1994 Specialized S-Works M2 project
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 143 Post(s)
Liked 438 Times
I stumbled into this bike on Facebook marketplace last spring and the seller worked with me for more than 2 weeks to complete the sale. I kept asking for details and the seller simply said it was a Specialized S-Works M2 and gave me the standover which looked like it would work for me. Then I started searching for the S-Works line information
Here are the specs on the bike as purchased - far from original but cared for and had some period correct upgrades:
S-Works M2 frame
Specialized Future Shock fork (Titanum/Carbon Fiber)
Ritchey 6061 bars
Specialized seatpost
Specialized Ti stem
Deore XT derailleurs 3x8
Deore 175 mm crank
XTR brakes
Sram grip shifters (meh)
Specialized Crossroads tires on original SWorks rims
S-Works M2 frame
Ritchey 6061 bars
Specialized Ti stem
Deore 175 mm crank
XTR brakes
Likes For Trav1s:
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
After riding it as is over the past year, I decided to make some upgrades (and put the original parts on the shelf for now). The local bike shop handled a crank upgrade to 165mm arms and a shorter stem. Both made the bike much more comfortable for my 5'6" self. The swap to the 165mm crank was by far the best decision as I rock less from side to side and have much less hip pain. WIN!
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
LBS mentioned that while the FS fork was in working condition, there can be problems with the Ti/CF bonded fork. If I was going to spend any trail time with it, even a spring fork should be considered. I eventually found a Rockshox Recon TK Solo air C1 26 fork that fit the bill. There was cheaper coil spring option from RockShox but the additonal $50 yielded a much better fork.
Here's the FutureShock in all of its Ti/CF 80mm travel glory
While the additional travel does impact steering geometry, the Recon's 100mm travel is a close as I could find with a 1" straight steerer tube.
Likes For Trav1s:
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
Old S-Works are always nice. You got the first generation M2 there. The year prior was the gorgeous maroon prestige steel frame with the Mag-21 Ti.
I took my '96 S-works around the world a few times while I was in the Navy.
Likes For PhilFo:
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Thanks for the scoop! It’s an amazing bike for sure. I didn’t know the history other than I though it was the first year of the M2 frame.
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Removed the Odyssey platform pedals for a pair of FaceFace Chesters. They fit my shoes better and was able to shed some weight in the process.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Length is a factor, but those original cranks are just uncomfortably wide for those of us with narrow hips.
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Ah! Now I see it in a new way. Never considered width. I’m really happy with Albion setup the LBS found for me. I’ll look into measuring old v/s new for reference.
Likes For Trav1s:
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Another update on the M2:
A friend has a mid 90's CroMo Hardrock Ultra that still was wearing the original Specialized Crossroads tires that needed replaced. Since I had been considering a tire swap on the M2, we made a deal and I put the new Crossroads Flackjackets from the M2 on his bike. Now I'm looking for some nice all around tires and think some Nobby Nicks will be the choice. The Odyssey pedals also got swapped to the Hardrock Ultra and he loves the upgrade. I call it a win for everyone.
Also, this weekend I stumbled into NOS Shimano Deore XT M738 brake/shifter combos that will replace the current SRAM twist grip shifters and current brake levers. The SRAM stuff will be looking for a new home too.
Likes For Trav1s:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I think you can still get Velociraptors. They definitely look period. WTB kept making them a long, long time.
That model of fork you can limit the travel by putting a spacer on the negative side of the air spring shaft. Probably one of the motion control dampers could fit
Genesis 49:16-17
Genesis 49:16-17
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Thanks for the suggestion Darth - I see the Velociraptors are available but considering the where/how of my riding, I think they will be more aggressive than I desire. I am leaning to Schwalbe Magic Mary or Specialized Fast Track Armadillo with the Specialized the likely choice. I'm also going to swap handgrips and I'm researching options.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Likes For Kapusta:
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Goodies arrived yesterday and I did a bit of work. I’ll leave a few pics for now.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 980 Times
very nice project For wheels, you can also check the mavic crossmax mark1, they will complete your bike well
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Thanks for the suggestion. I was concerned about wear on the original rims so an alternative is appreciated. I've considered a disc conversion since the fork has a caliper mount but think it's probably wise to leave good enough alone.
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
The rebuild is on hold since the "to order" list for the M2 continues to grow:
Ergon GA3 grips - https://www.ergonbike.com/en/product-details.html?anr=42410088&s=ga&a=griff
Specialized Fast Trak Armadillo - https://www.specialized.com/us/en/fa...=232365-157289
Cool Stop Pads
Cool Stop Pads
Likes For Trav1s:
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
These arrived and got them installed in record time. Still need tires so no seat time on this one for me.
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Ordered the Specialized Fast Trak Armadillo 26"x2.1" tires to replace the Crossroads that were on it. After a fair amount of reading, these seem to be a solid option for the riding I do with it.
Other than that, nothing new with this project.
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
Tires installed along with new Shimano pads on the rear. The tires are a bit larger ant 2.1”x26” and look more proportional to the bike. They are definitely more sticky than the Crossroads I took off of it. I got the rear derailleur dialed in on the first attempt and I'll need a bit more time on the front but it's totally ridable as it sits.
Ignore the saddle placment - I need to readjust it to reflect all of the upgrades
I’m really loving the final product!!
Steel is real
Quoted: 671 Post(s)
Liked 980 Times
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
It's nimble and very predictable. The fork swap slowed down bar input a bit but I prefer the change. Bike is a bit heavier than it was before the upgrades but still light. I hoped to hit the local trails but summer storms are keeping them too wet for riders. I'll take it out for a ride on the paved trails and report back more.
Likes For Trav1s:
Tinker-er
Quoted: 165 Post(s)
Liked 267 Times
Do those XTR V brakes squeal at all? Back when they were introduced, they squealed right out of the box and Shimano had to issue a shim kit to disallow the parallelogram linkage to vibrate.
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
No squeals, even with the old pads on it. It's definitely smoother and less grabby since I replaced back pads and need to do that fronts soon.
Deraill this!
Quoted: 143 Post(s)
Liked 438 Times
I finally made it to the local trails for 5.5 miles of riding. The fork works great, bike handles well, and I'm impressed with the setup. I needed to adjust headtube bearing preload again and do some derailleur fine tuneing but that's minimal. The tires are very sticky and handled everything from packed dirt to sand to obstables without a problem.
But... the bike is too big for me. Standover is a big higher after the fork swap and that makes all the difference. Soo... I think I'll clean it up and try to sell it. NO regrets on the fork swap either.
Likes For Trav1s:
Tinker-er
Quoted: 165 Post(s)
Liked 267 Times
It'll be worth more with the original fork back on it. Or at least sell the bike with the S Works fork.
Likes For PhilFo:
