OA and brass headbadge
Quoted: 765 Post(s)
Liked 660 Times
If I soak my Raleigh frame in OA solution, is it going to wreck my headbadge, which seems to be made from sheet brass? It's the standard heron headbadge with a really nice patina--frame is a 1976 Gran Sport. If the OA is likely to cause problems, could I protect the badge by giving it a thick coating of grease before the OA treatment?
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Bikes: enough bikes to qualify for Hoarders......
My Raleigh's headbadge ended up thinner and devoid of any paint after an overnight OA soak. I think if I did it again I would carefully drill the rivets and remove it first, then re attach with small screws.
Quoted: 1372 Post(s)
Liked 1,751 Times
Remove the badge! Then soak rather than risk being sorry. And...
For what it is worth, I have access to the rivets used to attach head badges. They are tucked away somewhere. I should look for them and let you guy/gals know what to purchase when you need the correct looking round head rivets. Oh, they are stainless steel but not all shiny and they look just fine.
Large Member
I removed mine buy cutting the portion of the rivets that protruded to the interior of the head tube. As to not take chances of inflicting damage to the badge.
Quoted: 765 Post(s)
Liked 660 Times
I was hoping others had tried the "coat the badge with grease" trick, and could tell me for sure that it works. How could it not? Yes, better safe than sorry and all, but I really dislike removing and remounting head badges. If I do feel brave (or foolish) enough to give it a try, I'll report back on whether it works.
JV
--Ogden Nash
--Ogden Nash
