Found a frame
Bikes: 2013 Cannondale SuperSix - 1998 CAAD3 R500 - 2012 Demo 8 Carbon
Quoted: 13 Post(s)
Found a frame
Just found this frame in a relatives basement shop-- and it's my size.
Anyone know anything about it?
I would guess it's a re-branded English frame, probably Raleigh built.
Quoted: 13 Post(s)
Quoted: 1627 Post(s)
Liked 630 Times
Depends on which Raleigh you're talking about. They made everything from top-end stuff to just-a-little-above-the bottom. Is there a decal that indicates the tube set used? Closeups of the lugs, seat cluster, dropouts and bottom bracket would the give the vintage frame guys a much better chance of IDing this thing.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I think it's mighty cool looking- if you're talking about for yourself, and the frame fits and it's not too heavy- I'd invest in building it up (or finding a donor bike to steal parts from to build this one).
Not that I know the value of any such collectible pieces, I don't think it's "worth anything" to the point that I wouldn't be afraid of building it up and making it an awesome fun cool ride.
I think it's way cool looking.
Commence to jigglin’ huh?!?!
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I grant that the idea of an English import is not unrealistic, but it doesn't look at all like a Raleigh to my eye. Rear drop out is not Raleigh. And the brake bridge is not drilled for a brake? Interesting! Do you have the fork?
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 3814 Post(s)
Liked 3,345 Times
the soft edged colour changes in the finish suggest a germanic heritage. may be from the low countries. noted the vertically drilled brake bridge. weinmann made calipers for this type of mount. did anyone notice that the fixed cup appears to be one of those rare single doggers?
tend to think it more likely of continental origin.
may turn out to belong in the "show us your Dutch bikes" thread.
waiting for T-Mar to weigh in...surely he will be able to enlighten us all.
Quoted: 790 Post(s)
Liked 1,769 Times
My guess would be rebranded low end reatailer import frame western Eurpopean in origin early 1970's most likely Austrian or Danish. As just a rough frame no fork this one has basically no value. If you could find a somewhat matching fork and headset that would work for a hipster beater build maybe $50-60
Liked 3,345 Times
the forum had a thread a few months back concerning a bicycle with a very English sounding name that was built in Belgium and discovered in...Japan(!):
https://www.bikeforums.net/showthread...1#post16113364
Quoted: 586 Post(s)
Liked 612 Times
Looks like the non drive side crank is still in place. Tell us what brand it is. Might also have a date code. Would like to see pics after it is cleaned up. Looks to be in decent shape.
Quoted: 13 Post(s)
Very cool guys-- I'll go take detailed pictures tomorrow and post them up.
Constant tinkerer
Unless you can figure out what it is, the frame is worthless IMO until you get that seatpost out. And it's REALLY down in there. I'll bet $20 it's stuck. To make a complete dork of myself here's solution to the matrix:
- You don't figure it out, the seatpost is stuck. $0.
- You figure out it's something decent, seatpost is stuck. Maybe $20?
- You figure out it's a cheap low end frame, the seatpost is free. $20.
- You figure out it's something decent, seatpost is free. Best case scenario I don't think you're looking at more than $75, especially missing the fork.
Quoted: 13 Post(s)
There is a lot of caked on mud, but here are some closeups. Not expecting to have struck a high value frame, but I'm really curious about it because it was my grandfathers. So, what do you guys thing?
Quoted: 13 Post(s)
Quoted: 790 Post(s)
Liked 1,769 Times
The detailed pick tell a lot it was definetly a bike 3speed .
and likely older than previous guesses
Bikes: Schwinn Paramount P15, Fisher Montare, Proteus, Rivendell Quickbeam
Quoted: 12 Post(s)
BB oil port, 3 speed pulley, cottered crank as said point to it being older.
Looks like a steel seat post so you may have luck removing it. At this point, I would wash it real good and keep it as a memory of your Grandpa. If you want a project, build it back up and ride it. It will probably take quite a bit of $$$ to do this if you aren't a bike nut and have stuff laying around.
multimodal commuter
Liked 574 Times
The BB oil port is not the normal English design. And the 3 speed pulley is on the left side; which rules out any Sturmey Archer 3 speed hub. If I recall correctly, the Fichtel & Sachs Torpedo hubs also shift from the right side, not left. Shimano made a 3 speed coaster brake hub on which the gear cable attaches on the left; so maybe your bike was made for that?
www.rhmsaddles.com.
www.rhmsaddles.com.
Liked 3,345 Times
Hello EnsitMike,
She appears to have a Los Angeles bicycle license sticker on the upper portion of the seat tube. Does it perchance carry at date?
When you get around to disassembly would be curious to learn if the bottom bracket fittings bear any markings.
Thank you for the additional pictures.
Quoted: 13 Post(s)
Hello EnsitMike,
No problem :]
Liked 3,345 Times
Hello EnsitMike,
thank you for this new information.
the UCSB item combined with the date of 1961 is curious. the school was quite small at that time and had a largely female student body who were on their way to becoming teachers. not many male students. it became more of a fully fledged branch with wide ranging curriculae later in the decade.
was your grandfather perhaps a teacher by profession?
Liked 3,345 Times
wrt the Weco pedals -
the forum had a recent thread about a Dutch bicycle which came fitted with Weco hubs. it is possible that your grandfather's bike may have also had a Weco front hub.
https://www.bikeforums.net/showthread...hing-different
Bikes: 1991 Tomassini Prestige 1973 Raliegh Supercourse, 1975 Panasonic Sport Deluxe, 1983 Fuji S-12, 1975 Motobecane Mirage, 1983 Motobecane Super Mirage 1999 Trek 930 1989 Trek 930 ,
Totally cool. I assume it had 26" wheels, in which case I would turn it into a single speed with some alloy wheels (nothing fancy) and for 15.00 get a single speed rear cog , but before you buy anything , get the seatpost out and open the bottom bracket and headset. I can't tell if that's rust or just road-gnar on the cranks.
Oh and the seatpost hopefully isn't jammed way down in there. Spray some PB Blaster in there and let it sit before attempting to extract it.
mello velo
2
03-28-12 09:04 PM
ransom63
0
08-31-10 09:19 PM
