris in the wound get it out ASAP. It's gonna hurt like a ***** but it's a lot better to do it now than have to reopen it and pull a stone or shard of carbon fiber out of a weeping scab.
If you're up for experimentation, try out @Ygduf 's Collodial Silver gel. I used it last time (mtb crash trying to jump my bike) to some successful results. Stopped the bleeding, scabs didn't form as thick but it did cause some weird ridges to form in my skin that took a while to heal. Still have the normal pink/rawness left over but it worked.
If you don't want to experiment gauze ortegaderm. If you can't afford or don't want to pay for tegaderm (or the wound is too large...) use saran wrap and neosporin or Petroleum jelly + skin tape to keep it in place and moist.
Ttoc6 is offline
Old 11-09-17, 11:17 PM
  #174
scheibo
once a runner
scheibo's Avatar
Bikes: n+1
Quoted: 270 Post(s)
Thanks. I'm pretty well equipped with tegaderm/gauze/non stick pads/colloidal silver/topical antibiotic/etc, and already had 2 doctors/nurses spend the better part of an hour cleaning the wounds and picking out debris. I want to go the moist healing route because I believe it will be faster healing and reduce scarring. My hip wound is too large for tegaderm currently (at least, the biggest sheets they had at the doctors/pharamacy), but until it reduces saran wrap actually seems like a pretty cool idea - i hadn't heard of that one before. Thanks!
scheibo is offline
Old 11-09-17, 11:19 PM
  #175
Heathpack
Has a magic bike
Heathpack's Avatar
Quoted: 4456 Post(s)
Liked 425 Times in 157 Posts
IMO you should get a second opinion and keep the wound moist until you do.
Twice I have been bitten by a dog with resultant infections. The first time it was handled very well by a hand surgeon. The second time I went to an urgent care place and the nurse practitioner there was floundering a little. I said something like, "Yeah it sucks, this happened to me once before & my hand surgeon wound up having to go with XYZ treatment".
She went behind the scenes and came back 15 minutes later telling me she'd made a phone call and consulted with a hand surgeon who suggested XYZ treatment course.
Heathpack is offline
