BB Conversion: Shimano Octalink to Hollowtech 2
Bikes: Cannondale Carbon Synapse Road, Cannondale T2000 Touring, Vintage Mongoose IBOC Pro MTB, Vintage Peugeot 12spd racer, Old rusty Schwinn Manta Ray I neglected as a child, Diamondback Haanjo EXP Carbon & Metro, Specialized Roubaix Pro, RaleighSC Tandem
Quoted: 225 Post(s)
Liked 39 Times
I want to spec my old 8-spd C-dale tourer similar to a new Deore 3 x 9 bikepacker I recently acquired. I've read I can use 9 spd crankset/rings with the existing 8-speed chain & cassette.
The Cdale currently has Shimano Octalink V1 BB-5500 (68 BCI 1.37 x 24 -- 118.5 L to R). Can someone tell me which Hollowtech 2 size i need to swap in there.
Thanks in advance!
Thanks in advance!
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
7/8/9 speed chainrings are compatible.
Hollowtech 2 for mountain has only 1 size. It only fits British thread 68 or 73mm. Included are three spacers to adjust for shell width and chainline.
Quoted: 2026 Post(s)
Liked 1,096 Times
Octalink is basically a splined cartridge-type bottom bracket that contains the bearings and spindle. Hollowtech II bottom brackets are external bearing only and the spindle is built into the drive side crank arm. Neither of the bottom brackets nor cranks are interchangeable.
michael101, This will be a pretty straightforward BB & crankset swap. You may need to adjust the FD position also.
Brad
Brad
Liked 1,096 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I agree that it is straight forward. I'll add the detail that spacers are used between the cup and the frame to get the position of the crank right for the derailer. You many need to move crank inboard further for a mountain crank on a road bike so you have to use fewer spacers on the drive side than a "normal" installation.
Stuart Black
Stuart Black
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Yes, Hollowtech 2, removes the what length?, option, by fusing it . the crank spindle, now a tube, into the crank arm .
PhoenixBiker
Bicycle Mechanics
24
02-11-22 09:52 PM
snuggiebear
Bicycle Mechanics
17
06-19-17 01:58 AM
