Raleigh Super Course binder bolt length?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
If anyone has a 1973 Raleigh Supercourse with their original binder bolt, I'd appreciate pictures and the length of the bolt.
TIA
TIA
The dropped
Liked 1,014 Times
How far apart are the ears on the seat post clamp? Mine are 17.5mm, which makes me wonder if it's a little deformed. I received neither a seatpost, nor a complete bolt!
Quoted: 457 Post(s)
Liked 462 Times
Mine are at 20mm.
Are the sides of slot in the back of the seat tube parallel to each other? The width of the slot is around 2.5mm or so, so if your ears are at 17.5 your slot is possibly nearly closed at the top?
The dropped
Liked 1,014 Times
Pinched seatpost binder
No, they were not closed, but were not parallel. My calipers were measuring towards the outside of the tabs, inflating the error.
I expanded the seat tube with several different sizes of steel seatpost. I ended at 26.4, since 26.2 seemed to be the right size, but tighter than I wanted. What size seatpost does yours use?
The dropped
Liked 1,014 Times
Quoted: 3810 Post(s)
Liked 6,699 Times
I’ve owned lots of early 70s Super Courses, and seat post sizes have varied from 26.0 to 26.2 to 26.4. Classic Raleigh inconsistency!
The dropped
Liked 1,014 Times
That's precisely why I didn't know the seatpost size, without starting with one. I have one vote for 26.4 for a 1973 Carlton made supercourse. I can go back to ther co op and pound a 26.6 seatpost in to stretch the clamp back out to 26.4.
Liked 6,699 Times
Well, if you have some vernier calipers, you can measure though if the lug is distorted from over tightening, you might not get an accurate measurement.
The dropped
Liked 1,014 Times
For those that are following:
Sheldon Brown (bless his soul) created a database with seat tube sizes for various bike models in various years of manufacture. My seat tube is 26.4mm, after cold-setting the lug with well-greased seat posts of increasing diameter, handy at the co-op.
...addicted...
This was a super helpful thread. I now have a seatpost of the right size and a new binder bolt coming for my '73 Super Course restoration. The seat tube was pinched and out of round, which I will have to cold-set back open a bit. I've got a few smaller posts that I plan on using for the job so that I don't destroy the alloy post that will be going in for real.
The dropped
Liked 1,014 Times
It was only possible with the help of others. That and clear subject titles.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
Unca_Sam-
If there's a framebuilder nearby, get him to ream and hone the seat tube to the specific diameter you require. The fit will seem like a miracle as almost all seat tubes go out of round during brazing.
Quoted: 800 Post(s)
Liked 753 Times
While this thread is around, a question. my super course frame (mk. ii) did not come with the binder bolt. I used a recessed brake nut, a few washers, and a regular bolt instead. I tightened it down, not like a gorilla, and the seat post hasn't slipped a bit. The ears/slit look fine. But, does this setup have the potential to improperly bend the ears and slit of the lug? AKA should I fork out the money and source a raleigh binder bolt?
The dropped
Liked 1,014 Times
Regarding a "Raleigh" binder bolt: as long as it's there same diameter and keyed, any bolt and matching nut will do the trick.
