Ultegra vs. 105
Quoted: 75 Post(s)
Ultegra vs. 105
Just how much real world difference is there in the performance and durability between Ultegra and 105 hubs? From what I'm finding there is about 20g difference between the Ultegra and 105 rear hubs and less than that for the front. Are there any other major advantages for Ultegra or is it a significant jump in price point to shave a few grams and have a blingier (is that a word?) finish and more bragging rights?
Quoted: 4197 Post(s)
Liked 3,849 Times
Depends somewhat with which years" versions you're comparing. But I don't believe there's much actual difference in the bearing elements IN REAL LIFE AFTER REAL USE. Well maintained and lubed bearings will bed in and run smoother after initial use even if the rolling surfaces are not ground and polished when new, they become smoothened with use. BUT the sealing designs do have some differences, some versions have significant improvements in sealing. It is this I would focus on.
20 gm in the center of one's wheels... come on If I wear thinner socks, cut my hair or pee before riding the difference will be more then 20gm. And at the centers of the rotation the inertia difference is almost moot. Andy.
Quoted: 1572 Post(s)
Liked 643 Times
A decade or so ago 105 hubs had a neoprene o-ring wiper seal. Ultegra hubs had a double labyrinth sealing mechanism. I'd guess the Ultegra hub should lave less drag but I doubt anyone could ever sense the difference.
GravelMN, I've had all of Shimano's road group hubs except for Tiagra and for a recreational rider they're all dependable. I used 105 hubs for the majority of my old distance bike's 15K miles without regret.
WRT the hubs themselves it is just a matter of appearance and a slight weight difference between the 105 and Ultegra hubs. I like my groups to be as complete as possible so my hubs matched whatever group (usually Ultegra) I chose.
Brad
Brad
Non omnino gravis
To me, 105 remains at the "sweet spot" for components-- close to half the price of Ultegra for just a tiny bit more weight, and seems to last every bit as long (if not longer.) My wife's bike came with a mix of 5700 105 and 4600 Tiagra, and I slowly switched out all of the Tiagra to 105. It has been absolutely flawless, and see no reason to "upgrade" any further.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
Also +100 DrIsotope. There was a recent thread (probably many of them in the past) discussing the 'sweet spot' in the shimano hierarchy. The overwhelming consensus was either Tiagra or 105, depending on whether an individual leaned towards cheap/reliable or weight-weenie. My understanding is that quality, performance, finish, and weight, all improve until you get to 105; beyond that, weight, finish and performance continue to marginally improve, but durability declines.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Yes.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
Ultegra and DA are less durable than 105, because they are aimed at racing, so they are made lighter/thinner
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
In the used parts market, Ultegra and 105 are often very close in price, so no reason not to use Ultegra if the cost is virtually the same. From a performance perspective, my 65 year old self can see no difference.
With regard to reliability, despite my best efforts I've never managed to wear out anything made by Shimano, so that wouldn't even enter the equation. For me, anyway.
The main difference will be the weight, and even then, in the modern groupsets 5800 and 6800, the weight difference is pretty small between 105 and Ultegra (I think Ultegra to Dura Ace is a bigger step in weight). If you don't care about the weight or "bling factor" you should get 105.
The exception being Dura Ace (and maybe Ultegra) cassettes, where they make some of the lesser used sprockets out of titanium or aluminum to save weight, which is less durable than all-steel cassettes. But Dura Ace and Ultegra Derailleurs, cranks, shifters, etc. certainly are not less durable, probably more durable due to harder, high-end finishes.
Quoted: 3230 Post(s)
Liked 2,079 Times
The OP question was about hubs and as with the overall group, I can't tell a difference.
I've been on Ultegra hub wheels for decades, recently went to CXP33's with 105, they come in black and it's an all black build, and I cannot tell a difference except my wallet is heavier with some money saved - maybe $30 ?.
I think 105 is the sweet spot in the Shimano group for price vs. function/performance.
Quoted: 2026 Post(s)
Liked 1,096 Times
No question 105 is very good stuff and plenty durable but not superior to Ultegra or Dura Ace except in cost.
Quoted: 140 Post(s)
Liked 162 Times
105, Ultegra, Dura Ace, all good stuff through the years.
Threads like this always remind me of one of my favorite "sign-offs" by Sheldon:
Dura Ace is for suckers.
Sheldon "105" Brown
I'm not looking to start an argument about component choices, btw. I just think Sheldon was often pretty clever with his posts.
Sheldon "105" Brown
Liked 1,096 Times
That's in the same category as the Campy owner's comment that; "Record is the pretentious man's Chorus".
Expired Member
Quoted: 3658 Post(s)
Liked 5,403 Times
Not sure if this has been mentioned but there is a significant difference in the way current generation hubs are adjusted. 6800 has the new method where adjustment is by hand w/o needing cone wrenches. 5800 uses the traditional method we all know and love. I prefer the shiny silver or black of the current 5800 to the meh gray of 6800 but the new adjustment method would be hard to pass up.
Bikes: Yes
Liked 3,868 Times
Seriously though, the 5800-series 105 hubs still use a steel axle, while 6800 Ultegra has moved to aluminum which also means smaller bearings. I know a lot of mountain bikers chose SLX over XT for this reason after XT went to aluminum axles. For road riding it's probably not as big a deal. For gravel, maybe somewhere in between.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
Not too long ago I was commenting on UK groupset prices and I made some comment to the effect that Tiagra was "obviously" worth the <$100 price difference relative to Sora. Someone (I think it was @wphamilton) called me on my BS, asking why it would be obvious that anyone should be willing to pay more for a group that didn't add any significant functional changes.
This is clearly a slippery slope. If you start making yourself justify the cost of every upgrade and always buy the cheapest thing that works for your purposes you'll end up riding around on Claris in no time. What will the neighbors say?
My Bikes
My Bikes
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Where does that leave Super Record?
Bikes: Yes
Liked 3,868 Times
It really is a very reasonable position. The rest of us like to buy jewelry for our bikes but don't like to admit that.
My Bikes
My Bikes
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
I wonder when they'll release Claris 2800 with 11-speed?
Hubs not much difference. Over the years sometimes there are more pronounced differences in some series than others, for example, 105-5500 used JIS screws for all the adjustments, Ultegra used proper socket head screws. After a few years, one is perfectly functional, the other has the stripped heads. Newer 105 uses socket head screws for everything, so that difference vanished.
Bikes: Yes
Liked 3,868 Times
The new Sora group stayed at 9-speeds. I guess someone at Shimano realized they could trickle down the technology without increasing the number of cogs. I think it makes sense, but I'm not sure how long they'll be able to maintain that position.
Shimano has historically made products for a customer base that didn't want to admit its own existence. The Tiagra and Sora lines have been directed toward enthusiast cyclists who are interesting in "sport" riding but aren't actually competitive racers (a nice way of saying we don't have the legs to use a 53-39x11-23 drivetrain). The current Sora page on the Shimano website describes them as "sports/fitness cyclists."
For a group like this 9-speed drivetrains and triple cranksets make a lot of sense. Unfortunately, the majority of riders in this segment seem intent on telling themselves that they need the same equipment the racers have. It's a shame because it seems like it would otherwise be possible for component manufacturers to develop new products that better served this segment instead of just trickling down racing technology.
My Bikes
My Bikes
Liked 1,096 Times
