Mirror, Mirror on My Bike
Bikes: Iron Man
Ok I got a mirror yesterday but I had no clue how to install it. If I just install it with the mirror up I don't see anything and the arm is not that bendable if I forced it I'm afraid I will brake it, so I figure installing the mirror looking down still have a hard time looking.
Does any of you have one of theses? And if you do what is the best way to install it?
PS: Sorry for the pic is a little to late and dark in the room.
Bikes: Iron Man
Quoted: 2497 Post(s)
Liked 740 Times
H
If it's what I think it is, the arm should be flexible. Most times I've seen them installed pointing up and bent to curve outward. It looks exactly like the two I installed on my daughter's electric bicycle.
Bikes: Iron Man
Ok here is how it looks up, no the bendable arm is suppose to be bendable but I have bend as far as the grip and it goes right up....there is no way I can make view on the right position
Bikes: Sngl Spd's, 70's- 80's vintage, D-tube Folder
This might sound dumb, but bear with me . . . I use a mirror that is a bar end type. You could make the one you have a bar type by cutting of the part that clamps to the bar and poking the long, stick/shaft(??) part through the end of the grip, into the bar. Thats what I would do. Maybe a wrap of colorkeyed electrical tape to keep it in place?
Not hi-tech, but totally workable.
Glad you got a mirror though. The most important safety item you will ever need
Bikes: 96 gary fisher 'utopia' : 99 Softride 'Norwester'(for sale), 1972 Raleigh Twenty. Surly 1x1 converted to 1x8, 96 Turner Burner
Quoted: 9 Post(s)
Get a helmet mirror. You get a better range of vision.
Bikes: Giant FCR, Scott CR1 Team, Fuji Newest 3.0
W A N T E D
Looks like a "Bell" brand mirror. I bought one awhile back, and couldn't find a suitable place to mount it where I could see. Sometimes you just gotta move on and admit defeat. Donate it to some kid, and look for a different style. I have bought several "Sunlite" bar end mirrors (model 93793), and use them on bars similar to the one in your pic. I like them, YMMV. Priced anywhere from $8.00 to $12.00.
on edit: The size of the mirror is the same as the one your asking about now.
xtrajack
Bikes: Kona fire mountain/xtracycle,Univega landrover fs,Nishiki custom sport Ross professional super gran tour Schwinn Mesa (future Xtracycle donor bike)
Papaya King
Bikes: 2009 Felt X City D, 1985 (?) Trek 400, 1995 (?) Specialized Rockhopper, 1995 Trek 850
Helmet mirror. Failing that, get a Mountain Mirrycle.
Not safe for work
I bought that mirror when I first started cycling and couldn't get it set up correctly on my handlebars either. I returned it and bought this one instead
I bought it from REI https://www.rei.com/product/683208/ca...0g-road-mirror and it installs easily into the end of the handlebar (remove whatever plug is in your handlebar and then use a screwdriver to lock the mirror into it).
master of bottom licks
Quoted: 111 Post(s)
A mirror on a long stalk like that is meant to stick up high over the handlebar. That kind of mirror cannot be mounted on the outside of the grips. It is correct for it to be inboard of the grips but oriented so it is above the handlebars. It is angled so it will be slightly to the left of the riders body. It will give the rider a view that is to the left of the bicycle. It is not possible to obtain a view that is directly to the rear.
H
H
Quoted: 111 Post(s)
Liked 740 Times
That's BS. The mirror can be positioned anywhere that suits the rider. If the handlebars that mirror was mounted on was narrower than the rider's torso, then it would be advantageous to mount that mirror at the handlebar end due to the length of it's stalk. Also I call BS on your claim that "It is not possible to obtain a view that is directly to the rear"... it is possible just as long as one doesn't adhere to your standards or limited notions of where a mirror should be mounted.
Do you have your mirror mounted like that? Does anyone in this thread? A mirror like that, as opposed to something like a Mirrycle, at the end of the handlebar is inconvenient at best and unsafe at worst. But I am more open minded than you are. Show me your bike with the mirror mounted like you are defending. I still won't do it on my bike, but at least I'll know the o.p. will have some company dealing with the nuisance.
H
Quoted: 111 Post(s)
H
H
W A N T E D
As I said before, I've tried it. This is my "grocery getter", I had the mirror mounted like this for a little over a month. Decided to try something else, and switched to a bar end mirror. Much better view with the bar end, YMMV.
Old pic.
Old pic.
Bikes: Iron Man
I think I will try this and then lift my handle bar a little more, I think the handle bar is low as well and it's not helping to much...thanks everyone
Bikes: 2014 Trek Crossrip LTD, 2013 Raleigh Misceo
Quoted: 13 Post(s)
If that don't work out, you might look at one like this. I put these on my bike as well as my wife's. We like them. They come in black and chrome. The mfg is Sunlite if you want to shop them.
https://www.ebay.com/itm/BLACK-BIKE-B...item5aec843ebd
I do the Sunlight Mirror thing too. It's nice and solid even in a strong headwind. The bendy ones always seem to vibrate too much for my liking.
cyclepath
Bikes: 2005 Trek Pilot 5.0, 2001 Specialized Sirrus Pro, Kona Lava Dome, Raleigh hardtail converted to commuter, 87 Takara steel road bike, 2008 Trek Soho
Heck with figuring out how to mount those things. Learn to use a head mounted mirror, much more efficient as others have said.
"Without music, life would be a mistake."
-- Friedrich Nietzsche
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
I've tried the same type that you are asking about, and it didn't work very well for me. After experimenting with just about all of the available mirrors, I've settled on this one. I also have a helmet/glasses mirror that is okay but my vision isn't as good 3" from my face, so I prefer the bar mount.
cyclepath
You are correct, a head mounted mirror is located near the eyes but the vision it provides certainly isn't 3 inches away. That's why I said one needs to learn how to use them. For me it worked right away....for others it takes a bit to find the sweet spot. And you can try helmet or glasses mount. The helmet mount doesn't sit quite as close to the face.
It's worth the effort since it does provide such a wide view compared to the limits of a stationary mounted mirror pointed where you have to be steering.
