Shimano deerhead derailleur 9sd compatibility
Bikes: Mutiny Bikes Villij frame will full Shadow Conspiracy parts. 95' Specialized Rockhopper. 87 Schwinn Super Sport
Quoted: 10 Post(s)
Hi, im just curious if anyone knows if the shimano deerhead has enough range to shift a 9spd 12-36 cassette?
Quoted: 384 Post(s)
Liked 6 Times
If your hanger is 29mm or more, it still also matters what chainrings you have. The Deerhead was intended for use with a triple chainring, and as such can handle a 22t chainring difference and a 40t total capacity. If your chainring set has a 16t difference, you're at max capacity anyway, so I wouldn't try it then either.
If your hanger is 29mm or longer, and you have a double chainring set that is less than a 16t difference, then you will have a little spare capacity. In that case, you could run the chain a link short, which might give you the cage swing and jockey wheel gap you need to get on the 36t. You'd have to be very careful not to cross-chain big to big, but you shouldn't ever do that anyway, right? Right?
Likes For Ghrumpy:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Not likely. It's probably not an issue of the in-out range, it's mostly the maximum cog capacity. XT Deerhead RDs have a factory max rear cog rating of 34 teeth, which is close enough probably to fudge. But that rating is only when used with the Shimano SFR dropout, which has a hanger length of 29mm, 5mm longer than the "standard" hanger. If your hanger length is less than 29mm, it's risky. Measure that first. If it's much less than 29mm, I wouldn't even try it.
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times
You really need to be more specific about which Shimano MTB rear derailleur your considering using. For instance the Shimano XT, RD-M771 (SGS long cage) is designed for Min/Max Cogs of 11T/34T, a total capacity of 45T, and a max Chainring Difference of 22T. I have this RD on two different touring bikes, shifting an 11-34T 9 speed cog, and the b-screw is not turned in all the way on wither bike; not saying though that it would work for a 36T large cog. Don't see why you can't try it with a Wolf Tooth Tanpan to get to shift a large rear cog like 36T.
Quoted: 384 Post(s)
Liked 6 Times
If RD chain wrap capacity is not sufficient, wouldn't it be safer to go with the optimal chain length and just avoid small-small combo? Cutting the chain too short can cause problems in the big-big combo, like you've said. But running it at optimal length, even while exceeding the RD's chain wrap capacity, can only cause nuisance when (accidentally?) shifting to small-small combo.
Quoted: 384 Post(s)
Liked 6 Times
Mostly harmless ™
Liked 216 Times
The reason to run the chain short is to allow the pulley cage to rotate CCW more for a given chainring, which brings the upper jockey wheel downward, increasing the gap between it and the cogs. This lets you "cheat" the max rear cog rating, but yes, at the expense of making the big-big combo more dangerous.
Quoted: 211 Post(s)
Liked 43 Times
He was specific. There are only two "Deerhead" derailleurs, RD-M700 and RD-M700SP. 1980s stuff. The SP "Superplate" version is pretty rare IME, it has a Duopar- or Mountech-type dual-pivot cage that allows a bit more total gear capacity. Both have a max rear cog of 34. Neither have a B-tension screw, as they predate SIS.
Quoted: 384 Post(s)
Liked 6 Times
Based on this website VeloBase.com - Component: Shimano RD-M700, Deore XT, the original deerhead RD-M700 (not the SP or version 2) can handle a 36 T large cog.
Brad
