Chain for 6 speed Cassette for 1980s road racer
Bikes: Nashbar Race SIS, Spalding Road Step Through Single Speed, Kent Road Single Speed, 630 Cruiser, Fuji Odessa mountain bike
Quoted: 109 Post(s)
Looking around to buy the right chain. I’ve read about different outer widths, even amongst 6, 7, and 8 speed cassettes, though chains for those sizes are grouped together. Not certain if my 1980s Nashbar Race SIS should have 7.8mm outer width chain or 7.4mm. Also don’t want a heavy chain that might be labeled as mountain/road but better suited for a heavier bike. And, when I find a chain with the correct width and acceptable weight, anything else I need to check to ensure it is compatible with my Shimano 600 (perhaps EX) groupset (with front and rear derailleurs)?
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
I run '8 speed' chains. SRAM & KMC
190lb masher.
Keep it clean, lubed.
Shift moderately.
190lb masher.
Shift moderately.
WGB
Bikes: Panasonic PT-4500
Quoted: 1794 Post(s)
Liked 2,328 Times
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Any 7 or 8 speed chain ought to be fine.
Veteran, Pacifist
Liked 4,829 Times
If I have shifting probs with a new chain properly tensioned, the first thing I check is condition of freewheel/cassette.
"Friction makes it all so simple."
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,287 Times
Glad to see that we're beyond the time when people would recommend old, standard-width (~8mm) chain for 6s freewheels.
When Shimano finally introduced their first narrow chain (UG-Narrow, a truly modern chain), a new standard had been set for best shifting on 5-8-speed freewheels and cassettes.
The earlier Sedisport was highly innovative as a bushingless narrow chain, but Shimano took what was learned there and spent years developing a better chain for their newer-style sprockets. Everyone else (among those who remained in business) then copied Shimano's work once the applicable patents had expired or a licensing agreement had been reached.
Sometimes even an 8s chain won't play nice with an older crankset's sprocket spacing, but it's worth it to do a bit of beveling to the smaller ring's teeth (or even bending the teeth a half-mm) to realize the shifting benefits of modern chain.
Quoted: 1946 Post(s)
Liked 2,004 Times
I prefer the Shimano HG-71 just because Shimano and I like to use my chain tool. But if I get caught needing a chain, REI always has a shiny Sram PC 870.
Quoted: 796 Post(s)
Liked 522 Times
+1 on SRAM 8 speed chains
Quoted: 1372 Post(s)
Liked 1,749 Times
Likes For randyjawa:
