Guide For Winter Bike Tires - Studded Tires and Fat Bikes
#51
Quoted: 1062 Post(s)
Liked 665 Times
Last year I got a pair of Nokian W160's, to put on a mountain bike that I wasn't using for anything else. It was going to be my first full winter of bike commuting. The tires seem to be affordable and of decent quality. I haven't lost any studs.
But we were robbed. Madison got about 20 inches of snow all winter, half of normal. And I spent the coldest week of the year in bed with the flu. Most of my "winter" riding was on dry pavement with scattered patches of ice. Still, I worked out a number of useful things -- maintenance, clothing, lighting, etc. It helps me to have a place in the house for all of my gear, so I don't have to search for things in the morning.
It's hard to say how much the tires really slowed me down, since I was also encumbered by my ski jacket, snow pants, and boots. When it was well below zero, I wore my ski helmet with built-in ear flaps, and ski goggles. When it was warmer, I wore a wind proof beanie under my helmet.
The pleasure of being out in the brisk weather makes up for the extra time it takes to get around.
#52
Quoted: 7345 Post(s)
Liked 2,450 Times
Ski helmet. Good idea.
#53
Did I catch a niner?
Bikes: Vassago Fisticuff/Surly Ogre/Surly Pugsley/Surly Pugsley 29+
Quoted: 9 Post(s)
Let's not also forget the Nokian Extreme is a BEAR to get on a rim, it took all I had to get that one tire on a Salsa Gordo, and took even more to get it on a Stans rim which uses a slightly larger ERTO.
#54
No one carries the DogBoy
For what its worth, I've been very happy with my 32mm A10s. I don't expect to ride them in deep snow. I only ride them after the streets are plowed, and I have a very short portion of my commute on an MUP that isn't plowed at all. They are great on the streets even in occasional packed snow. When the weather gets worse, I use my other bike with 26" mount and grounds/ Also a good tire that isn't for totally extreme weather, but can handle more than the a10s. If I only had one bike, I would go to the W160 though.
Nokians tend to me hard to mount. I find that warming the tires in the sun does wonders for this process, but I'm also mounting them in November when there are still quite a few sunny days.
My riding has been in IA/MN & WI.
#55
I recently purchased a fat bike. KHS 4 season 1000. The KHS website shows that tires as Vee, which I read are terrible. But when I was at the shop, the markings on the tires just say KHS. So I'm not so sure what brand tires are really on there.
Anyways my commute is only 4.6km and the past winter was basically me going through a learning curve with a beater mountain bike on Continental spike claw 120s which were ok. The entire route isn’t that much of a challenge except for staying in the ruts cut out by pedestrians along the MUP.
So my fat bike has knobby tires and I’m wondering if it’s worth getting studs. As I was shopping I noticed some tires already had stud holes in them but mine did not.
A new set of quality studded tires would easily be another $200 or more.
At the bottom of this link shows spare studs you can buy for about $30 per 100 but they require existing stud holes already in your tires.
Components - Tires and Tubes - Fatbikes
And then there are grip studs where you can tap into the knobs of your tires. They are expensive at about $1 each stud.
Tire Studs | Grip Studs™ Screw-In Tire Studs | Traction in Ice, Snow and Dirt
Since I didn’t encounter a lot of challenging ice conditions last winter, I figure I should be ok with the knobby tires except that they may be Vee Mission.
Any thoughts?
Any thoughts?
#56
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
There are a lot weight weenie cyclists who exaggerate the weight and rolling resistance of studded tires... Yes it's true that studded tires weigh a little more then regular tires and they are a little bit slower but it's not as bad as some people make it sound. Winter riding will always be slower and harder not just because of the tires, but because of being dressed in heavier clothing, because of the air density and poor road conditions.
#57
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
Any thoughts?
Any thoughts?
Don't complain about the weather and cower in fear. It's all good weather. Just different.
#59
My KHS tires are actually ChaoYang 26x4.0 120tpi. The only review I can find is from mtbr.com which rated the 26x4.9 as passable. It noted the treads on the side could be taller for better turning.
Chaoyang/FatB 4.9 Initial Impressions/Review- Mtbr.com
Can anybody find any more reviews? I didn't get the fat bike as a sport but rather as a winter commuter. So I figure I may not be as demanding as those recreational riders even though it would be nice to have the flexibility and performance.
#60
Quoted: 539 Post(s)
Liked 44 Times
Thanks for the review. I have 26 x 1.75 Marathon Winters (great tires) on one bike and am thinking about adding studded 700c on another bike. Have you actually used this tire? Seems promising for everyday winter riding in the DC area. Also, it would be helpful to add tire weights to your review.
I'd definitely have a fat bike if it was 5 years ago, but now they plow our bike trails, so the skinnier studded tire is faster.
@PaulRivers Very nice summary of studded options. I concur with your assessments.
To add:
Nokian W160 (aka Mount & Ground) 26 x 1.95" tires (also mentioned by @fietsbob) = 2 rows of studs, so not as aggressive as the W240 or 294; they make a good commuting tire and are a better budget alternative than the Innovas. They are sure-footed but pretty heavy and slow. The tread is decent on snow.
To add:
RE Fat bikes: I bought a fat bike (Spec Fatboy) last year to commute through the Iowa winters. Partially, at least; my commute is 8.5 miles and I rode it at least once a week last winter, sometimes more often. After the first snow, I immediately bought the studded Dillinger 5 tires. The slush melts during the day and re-freezes at night, so I vastly prefer studs to power over and through the frozen ruts on streets and bike paths.
The studs make the Dillingers much noisier than any non-studded tire on bare pavement. But, surprisingly, the Dillinger 5's (4.5", actually) were barely any slower or harder to pedal than the stock Ground Control 4.5" tires, which are known as a fast-ish tire (for a fat bike). Or, maybe my wallet was so much lighter after buying the Dillinger 5's that it counteracted the difference in effort.
Riding the fat bike definitely takes more effort than a MTB, which takes more effort than a touring bike, which takes more effort than a skinny road bike. I can rarely coast; I have to keep a good pedal effort going to maintain speed.
But, the fat bike kept me active last winter which kept me from gaining weight.
So, I'm very happy with the fat bike as a winter commuter. It also makes a great MTB; I haven't ridden my Cannondale 26er hardtail once since I bought the fattie. The extreme traction of the fat bike makes up for my pitiful skills on technical MTB trails, and the fat bike feels more "proportionate" to my 6' 225# frame.
All good stuff.
A fellow Minnesotan here who commutes all year. And has done it one a few different bikes a few different ways.
- 26in with mount and grounds; this was good and pretty easy to get around as long as there is not a ton of snow.
- 29er with fat front and studded rear tire; this did ok and was really nice when the snow got deep since the front would push the snow apart and let the rear Nokian Extreme ride in it's wake problem with this setup was ice.
- Fat bike; this was a ok option to, the snow I see on our roads is considerably different then what I see on our trails so it's not a 1:1. There is a lot more stable snow on a singletrack trail then there is on the road it all wants to brake loose. Plus was it pushed out all the ruts
- 29er with studs; this is my favorite option as of now it works for me and is most importantly predictable.
My biggest suggestion for all year commuters who are especially just starting out is yes get a studded tire for your winters the greenways here do not use salt so they just get scraped and become shear ice. But also get some pogies and leave them on all winter, I have two sets now one for the fatty and one for the commuter. I can now wear a thin 45nrth wool glove all the way down to about -35F and even then my hands just sweat if I push it too hard. And for goodness sake if you do not wear a helmet all year, wear one at least in the winter. Some many chances to randomly fall over.
My personal experience with Nokians 294's was that they are strictly off road tires and not commuting tires. They are very good on frozen trails with rutted ice or frozen lakes. I didn't really like them for commuting in traffic snow or in mixed conditions.
I agree. In my experience, 2 inch tires offer no advantages over 30-38mm tires for commuting on snow covered roads. In fact I have been able to ride through much deeper snow with narrower tires then with wider tires. Skinny tires cut through all the slush and traffic snow and wider tires just slide all over the place. Wider tires are better at very low pressure on frozen bumpy hardpack snow/ice.
I have studded fat tires, and they are really not that bad. They weigh less than the Nates I have, which aren't studded. Of course, that comes at a price, they are well over $300 for a set. I got one studded and one unstudded and moved some studs between them to save money. So neither tire is fully populated with studs.
We have a lot of ice, and it gets rutted right away, so a fat bike is a lot more comfortable ride for much of the winter. Hopefully this winter will not be quite as bad as the last two.
@unterhausen, how far do you ride on your fat bike? I'm thinking I may need to allocate a lot of time to riding the winter bike to work. I haven't weighed the new tires yet, but they feel extremely heavy. I know I might be very happy with them, considering they will make an impossible ride possible. I might even enjoy the sound they make.
I normally ride the lightest tires I can. I don't care about flats. I'm adept at fixing them. I just want light tires. But I'm willing to try these tires. I better be willing, after all I spent on them. They are cutting edge technology, so they won't ride as badly as their shear weight implies.
Last year I got a pair of Nokian W160's, to put on a mountain bike that I wasn't using for anything else. It was going to be my first full winter of bike commuting. The tires seem to be affordable and of decent quality. I haven't lost any studs. But we were robbed. Madison got about 20 inches of snow all winter, half of normal. And I spent the coldest week of the year in bed with the flu. Most of my "winter" riding was on dry pavement with scattered patches of ice. Still, I worked out a number of useful things -- maintenance, clothing, lighting, etc. It helps me to have a place in the house for all of my gear, so I don't have to search for things in the morning.
If you ride regularly in the winter, and want to ride fast, it's a whole different wardrobe. Wearing regular ski jackets and pants can trap the moisture from sweat, making you colder. It's not such a big deal if you just ride slower to begin with, but if you ride faster the outfit is usually a wool/synthetic base layer, additional wool/synthetic base layers in the middle if needed for the temp, and a windproof but breathable (goretex, event fabric, or windstopper) outer shell.
For what its worth, I've been very happy with my 32mm A10s. I don't expect to ride them in deep snow. I only ride them after the streets are plowed, and I have a very short portion of my commute on an MUP that isn't plowed at all. They are great on the streets even in occasional packed snow. When the weather gets worse, I use my other bike with 26" mount and grounds/ Also a good tire that isn't for totally extreme weather, but can handle more than the a10s. If I only had one bike, I would go to the W160 though. Nokians tend to me hard to mount. I find that warming the tires in the sun does wonders for this process, but I'm also mounting them in November when there are still quite a few sunny days. My riding has been in IA/MN & WI.
My 1.9" Nokian/Suomi W160 Mount and Grounds weigh exactly twice as much as the 1.75" Paselas I use in the other three seasons (946g vs 470g) and I'd consider both to be fairly middle-of-the-road in that regard. To say that studded tires weigh "a little more" or have "a little more" rolling resistance would be just as disingenuous as exaggerating the difference. I truly felt like I was on the verge of a heart attack the first time I rode studded tires and I'm not otherwise at high risk for one.
#61
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,529 Times
Was DHL the carrier? I shipped two foot lockers of personal goods from Afghanistan with DHL that arrived in the US two days later via Bahrain, Lepzig and Cincinnati, a week before I arrived home.
#62
Liked 2,450 Times
Yes, it was DHL. Your story is even impressiver.
#63
Quoted: 1363 Post(s)
Liked 1,675 Times
So the 2nd "Nokian" W106 tire came two days after the first. They are both branded as "Suomi". I did a quick google search and found this: FAQ / Nokian Tires and this: Home | Suomi Tyres
Apparently Nokian divested its bicycle tire division in 2004 which was bought by another Finnish company, Suomi,who have been making Nokian Tires since at least 2004. I guess they brand them as "Nokian" where they can or want and "Suomi" everywhere else. The instructions said to ride 'em 35km before attempting snow and ice. My commute is 18 miles round trip so that should suffice. I will post my experiences as winter progresses.
#64
Liked 2,450 Times
Suomi is the Finnish word for Finnish.
#65
Liked 665 Times
Ha, well studs are for ice not snow, so that part makes it sound like it was an even better winter for riding. If you got the flu the coldest week of the year is the one to get it - I have no problem riding between 15-25F, but around 0F you have to worry that any exposed skin will get frostbite. You really have to make absolutely sure your gear covers all of your skin for those conditions. I tend to just take the car when it's that cold.
Even aside from the week that I missed, there were several below 0F, getting down to -10 at worst. I was very well covered up. For better or worse, I ride pretty slow, and my commute is only 8 miles round trip on flat terrain. Also for whatever strange biological reason, I don't sweat a lot.
I imagine that if I have to slog through real snow, then I have to be more concerned about sweating, so I won't assume that I've yet found the optimal clothing. I was using stuff that I already had, since I've always been outdoorsy, but just haven't been outdoorsy in the winter on a bike yet. Now that I made it through one winter, I'm more willing to spend some money on appropriate gear.
Note: My tires were listed as "Nokian" by the retailer, but "Soumi" is molded into the rubber.
#66
Liked 1,675 Times
#67
This thread should be a sticky in the Winter Cycling section.
As I was researching the tires I have and the Dillinger studded tires, I kept running across these other names: Lou/Bud, Nate and Ground Control.
The tires I have are Chaoyang Big Daddy 26x4, 120tpi. Mtbr has a post with a test for the 4.9in and said it was passable. I measured the knob height. It is 4mm (more about that next).
Mtbr also compared the Lou/Bud against the Dillinger 5 studded.
Bud/Lou versus Dillinger 5- Mtbr.com
Seems odd because the Lou/Buds aren’t studded so each type of tire would have its strengths and weaknesses. Of course you’d expect the Dillinger studded to excel on ice but surpassed by the Lou/Bud in deep snow. It seems each time someone else posted a review, the opinions keep changing. The knobs on the Dillinger were 5mm and the Lou/Bud’s were 7mm.
So if one were to put studs on the Lou/Bud tires, it would be the best all around tire wouldn’t it? Makes me wonder about the ability of my own Chaoyang Big Daddy tires which have only 4mm knobs.
Mind you, I’m probably not going to take the bike to the extremes like mountain bikers do as I am only using it to commute. The commute route takes me through 2km on a MUP which isn’t maintained in the winter. The tires would also have to take me through a plowed sidewalk with icy and snow chunks on it as well as plowed roads.
So what is the opinion of the Lou/Bud, the Nate and the Ground Control tires?
#68
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
The Specialized Ground Control tires have a slightly less aggressive tread and smaller knobs, so they have slightly less traction but roll a little faster. Plus, they're a bit narrower than the Bud and Lou.
But, aggressive tread still doesn't help on ice, only studs do. I really like my Ground Control tires but I swap them for Dillinger 5's once it freezes. Surprisingly, they are pretty fast tires even on pavement. The studs are super noisy, though.
If your tire has stud pockets built into the tread (Dillinger, Escalator, some Vee Snowshoe tires), then you can buy inexpensive studs and just push them in. Get the studs with carbide tips, they last much longer.
If your tire doesn't have stud pockets, you have to use screw-in studs (Grip Studs). But, they're about $1 a stud, so that's an expensive option.
Some folks "redneck stud" their tire with common hardware (screws or bolts) through the tread, but they wear down quickly (they're not carbide steel), are heavy, and put a ton of holes through the tire.
#69
Bikes: Scott Genius, Surly Crosscheck, Yuba Mundo cargo, Specialized Dolce Triple (stolen 5/8/15)
Quoted: 29 Post(s)
cool thread! we have gotten Nokian w240s studded tires for the winter. if anyone has had experience am curious. otherwise i will come back and post my experience when we get snow later this season.
#70
I had considered buying a e-bike helmet because they are much cheaper than motorcycle helmets but offer sufficient protection for a cyclist. Plus, the ones I was looking at had face shields that should provide protected and hopefully unfogging vision.
#71
#72
Bikes: Surly CC
I ran with the schwalbe marathons for a few winters, but just purchased some 45Nrth Gravdals at 120tpi . The marathons were great (good control & good speed), but after a few winters I was interested to try something else, and wanted to try a higher threadcount / non-wired type. I gave the marathons to a neighbor kid that wants to try some winter biking. Looking forward to getting on these Gravdals
#73
Randomhead
Liked 3,686 Times
I have studded dillingers on my fatbike. When we start getting snow, it immediately turns to ice. And when it gets rutted, it is a pain to ride on with 2" tires. So the fatbike gets ridden a lot. In out kind of weather, not much point in having non studded tires on the fatbike, in fact, it might be worse in a way. I'm hoping our winter isn't as extreme as it has been the last couple years. So far we are having an extremely warm winter
#74
Liked 2,450 Times
Right, and I can't tell yet if my winter purchases are effective. Now I'm hoping for at least a short period of severe weather.
#75
FWIW Kala is Finnish For Fish
Lots of Finns setters here Swedes and Norwegians too.. ..
Back in the 90's I got bundles of bike Tires imported directly from Finland ..
still have my studded ones from then .. ready to roll once I Pump up the PSI
