Wheel Advice
Loves Riding!
Bikes: Specialized
Wheel Advice
Okay any recommendations for a wheel set where neither wheel has more than 26 spokes and they are bladed? I have already looked at a few brands but i need something cheap but also that wont break got any idea's?
Bikes: 2007 Trek Madone 5.9 (Shimano DA), 2008 Kuota Khan (SRAM Red), 2009 Giant OCR2 ( Shimano 105 ), Lynsky R340 ( SRAM Rival )
I have several Fulcrum Wheels. Currently I run 1's, 3's and 7's on a few of my cycles.
The Fulcrum 1's are beyond a doubt one of my favorite wheel sets.
https://www.fulcrumwheels.com/jspfulc...e&enduro=false
However I find these to be very inexpensive, though that is very subjective.
Making a kilometer blurry
24h rear and "won't break" are not consistent goals. How much do you weigh, and why do you care about 4 spokes on the rear?
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
24h triplet rear is stronger than a conventional 24h rear, but even that has its limits.
you can get a 27h rear from falcrum, since it's also a triplet pattern.
but there's no way you can get a 26h wheel.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Any particular reason you set the limit at 26? As for cheap, the Forte Titans are very cheap and hold up well for people at least up to 180 lb.
It's like riding a bicycle
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Aksium ?
Agreed, but with the requirement "won't break," I don't think triplet is the answer.
Liked 5 Times
Neuvation M28. $200 a set, 16/20 bladed spokes.
If you're under 180-200 lbs, should be strong enough. Over that, and you'd be pushing it. At 210 +/- a few, my Neuvation M28 rear wheel lasted about 4,000 miles. The rim was fine, the hub was fine, but the spokes and nipples had started failing so I sold it to a lighter rider who rebuilt it.
Neuvation
Quoted: 551 Post(s)
Liked 277 Times
Neuvation, Fuzion wheels if you are on a budget. Never had a problem with Neuvations and two people that I know of have never had problems at over 2k miles.
You can also check Psimet wheels...hand built to your needs.
