What size tubeless tape?
Old 11-14-19, 04:06 PM
suncruiser
suncruiser's Avatar
Bikes: 2015 Trek District 8, 2017 Salsa Vaya Claris, 2012 SE Draft
Quoted: 92 Post(s)
Liked 14 Times in 11 Posts
Converting my gravel bike to tubeless, I have the WTB TCS wheels, already have the tires, valves and sealant either ordered or already at home. My question is what size tubeless rim tape should I use on my wheel? Internal width 19, do I just get 19mm tape or do I get larger?
suncruiser is offline
Old 11-14-19, 04:16 PM
well biked
well biked's Avatar
Quoted: 140 Post(s)
Liked 163 Times in 89 Posts
I usually use a tubeless tape that's a couple of mm wider than the stated internal width of the rim. The contours of the rim bed add a little distance across the internal surface of the rim.
well biked is offline
Old 11-14-19, 04:42 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
24/25mm. All of my wheelsets that require tape are 19mm internal, and I use 24/25mm tape in all of them. Is just wide enough to cover the entire rim bed, and start to make the turn toward the bead hooks. Remember, the rim bed of a 19mm ID wide wheel is wider than 19mm, because of the dip in the middle. It's really 22-23mm wide.
WTB sells theirs as 24mm, Stan's as 25mm, though I suspect it's the same stuff. For my next wheel taping I'll be trying Tyvek seaming tape, cut down to 1" wide. Apparently it's the best-- the only drawback being that the narrowest roll is 1.88" (48mm) wide.
DrIsotope is offline
Old 11-14-19, 07:02 PM
suncruiser
suncruiser's Avatar
Quoted: 92 Post(s)
All right cool. What rim strips would you guys recommend?
Old 11-14-19, 07:18 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
I've used like 5 brands, and they're all the same so far as I can tell. I have a fresh roll of WTB sitting on the bench, bought only because the price was oddly low at the time. A lot of MTB guys swear by Gorilla Tape. I just read a lengthy write-up reviewing all of the off-the-shelf and DIY rim tape options, and Tyvek tape was at the top. If you have no desire to tinker and just want to tape a wheelset, I'd say WTB/Stan's. Proven to work.
Old 11-14-19, 07:20 PM
well biked
well biked's Avatar
Quoted: 140 Post(s)
Stan's....pull it TIGHT, as you apply it.
Old 11-14-19, 08:00 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 943 Post(s)
Liked 658 Times in 371 Posts
The two I have used for tubeless applications are Stans and Velocity Velotape. I like the way the Velotape lays down, but for applications over 45 psi, it needs to be doubled up.
Dan Burkhart is offline
Old 11-14-19, 08:09 PM
HerrKaLeun
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 900 Post(s)
Liked 231 Times in 168 Posts
I get it as small as possible to just cover the spoke holes. Like 19mm is the smallest I found.
Reason is i don't want rim tape too close to the bead because a tight tire will be even tighter when it has tape under and won't slide easily to the bead.
the rim tape only needs to have enough surface to stick and cover the holes.
Oh, and thinner tape saves a lot of weight
HerrKaLeun is offline
Likes For HerrKaLeun:
Old 11-14-19, 08:42 PM
suncruiser
suncruiser's Avatar
Quoted: 92 Post(s)
Wouldn't thinner tape save all of a couple of grams? I'm not doubting you really. Just kinda curious.
My bike is currently about 33lbs in itself, tubeless tires should bring it to around 30-31. Not too worried about grams, more interested in less rolling resistance
Old 11-14-19, 09:01 PM
suncruiser
suncruiser's Avatar
Quoted: 92 Post(s)
Just got my tires in... Would it make it easier to mount them if I preshaped them with tubes?
Old 11-14-19, 11:51 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
You're doing this on a tubeless setup, as the OP intends?
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 11-15-19, 08:23 PM
HerrKaLeun
Quoted: 900 Post(s)
i had added some sarcasm with the weight comment.... i have touring tires that weigh over 900g each
yes
Old 11-15-19, 08:38 PM
ThermionicScott
yes
Interesting, I thought the tape needed to go completely under the beads to seal reliably.
RUSA #7498
Old 11-15-19, 09:16 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
My wheelbuilder builds hundreds of sets of wheels per year, and the tubeless tape is always edge-to-edge. I'm gonna keep taping wheels the same way he does.
Old 11-16-19, 10:02 AM
HerrKaLeun
Quoted: 900 Post(s)
teh tape only seals the spoke holes. the rest of the rim is solid aluminum that is already air-tight. if it wasn't for the spoke holes, no tape would be needed.
if you have the tape too close to the tire, it may not fit correctly anymore. At minimum it will be hard to move the tire.
this is different for typical fatbike rims, where there are cutouts. in that case you use a tape as wide as the rim. I believe my 80mm fatbike rims required 78mm tape.
Old 11-19-19, 03:54 PM
Metaluna
Bikes: Niner RLT 9 RDO, Gunnar Sport, Soma Saga, Workswell WCBR-146
Quoted: 114 Post(s)
Liked 19 Times in 19 Posts
Every rim/tire combination is different, but as long as it doesn't interfere with tire mounting, then using edge-to-edge tape allows the bead to press down on the edges of the tape, sealing them off and preventing sealant from working its way under the tape and migrating towards a spoke hole under pressure. Maybe if I were using Gorilla Tape I would be less worried about this since the adhesive is much stronger. Also, if you ever need to unseat the tire, I would be concerned that the bead would scrape across the edge of a narrow tape (especially if you have a double layer), pulling it up. If the tape is edge-to-edge, then the bead is already in contact with the tape, so when it pulls away from the hook it should just slide over the tape with minimal damage. On the other hand, wider tape is easier to mangle with a tire lever so it's tricky either way.
Metaluna is offline
Likes For Metaluna:
Old 11-19-19, 08:25 PM
HerrKaLeun
Quoted: 900 Post(s)
Gorilla tape isn't really sealant rated and also is thicker. That MAY make tire installation worse and the sealant MAY dissolve the adhesive/tape over time. Better to spend a $ more and get tape that is tubeless rated.
you are right with the variety of tire/rim combinations. Unfortunately bicycle tubeless tires and rims aren't as standardized as car systems (but also is much lighter). But still best to use actually tubeless rated equipment (tire, rim, tape)
