Dr. Scholl's Custom Orthotics
Slacker
Bikes: 1986 Peugeot Orient Express, 1987 Trek 560 Pro, 1983 SR Semi Pro, 2010 Motobecane Le Champion Titanium, 2011 Trek Fuel EX8
Quoted: 97 Post(s)
Liked 6 Times
Any of you ever use the Dr. Scholl's foot-mapping kiosk to inform a purchase of insoles?
I'm using a pair of Diadora Speedracer 2 Carbon shoes, mainly, and I was thinking better insoles might help with the hotfoot I get on long rides. But Specialized, for example, has three kinds of insoles, and I have no idea which one to buy.
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
Quoted: 138 Post(s)
Liked 12 Times
The views expressed by this poster do not reflect the views of BikeForums.net.
I actually did this last week. From what I noticed it's not really a custom fitted orthotic. What the kiosk really does is it sees what type of arches you have and then gives you a recommendations based on that.
I ended up just getting a pair of Superfeet Cycling insoles. They're alright...
Bikes: All-City Space Horse!
I have done it, but its giving you info based on walking, not on how your feet will be while riding. I'd look into something more cycling specific.
Slacker
Quoted: 97 Post(s)
Liked 6 Times
Bikes: 2009 Trek Soho
avoid! avoid! they are superthick insolves that will not fit in your cycling shoes. (believe me, I've tried). go to an LBS and for the same money ($50ish) you will get what you need.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
I use the yoursole thin sport insole. You heat it in the oven to make it pliable, then put it in your shoe, put the shoe on and voila, a custom footbed.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
Orthotics are generally designed for walking/running. The forces on your foot during cycling are quite different and may require different insoles/orthotics than a street or sport shoe would.
The stock insoles on my Shimano R106 are garbage and were causing an issue on my left foot. I needed more arch support. The only problem is beyond a size 10 they don't adjust length between the arch with the heel appropriately. I have a size 10.5-11 depending on brand and I got the 9-10.5 Size (Size E?) but the arch was too close to the heel. I thought this was my fault so I bought a Size F (11-13) and it's the SAME length apart. The good thing is the yellow cycling version is slightly thicker than the stock insole that came with my R087s and R106s.
I already had Superfeet black in my work shoes and they help out a bit.
I guess I'm supposed to have custom orthotics.
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
I think orthotics are mostly for correcting people with flat feet. Maybe there's other corrections but mostly for flat feet.
I do have flat feet and I have custom made orthotics from my running days. I do insert them in my SIDI shoes. But I don't think it does that much for me. What I think matters is how I redistribute my weight so that when I push down on the pedals, the outer edge of the foot takes up the pressure rather than the inner part of the foot.
Blissketeer
Refrigerator Raider Hater
Bikes: 2008 Sequoia
Slacker
Quoted: 97 Post(s)
Liked 6 Times
I have no idea if the kiosk software then is the same as now.
Seemingly everyone says that the stock insoles which come with cycling shoes are not very good. The ones from my Diadoras (pictured below) look and feel like they offer some support, but if some other insole would more effectively combat hotfoot, I would be willing to try them.
The marketing of these aftermarket insoles is compelling, but they are not cheap (for a bunch of foam and plastic). I don't want to just throw money at this. But spending money on the contact points can be money wisely spent.
Slacker
Quoted: 97 Post(s)
Liked 6 Times
Quoted: 12194 Post(s)
Liked 1,497 Times
I've tried a lot of innersoles.
I have tried cycling with those Dr Scholls.
They are a 3/4 sole, and the front edge always bothered me after a couple hours.
They are bulky, but they fit in my Megas. But I can see where they wouldn't
fit in a lot of cycling shoes.
I don't see that as an issue. If they worked well, you could get Lakes.
If they come out with a full length version, I might try them again.
These companies want you to be happy and offer a 60 day return guarantee. I didn't like the first pair I got from superfeet and had worn them for a week. I told Amazon and they said this item is something they take back no questions asked. They gave me a return label and told me to send them back.
When you are paying $35-$45 for an orthotics that probably costs 1/20 to make that's the type of service they offer.
I have flater feet and orthotics helps a lot. I usually have a pain on the outside of my foot. Trek has e-soles in their shoes and my GF loves them. She has custom leather orthotics in her running shoes that keep her from getting pains.
I tried the specialized red soles but found that I liked this other brand better. They were heat formed ones but the shape fit my foot better from the start. If I didn't find any locally I would have ordered the Louis Garneau heat moldable ones as they get great reviews and decent price too.
Quoted: 25 Post(s)
What kind of arch support do you need? Do you notice a significant difference between the stock insoles and these Your Sole insoles?
Bikes: 2008 Sequoia
I have two sets of actual custom orthotic insoles at $200 each. My arches are so high that my footprints would be a 0.5 on this graphic, the prints connect, barely:
There is a good reason they are expensive as they have four different types of foam in varying thicknesses, with the inner part of my arch being nearly an inch thick total. I use them for cycling in addition to boots, sneakers, and dress shoes.
Bikes: are better than yours.
My fitter made some custom insoles for me. The conformables, in the right shoes make a huge difference. The e-Soles and YourSoles are crap by comparison.
Telemachus has, indeed, sneezed.
Recusant Iconoclast
Those Dr. Scholl's things aren't "custom" orthotics. If you truly want custom you need to see a certified pedorthis, and even better if he/she has a kinesiology degree. They'll assess you if you need one, and if you do, make a cast of your foot. Price varies but probably in the neighborhood of $400. Mine are for running only, carbon fiber, and lighter than the insoles of the shoes I replaced them with.
If hot foot is your only issue, make sure you're not overlooking the possibility that your foot anatomy requires a varus/valgus cleat shim/wedge (or several). An insole alone, however nice, would be a poor way of compensating for this.
I have an extremely flat left foot (probably a 3 on the graphic fordmanvt posted) - it's almost completely collapsed. My right foot is probably around a 2. I make a conscious decision to put pressure on the outside of my left foot on the downstroke but I often experience foot pain along the 5th metatarsus at the end of a race.
I don't experience knee pain yet but my left calf does tend to cramp/tighten more than the right so I assume knee pain is not too far off.
I have already purchased bike shoes and don't want to buy new one's so is there anything other than a $400 orthotic option in a case as extreme as this? I would be willing to try the heatable/moldable insoles but I'm confused as to how they work.. If you heat it up and press it to your foot, wouldn't it mold as a flat foot?
Quoted: 25 Post(s)
