Deore XT RD - when an upgrade isn't
Bikes: Giant Anyroad
Quoted: 44 Post(s)
Liked 33 Times
I picked up a new 9 speed Deore XT SGS RD at a recent LBS sale for a bargain price. I hoped this would improve over the existing r453 mech when using a 12-36 cassette. The crankset and levers are all Shimano r453 (Sora 3503) triple, with a 26T granny gear. I use one bike for riding SoCal gravel and road riding and swap wheels/tires and cassettes accordingly. The road cassette is the stock 11-32. Swapping wheels with the old mech was a breeze and required no adjustment to the RD or to cable tension. I could have adjusted the B screw in and out, but I typically I left it screwed all the way in. It wasn't perfect but it worked - I would on occasion experience some juddering when in the 36T. I hoped the Deore would solve this problem, unfortunately it has created nothing but problems, most significant is the increased "cross chaining" in the three lowest gears when using the middle chainring and the stock 11-32 cassette. (Its the same issue with the 12-36, but typically I'm in the 26T ring when using the bottom end of that cassette.) I would experience a little extra noise in the lowest gear with the r453 but the Deore is far worse and the noise arrives nearer the middle of the cassette. No amount of cable adjustment or fiddling with the limit screw has improved this. I have replaced the cable and the hanger. I have spent hours on it. The noise comes mostly from the bottom jockey wheel, which runs very close to inside (hub side) of the chain. Of course I could simply drop into the 26T ring to avoid this. Am I misguided in thinking i should be able to use my middle 39T ring across the whole range of the 11-32 cassette?
Other issues I have encountered: there are now no quick swaps between wheels/cassettes. There is no one single B screw setting that works for both cassettes, and with any adjustment to the B screw then the cable tension is thrown off. Also in general the cable tension has proven to be extremely difficult to set and provide good gear shifts at both ends of either cassette. the r453 RD was much more forgiving.
Besides swapping back to the old mech (which is my fail safe) I'd appreciate any insights or suggestions as to what to look for. Thanks
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 215 Post(s)
Liked 153 Times
What is the model of the RD? Is it M772 (shadow), M771 or something else?
I run Sora 3503 shifters with 11-34 cassette and Deore M591 in the rear. Before that I ran RD-5701, it was easier to setup, but M591 also works.
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
What size are your chainrings, and how are you sizing your chain?
And to repeat the above question, which model it the RD?
Bikes: More bikes than riders
Quoted: 1438 Post(s)
Liked 749 Times
It sounds like you've got the newer Shadow style derailleur. I have personally found this design to be more difficult to tune, with the traditional style more forgiving as you describe. Most noticeable with the Shadow design is the higher chain tension, which seems to generate more noise, at least in my case. In addition, shifting wasn't as smooth. I "downgraded" one of my bikes which came with an RD-M3000 (Acera level Shadow) to an RD-M360 (older Acera design) and it's much more pleasant to ride.
Liked 1,092 Times
Have you checked the hanger alignment, even though it has been replaced? Changing the B-screw shouldn't affect the indexing ("tension" is a misnomer) if everything is correctly parallel.
Quoted: 44 Post(s)
Liked 33 Times
its the M772 shadow.
chainrings are 50, 39 26 (stock was 50, 39, 30)
Chain is the original size stock size
re hanger alignment - its a new hanger - I'm not sure how to align it past fitting in place
quick edit: i did take the bike to the LBS who fiddled with it for some time. They did not improve on what I had done - but found no issue with the RD, but vaguely suggested this problem could be a compatibility issue
Advanced Slacker
Liked 2,516 Times
If you are exceeding the RD chain wrap capacity it is still OK to use (if you use the Big/Big+1 chain length method), but the smaller ring/cog combos can get wonky.... just avoid them.
Quoted: 44 Post(s)
Liked 33 Times
i agree that there is some kind of alignment issue, perhaps exacerbated by the longer cage. I would be tempted to say that the cage appears to angle out and away from perpendicular - that is if i sight up everything by eye and try to confirm with a straight edge, then id say that the bottom jockey wheel is not directly below the upper jockey wheel. its hard to judge
Quoted: 44 Post(s)
Liked 33 Times
Thanks, that will be my next course of action. I can see how there could be an issue there, and perhaps this RD is just more sensitive to things being not quite right. Im still perplexed as to why i get the cross chain in 39 ring with either 24, 28 or 32 cogs. When these combos worked fine with the old RD. could the longer cage in itself create this problem.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
This is an outside chance, but on these RD’s it’s easy to thread the chain on the wrong side of the little nub on the pulley cage between the jockeys. Noise galore
Quoted: 1589 Post(s)
Liked 2,486 Times
You didnt mention if it was new. Just wondering if the pulleys were off and maybe reversed when put back on.
Quoted: 184 Post(s)
Liked 67 Times
Bracket axle unit installed in the horizontal position as it should be?
I've seen people incorrectly attach it in a vertical position, they had problems with shifting and chain tension.
Is there a gap between the stoppers on the bracket axle unit and the derailleur hanger?
Likes For cobba:
Advanced Slacker
Liked 2,516 Times
Liked 749 Times
I've tried to make my RD-M3000 derailleur work correctly on a number of bikes, and I just couldn't find satisfaction with it. I've posted a few questions about these derailleurs here in the past. Here is a thread. Here is a second one. Neither is directly the same issue as yours, @Bingod, but I believe the behaviors may be related.
Quoted: 44 Post(s)
Liked 33 Times
The chain tensioning is much higher with the Shadow derailleurs because of the stronger springs (designed to keep chains in place). I've found that this makes "misalignment" of the chain (cross-chainging) a noisier affair. When the chain is more or less inline between front and rear sprockets, it runs fine. But when you start getting outside that "straight and narrow", it's less tolerant of that. And it makes intuitive sense -- the derailleur cage is pulling harder on the chain with Shadow derailleurs compared with traditional designs.
Quoted: 44 Post(s)
Liked 33 Times
I've seen people incorrectly attach it in a vertical position, they had problems with shifting and chain tension....
FWIW I've been having problems with my XT 9 speed as well.
My Jamis Aurora Elite (2010) came with a triple 9 speed setup, Tiagra (4503) up front (50-39-30) and XT in the rear (11-34) with a M771 RD. I bought it used and it needed a new chain and cassette, which I promptly replaced. However, I was still having issues smoothly shifting through the entire range of gears and paid a local shop to align my derailleur hanger, thinking that was the issue. Still no joy. Also had a lot of chain slop in the smaller cassette rings.
I found a like new takeoff of the "upgraded" M772 shadow RD. Installing this alleviated some of the chain slop I was getting in the smaller cassette gears but exacerbated my issues shifting throughout the entire range of the cassette. If i indexed the drive train to behave well on the large cassette rings, it would rub on the small ones and vice versa. Took it to a local shop and they thought my derailleur cage was slightly bent, and they 'fixed' it. Still didn't quite ride right.
Well, I figured, if it was slightly bent it would never be perfect. So I bought a brand new Deore (not XT) M592 RD, which is essentially the same as the M772 but more or less commonly available. Still having the same problems - I can index and shift well great through 2/3 of the cassette but then the last couple gears either start slipping or fail to shift at all. Turning the barrel adjusters just moves the problem to the other end of the cassette. A funny thing happens in the 8th cassette cog where the chain sits up on the edges of the chain instead of slotting into the grooves.
Nothing looks bent, everything adjusted per Park Tool video recommendations, all shift cables and housings and cable guides replaced with new components, shift controls oiled. Can't figure it out other than thinking something on the frame may still be tweaked.
I just ride my bike like it's a 6 speed =/
Liked 749 Times
Do you have any other derailleurs to try? You can get an RD-M360, or any 7/8/9-speed derailleur, pretty inexpensively and swap it to see if you have the same behaviors, or if you can tune it out with a traditional design. The biggest challenge with swapping back and forth between a Shadow and a traditional design is the length of the cable housing and cable. The Shadow has a much more direct (and, thus, shorter) cable routing.
For me and my bikes, I ride triples with front derailleurs, so I'm not so concerned with chain drops the Shadow legitimately helps to avoid. I just have a cheap $10 Lizardskin stay protector to keep everything clean and quiet.
Quoted: 44 Post(s)
Liked 33 Times
Quoted: 44 Post(s)
Liked 33 Times
For me and my bikes, I ride triples with front derailleurs, so I'm not so concerned with chain drops the Shadow legitimately helps to avoid...
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I thought that the problem is that there is a different cable pull lengths between the mountain shifters and road shifters. Even though the shifters are both 9 speed, they are not compatible.
I use the M771 derailleur with my 10 speed 105 shifters on a 10 speed setup.
Liked 749 Times
I'm pretty sure road and mountain are interchangeable on 8- and 9-speed drivetrains. Supporting info:
https://www.bikeradar.com/advice/buy...r-derailleurs/
There are a few exceptions (like Tiagra 4700 and old Dura-Ace), but I don't think those are in play in this situation. That said, that article concludes the Shimano section by saying:
And just for clarity, current generation Shimano road and mountain bike components are not inter-compatible with each other as they use different cable pull ratios. For example, you couldn’t use a set of road shifters with a mountain bike rear derailleur.
Quoted: 44 Post(s)
Liked 33 Times
Good call. I made that mistake when initially threading the chain through the RD, but I corrected it, but only after i had reconnected the chain.
