Will this Shimano Deore work with my DeVinci?
Ok. I hit up the search function and came up with bunk. Also checking out the recommended sites for Shimano stuffs. I figured I'd also employ the "it happened to someone else last week" mentality and see if it actually has.
My bike is a 2010 DeVinci Cameleon 3. I had a fairly solid ride and bail that resulted in the bending of my chainrings... I'm looking to replace the crankset as a result. I'm drawn to the Shimano Deore FC-M590 (Product)... I'm probably going to bring it into my local shop to get it put in (to avoid the PITA of getting the tools to do it myself, I hate unitasking tools), but I've encountered a deal that I probably can't pass up (it'll save me $100 on buying it in the shop). So I'm wondering if the 2 will be compatible? What other information should I be gathering to see if it will?
Quoted: 5791 Post(s)
Liked 2,581 Times
Bad news.
Derailleurs don't care about bikes, as long as there's a derailleur hanger. They care about the cassette and the number of speeds, and they care that the levers match properly so it's a single compatible system.
Since you're putting a Shimano derailleur onto a bike with levers made for Sram, it won't work. Sram systems have a different cable response ratio, meaning the distance the RD moves for each click, than Shimano.
It's like running a ship with a Captain shouting out orders in French to an English speaking crew.
So, either stay with Sram derailleurs, or replace both the derailleur and a matching lever set.
FB
Chain-L site
FB
Chain-L site
Hrm. I might be on glue here... But I'm talking about the crankset (bottom bracket and chainrings and cranks), not derailleurs... Or is there a leap of logic I'm unaware of? There's a Shimano chain on there right now, running just peachy keen with a "temporary POS chainring" that's on there just as an interim between the original and whatever I get for replacement...
Liked 2,581 Times
BTW- most compatibility questions are drivetrain related, so when you say Deore, people think RD. So next time say will this Deore Crankset work.
FB
Chain-L site
FB
Chain-L site
AHA! Ok. Simple lingo barrier.
See, this is a matter of having ordered this crankset 9 months ago when I needed it, then it taking 5 months worth of "it's on it's way" for me to finally just get my money back. Now I'm 99.9% sure that this is the one, but I can't find the purchase order for the one from eons past, but this one strikes a chord with me, so wanted to check before I bought it. At least, if it IS wrong, I can return it without issue.
Thanks.
Thanks.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
They're both 44-32-22 triples meant for 9-speed drivetrains, so it should work.
Off the top of my head, two things to be aware of:
- You'll need to replace the bottom bracket along with the crankset. (Not a huge problem. The Shimano SM-BB51 bottom bracket the Deore spec sheet calls for is under $20.)
- Crank arms are made in a few different lengths, such as 165, 170, or 175 mm. You'll probably want to match size of your new cranks to your old ones.
Liked 5 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
Hmmm, interesting that the MTB crank sets come with the bb. For their road HT2 cranks, you have to buy the bb as a separate item.
Liked 5 Times
The part that weirds me out is that the mtb cranks tend to be as cheap as comparable level road stuff, yet they ship with a part that retails @$20 or more....
