Commuter Bicycle Pics
Bikes: 2009 Felt QX75; 2014 Soma Double Cross Graphite
Bikes: 1997 Kona Hahana Race Light, 2010 Surly LHT(deceased), 1999 Rocky Mountain Turbo
Quoted: 86 Post(s)
I think it was this? Fizik Microtex Handlebar Tape - Mountain Equipment Co-op. Free Shipping Available Or the house brand equivalent. I like it since it is not prone to look dirty and has stayed bright the last 4 months. It is thin and not padded but that is my preference.
Thanks Joey! Looks good. Might try it on my next bar tape replacement.
Thank you.
Bikes: 2015 Cannondale CAADX, 1994 Nishiki Performance Equipe
Quoted: 7 Post(s)
Here’s my Atlantis. The Jannd rack trunk expands to hold an impressive amount of stuff.
Quoted: 86 Post(s)
Everything attached is used everyday. It is a daily daycare hauler then gets me to work.
one life on two wheels
Liked 18 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,979 Times
Fenders installed! Ready for rain.
Quoted: 86 Post(s)
Now how is the best way to attach the turbine to the rack? Zipties or mechanics wire?
I love the yellow bike.
@DiabloScott I like the stealth flat black, the fenders are a nice accent.
But the yellow does it for me.
always rides with luggage
... a P180???
Fly up to RDU and give a brother (and his kids) a joyride!
--Ben
2006 Trek SU100, 2009 Motobecane Fantom CX, 2011 Motobecane Fantom Cross Uno, and a Bakfiets
Previously: 2000 Trek 4500 (2000-2003), 2003 Novara Randonee (2003-2006), 2003 Giant Rainier (2003-2008), 2005 Xootr Swift (2005-2007), 2007 Nashbar 1x9 (2007-2011), 2011 Windsor Shetland (2011-2014), 2008 Citizen Folder (2015)
Non-Bike hardware: MX Linux / BunsenLabs Linux / Raspbian / Mac OS 10.6 / Android 7
--Ben
Bikes: BD CX commuter, 80's Stumpjumper
A little of DIS, a little of DAT. Seriously, years ago I swapped engines on an old 421 Riley Rocket conversion (if anyone here knows what they were; good on you) and the "manual" said for engine removal: "Remove engine from mount. Installation is the opposite of removal." That was really helpful.
Yes! Avanti II. Sorry, though, I am just a tech. No rides from me. Years ago (again) I was flown to Sarzana, Italy do do some engine work on one of the Guardia Costa's P166's. THAT was pretty nifty.
Well, I am insanely jealous.
--Ben
--Ben
Bikes: 2015 Motobecane Mirage S
Wow, haven't posted here in a while. Oh wellllll XD
Anyways, this has been my daily ride since early May or so. It's far from a dedicated "commuter" but it works so far.
Trek 3900, from 2007 I believe
-Cheap rack/bag I found at walmart a while ago
-Schwinn computer
-Rear light, didn't have my headlight on in this pic
I just ordered a set of Ibera panniers, new set of schwinn Street Comfort Tires, and some other miscalculation bits.
If anyone had some advice for other additions I could make, I'd appreciate it. Not sure how compatible Treks are with various upgrades but I'm always looking to learn!
-Schwinn computer
Quoted: 5772 Post(s)
Liked 2,564 Times
If you ride it to and from work on a regular basis, then by definition it's a (the) dedicated commuter. What else would it be?
FB
Chain-L site
FB
Chain-L site
Ha, true enough! Probably not the most efficient ride out there, but it can definitely take a beating! I've been running that poor bike hard for about three years now.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
Quoted: 7348 Post(s)
Liked 2,461 Times
I've been using this on the streets the last couple of weeks. Light frame, longish wheelbase, and wide-ish (32mm) tires make for a nice ride. It has a Sturmey-Archer S3X hub, which is a 3-speed fixed gear hub.
Bikes: 2015 Salsa Fargo 3, 2000 Specialized Rockhopper
Quoted: 9 Post(s)
Liked 9 Times
Damn autocorrect, hah. "Miscellaneous" and yeah, that's part of the plan. I'll see if the Iberas will work on my current rack but if not I'll get something else.
Liked 2,564 Times
When you have a minute (make one) remove the front wheel and look at the bottom of the fork crown to confirm that yours has the steel dowel pin that was added to prevent unannounced steerer tube separation.
It's very obvious and if you don't see it, consider that fork to be a micro-second away from a face plant. Not the next micro second, just any some time down the road.
FB
Chain-L site
FB
Chain-L site
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
I have done a thing before where I took "galvanized steel strapping" (I live in CA and had lots extra from a roll I had to buy to secure a water heater), cut two approx 8-12" lengths, folded them in half so the holes aligned, used bolts through holes on the bottom end to attach to frame, and then hooked pannier straps into holes on the top end, and then tightened. It worked pretty good to stabilize panniers on a seatpost rack.
