Tick....Tick.....Tick
Just put a bike together and about 30miles into it, it started to tick.
The bike...Surly Steamroller frame, Sugino Messanger crankset, UN55 bb
If I pedal with my left foot only, I can not make it tick no matter what.
If I pedal with my right foot only it ticks.
Under light pedaling it goes tick......tick......tick
Under medium/heavy pedaling it goes tick-tick......tick-tick.......tick-tick
Under heavy pedaling it goes tick-tick-tick.........tick-tick-tick......tick-tick-tick.
The bike does not need to be in motion to tick. With the bike stopped and me standing at the non-drive side of the bike I can lean over, rest my chest on the saddle, grab the drive side pedal and push on pull on it and make it tick.
Not sure what else to add.
Any ideas?
Thanks
Any ideas?
Thanks
Oh and this is set up as a fixed gear bike.
If I am going forward and wish to slow down and start pushing back it will induce the tick just the same as pushing forward to accelerate.
Quoted: 427 Post(s)
Liked 339 Times
I would start by pulling the cranks off, cleaning the shafts and holes and reassembling according to MFR spec, including torque settings. A bit of grit in there can cause this. I would also remove, clean and reassemble the chain ring using a torque wrench again on every bolt.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I'm not much of a mechanic, but definitely look at the pedals before messing with the crank. I've had "ticks" that were caused by a loose pedal (I couldn't see or feel it was loose until a wrench was on it, then it was clear it wasn't tight enough). Removed the pedal, cleaned the threads, greased it, put it back on as tight as I could - no more tick.
I think I may have over-tightened the crank on the drive side.
Would that cause this?
If so, would parts need to be replaced or just remove and reinstall?
Bikes: A little of everything
Quoted: 7 Post(s)
Try your pedal pulling stress test, except don't touch the seatpost or saddle.
Try your stress test, but don't touch the pedal, manhandle the crank instead.
(Trying to narrow down the ticking by unincluding things that often tick. Keep in mind that the wheels/hubs are still in the equation here).
Did you clean the threads inside your bottom bracket shell and your bottom bracket, and grease or antiseize the threads before assembly? If you didn't, take it apart and do it. You have the tools, it takes 15 or 20 minutes.
Check your chainring bolts.
Is your chain tension super tight? Try loosening it just a tiny bit.
Bikes: Kestrel Talon, Felt Verza Speed 20
Wanted to say thank you to the group. I developed a tick-tick earlier this week and couldn't figure it out. Based on this thread, went out tonight, removed pedals, cleaned them, relubed, reinstalled and... bam... no noise.
I greased and cleaned everything.
I was about 1mm off on my chainline so I tried to push the crank on further to get perfect chainline thinking it wouldent matter as far as the crank-bb are concerned. I am thinking my problem might be there as I likely overtightened it. It is starting to make a "creaking" in addition to a "tick". Thoughts?
Quoted: 7 Post(s)
Dunno, it's pretty hard to overtighten a square taper crank without power tools or doing silly thiings for leverage- installing and removing it a million times or installing it loose and allowing the play between the steel spindle and the loose aluminum crank to chew up the crank are typically what causes damaged cranks. My suggestion is still complete disassembly and reassembly.
Half way there
Quoted: 987 Post(s)
Liked 880 Times
Check to make sure the end of your shoelace is not hitting the crank. Probably not the issue, but it caught me once. It is self-resolving when the chain lops the end off.
My thought is that it is your chain ring bolts because of the sequence of clicks you describe (and the creaking supports it too). Check to see if they are loose. If so tighten them. If not loose, put a drop of oil on each. If the noise changes then you can narrow in on the issue, taking the chain ring off, checking the orientation and seating of the bolts. Did you convert a double crank to a single and use the wrong bolts? If the tick persists after lubing the bolts, it's something else.
Optically Corrected
Good thing it's not carbon ...
Quoted: 1324 Post(s)
Liked 927 Times
Stress test induces the tick with pedals removed.
Check for cracks. Then loosen the chainring bolts, lube the threads and retighten. Make sure those bolts are tight.
Good luck and cheers.
How did you tighten the crank? Did you use an extension on the wrench or socket? If so, you might have cracked the square eye of the crankarm.
Liked 927 Times
Cheers
If the noise comes back this is the first thing I will do.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
See also this thread of mine, I haven't solved my issue yet. I'm starting to worry about a cracked crank.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
I very much doubt you overtightened it. I very much doubt you COULD over tighten it unless you're a big burly man (or a wonderfully voluptuous woman?). (It's hard to tighten the bolt/nut with the crank arms rotating freely. If they're tied down or held by another person, it gets significantly easier.)
