Bicycle lighting for the car free
In the right lane
From following various threads in other forums, seems like bicycle light is a contentious issue.
I'm guessing that trying to life without a full-time car and therefore needing to travel at night puts some extra requirements on lighting specs.
For example, I used to have a rechargable light (it was a pretty bright DIY job...), but if I needed to go somewhere while it was charging, I had to reach for another light.
Also I found that my bright light wasn't well focused and that a well designed bike-specific light, even though its output was less, seemed to work better.
For the last couple of years, I've been using dyno lights and find the effort of fixing up a new wheel is well worth the pain. They aren't as bright as rechargeables, but seem to me to be adequate.
What about you? What lights your way?
Sophomoric Member
As always, I'm a minimalist. (IOW, cheapskate) I just use the cheap LEDs that use AA batteries. Planetbike superflash is my usual choice, although other makes are available that are just as good.
I like the run time of 20 to 30 hours or more. My city is lit well, so I really don't need lights to see the road. Drivers can see unlit bikes pretty good. I would never ride at night without lights but the small lights are adequate to be seen by, IMO. These cheap lights are so small and light that it's easy to double them up or carry spares. I often ride with an extra front light mounted on my bars or fork. I usually have a second rear blinky on the left seat stay too.
"Think Outside the Cage"
Bikes: 2013 Haro FL Comp 29er MTB.
Quoted: 1470 Post(s)
Liked 45 Times
It took me a while to realize good lights are like good shoes. Any light might work but a good light works better. I have a niterider Mini Newt 150 I got for 60 bucks about a year ago. It had been replaced by the 200 then the 350 I believe. But it puts out a very bright light that allows me to see the pot holes and trash that seems to find their way into my path the few times I get caught after dark. But the Mini Newt is to see and the super flash on the back is to be seen. I also put a white frog light on my helmet in the front and a red one in the back to be seen as well.
"Florida Man"
Quoted: 1574 Post(s)
Liked 1,708 Times
...For example, I used to have a rechargable light (it was a pretty bright DIY job...), but if I needed to go somewhere while it was charging, I had to reach for another light.
Also I found that my bright light wasn't well focused and that a well designed bike-specific light, even though its output was less, seemed to work better...
In the right lane
I tried the diy, too, and had the same result--bright but unfocused. I got an Ixon IQ, which gives out fewer lumens, but works better due to the focus, and does not blind other cyclists or cars. It's worth the extra cash to get an effective light, if you ride frequently at night.
I have also used Planet Bike lights like Roody uses. My dyno lights seem to output about the same as a PB 2 watt light. The big problem was having to take the lights off when locking up at a rack and when putting the bike out in my cold garage. This eventually lead to me dropping a headlight or two which eventually lead to them no longer working. The dyno lights seem to be more durable, but just because they stay with the bike... hard to steal and not affected by cold.
Except for that, a PB 2 watt with a Superflash rear light, using a good rechargeable battery like Sanyo Eneloops, is a good system.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I am dyno powered. I want lights ON the bike that are going to work the minute I spin up to speed. No looking for batteries, lost lights that fell off, etc, etc.
I primarily use the B&M head lights, tail lights vary. Almost all of my bikes have Planet Bike Superflashes on them for be seen and back up lighting. Most of my dyno lights are the EU code with stand lights. FWIW I buy my PB Superflashes on sale, Amazon used to run BOGO's on them pretty regularly.
I have been riding at night for over 40 years. My very first bike light was a metal Eveready flashlight with a Wald bracket. Things have improved since then. If I were going to buy a rechargeable it would be the Mini-newt.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Sophomoric Member
I recently outfitted my touring bike with a Bush and Muller headlight. Pretty nice, much better than others I have used.
Pedal pusher...
Bikes: I've got a bunch...
Quoted: 5 Post(s)
I'm using a solar headlight. Works out pretty well in Los Angeles we have lots of sun....
May you live long, live strong, and live happy!
I have a fairly bright headlight. It requires 4 AA batteries. I use rechargeables The light has two levels of brightness, but I almost always use the brightest level. I also have a rear blinkie which is bright enough to be noticeable.
In addition to the lights, I have a highway worker vest I wear if I'm riding at night. Or, if I don't use that, I have a reflective triangle which attaches to my backpack.
My methods may seem like overkill, but I want to be safe and visible. Also, the bright headlight helps where I live because we have some rural roads which are not well lit. Even so, I tend to slow down on those roads at night.
Quoted: 10 Post(s)
I used to us a fenix with a twofish mount, worked fine as long as I had remembered to charge/replace the batteries. Finally went with a son dynohub, love it.
In the right lane
If I had to do a whole bunch of night riding, I might even get a rechargeable light with the dyno light. Although I've never actually needed a backup for any of my hub lights... they've been pretty reliable.
I use this headlamp from Princeton Tec. The light was $35 and comes with a head strap, a helmet mount, and a handlebar mount. It works great and means that I can use it in all sorts of situations besides just cycling, like camping, or working in the dark when I need my hands. I also like being able to shine my light in drivers faces to make sure they see me. The flexibility to mount it wherever I want is also nice should I ever want to attach it to my handlebars, I can. It also has three different brightness levels which makes it perfect for reading in a tent, plus a flashing mode. Its been with me through about 13 countries, getting dropped and abused the whole way, and still works like new. Uses 3 rechargeable AAA batteries. https://www.campmor.com/princeton-tec...=%7Bkeyword%7D
Bicycle Commuter
We donated our second car to charity and are now living car light as of Oct 1. I commute 100% by bike now and my wife has the car. For me to get to the point where I could make that commitment to bicycle commuting, I had to get systematic/repeatable/dependable in my processes that relate to bicycling. My wife sometimes thinks I'm crazy, but the system has worked great for me.
Bicycle lighting is one area I adapted and adjusted to and now have a regular system and routine. I run two front lights (one blinking, one steady) and two red rear lights (one blinking, one steady) on every ride, day or night. One of the things that helped my wife accept me riding 6 miles in city traffic each way each day was committing to being very visible to motorists every time, and for me that includes 4 bike lights, lots of retroreflective tape on my bike and helmet, and shirts, jackets, and panniers that are bright yellow or orange with reflective elements when possible.
My two headlights are PDW Cosmic Dreadnaught 1-watt LEDs that use AA batteries. My taillights both use AAA batteries - a PDW Danger Zone on my seatpost set to steady mode, and a PDW Radbot 1000 on my rear rack set to zZzPOP flash. I like all of the lights, but the Radbot 1000 is the best of the bunch and the one I would most highly recommend.
To get truly systematic in dealing with these lights, I switched to rechargeable batteries and chargers and I record when I switch them in my day planner. Through experimentation, I found that with fresh batteries in all of the devices, the first ones to drain were the AAA's in the Radbot after three days commuting. So now I record when I change them, rotate two sets of rechargeable AA and AAAs, and never let them go beyond two days before changing. I keep one battery charger on my desk at work and one on my computer desk at home. This system may sound like OCD or overkill, but it is bulletproof, repeatable, and dependable for me. My 4 lights are full blast on every ride, guaranteed.
Like a previous post, I use and really like Sanyo Eneloop rechargeable batteries. My battery chargers are both LaCrosse BC-700, which I really like. They can charge any mix of AA's and AAA's at changeable charge rates, and you can toggle the display and see what charge, voltage, etc, etc, each individual battery is taking.
This system requires an initial investment in batteries, chargers, and lights. But it is a big part in me finally cutting one car loose, and just the savings in car insurance for a few months from one less car covered can pay for the whole thing.
There are lots of good lights out there, find ones you like at your LBS or online. Like I mentioned, the Radbot 1000 is the best of my bunch. I also recommend the LaCrosse chargers and Eneloop batteries. Hopefully this admittedly long and verbose explanation of my system is helpful for those considering the subject. Here are some links to products I mentioned:
https://www.amazon.com/PDW-LED-Cosmic...=pdw+headlight
https://www.amazon.com/Portland-Desig...bxgy_sg_text_y
https://www.amazon.com/Portland-Desig...ef=pd_sim_sg_1
https://www.amazon.com/La-Crosse-Tech...acrosse+bc-700
https://www.amazon.com/Sanyo-eneloop-...atteries+color
https://www.amazon.com/Sanyo-eneloop-..._bxgy_e_text_y
Be seen by motorists, and ride safe!
Quoted: 10 Post(s)
I'm guessing a SON hub would be pretty delux. What headlight do you use with it?
Quoted: 70 Post(s)
Liked 15 Times
That is the same light I use on my city bike. On that one the dyno hub is a Shimano 2.4 watt with roller brake. It is a DH-2R30 same one that WorkCycles uses on their Bakfiets.
Aaron
Aaron
Mmm hm!
Helmet mounted Cygolite Turbo Xtra which is 740 lumens. It's extremely bright and clearly defines the roadway no matter how dark it is. The flash mode is awesome because cars suddenly know I exist. I'd like to get another powerful light on the handlebars but don't have the funds for it now. Using three Cygolite hotshots, one rear mount to the helmet, one on the seatpost, and the other on the rack.
Bikes: Bianchi San Remo - set up as a utility bike, Peter Mooney Road bike, Peter Mooney commute bike,Dahon Folder,Schwinn Paramount Tandem
My primary lighting system is a dynohub (Schmidt) and LED head/tail light (Supernova E3). I leave them on always. I also have various battery powered lights which I use, mostly when commuting in the dark - Dinotte tail light and blinky lights.
Sophomoric Member
I sometimes see people (mostly Asian Americans) crawling around in the grass with lights on their heads. I was told that they are looking for worms for fishing.
Quoted: 70 Post(s)
Liked 15 Times
Aaron
In the right lane
Seems like dyno lights are pretty popular on LCF. However, when you go to look for them -- even on the Internet -- they aren't that common. Most people are still buying battery lights.
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
The sport/enthusiast roadies don't want the drag of the hub or the weight of the hub and most of the beam patterns aren't the ideal for off-road applications, so the mtb shuns them as well. Quite a few of the recreational riders rarely ride at night or do their best to avoid riding at night, so they don't want the expense. Down on their luck types can't afford them and the ones who are temporarily forced to give up their cars see no point in making that investment.
Broad generalizations I know, but that's the way I see it.
bragi
Bikes: LHT
