Can anyone suggest a good, easily removable handlebar mount for bolt-mount headlamp?
Bikes: 1974 Raleigh Grand Prix
Hello,
I am trying to figure out a good, but also affordable way to mount my inoled headlamp so I can remove it when I am going to be locking my bike up for a while outside.
It has a bolt mount that is designed to fit on the front fork,
but my brakes aren't compatible with it and I also need a mount for it, thats removable Here is another photo..
Its a very good headlamp..
I will be very happy when I can mount it securely so that its also easily taken off and put in my pocket when I am leaving my bike somewhere.
Ideally, I'd like to find or make something like this "lenkerhalter" mount.
Thank you!
Thank you!
Check out Minoura's accessories. There are a number of quick releases, and many of them are bolted together in a way that you should be able to disassemble and mount your light. The only downside is that since the whole thing detaches, you'll have to redo the aim each time you mount it.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Obviously, you've already found it.
Community guidelines
Except that it's $17
That's just too expensive for something like that, IMO.
Unless there is something there I am not seeing.. That's just a handlebar mount, right?
Something like this would work too, although its not removable.
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
Yes, that allows you to mount your light to the handlebars. The Inofix would allow you to mount to the stem, if you have a threadless stem.
Either way, if you remove your light every time you lock up, you lose the convience factor of a dyno light set-up. The trade off for going battery free is to basically mount the light(s), aim to desired effect, and forget about them. If you're worried about theft, then mount the light and use some kind of exotic screw/bolt head or fill in the screw head with something that you can dig out later with some effort.
Out of curiousity, are you planning on using a hub or sidewall generator? If you run a wired tail light with a hub, then you'll also need to get that Isoguard circuit. Sidewall generator doesn't require that circuit.
Sidewall generator, as it doesn't make sense to spend more given how infrequently I ride at night. And yes, I am definitely worried about theft. Even though I don't live in the city, things do get stolen around here sometimes.
I wouldn't be surprised if the mounts for some other brand work with the inoled, I just have to find a good one. Its a nice light.
Liked 6 Times
Have a look at these: https://classifieds.mtbr.com/showprod...-mounts&cat=27
My DiNotte 600L came with that mount. The headlight mounts on a shoe that can be slid onto the bar mount. It'd require a little adaptation, I'm sure, but it's a good mount.
mechBgon,
Thank you for that link.. thanks a lot.. lots there thats useful.
My light basically takes a M6 20mm bolt.. and the holder is 8mm wide.. I suspect that there is a mount out there that would fit - it seems like it would be a common size..
I just need to do more looking..
The site that page links to has their mounts which could probably be adapted.. they are also inexpensive.. If only the gap was a bit narrower they would be perfect.
Liked 6 Times
Some spacers would fill the gap, just thick washers basically. I forgot to mention another feature of that mount (maybe you've already discovered it) but the entire shoe can be swivelled about 15° to the left or right on the base. They're REALLY nice mounts. There are even offset versions if you want to have the light right on the bike's centerline: https://www.batteryspace.com/handleba...ikelights.aspx
Also, as you can see, the entire mount has a quick-release cam. And there are two reducer shims that can be removed to convert it to 31.8mm bars.
These look like they might work well.. maybe with some washers.. Thank you for that link.
Use wing-nuts and/or thumbscrews,instead of regular machine screws..
more Kludgie ..
I got a 2_Fish Rubber block and 2 velcro straps,
there are parallel .. I Use it to keep my frame pump in front of my seat tube..
and a crossways one , It works to put a mini 'maglight' on my handlebar. the backup.
I'm thinking.. putting a piece of dowel or, whatever round,
with your headlight mount on it , with a screw ,
or whatever..
then You can grip it with 1 velcro buckle ,
fit the thing on with the other..
these use pulley like strap ends and you can get them pretty tight.
and some sticky back stuff to help make a tacky mounting place.
and Zip off a strap, un plug the wires and you are good to go.
more Kludgie ..
or whatever..
Quoted: 2604 Post(s)
Liked 1,934 Times
What about using some anti-theft screws to bolt it on?
polymorphself
8
07-02-18 08:31 AM
balrog687
0
07-06-15 11:41 AM
