New Canyon Gravel/Trail bike to be released tomorrow...
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Specialized ripped it off from Cannodale, fair and square, so I suspect they will vigorously protect it, like they always do.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I know that's not racey and cool but you can just simply lengthen the chainstays...
I would like to run 45-47s. Where I live we don't really have gravel roads, mainly just dirt roads that are a bit rougher. I mix paved roads with offroad on my rides, and sometimes I would like a bit more plush than what my 37s give me. The "gravel" tyre selection is still the biggest in 38-40mm tho I think.
I would really like an MTB, but the terrain where I live is too boring for it, and I find a nice elevated drop bar much much more comfortable than a straight handlebar even on 1-1,5 hour rides.
By the time you're done making all the tweaks, you end up with a dropbar 29er MTB...rather than road/CX/touring geometry that can take big tires. Not that there's anything wrong with that.
Look at all the engineering that went it Cur've GMX clearing a 60mm tire:
https://www.curvecycling.com.au/prod...-monster-cross
The chainstays (length) and yolk are very similar to my Carver, but they bent the seat tube, made a CF MTB fork...and top-tube routed all the cabling. They were able to make 68mm roadie std BB/cranks work, although for a bike that sees such offroad duties you probably want MTB clutched RDs. And for 60mm tires a 50T high gear is way too high, Heck even a 46T high gear is probably still barely usable.
You have to lengthen the stays anyway--for tire clearance at the BB. If you stick to 700C wheels. Which is why 650B conversions are taking off, lowering the high center of gravity and often finding more tire clearance.
Quoted: 479 Post(s)
Liked 277 Times
I just ordered the Ultegra version of the Grail. I read a lot of reviews - riding the bike - and they were all good. The only negatives I could find were the aesthetics of the Hover Bar and the limited options for adjustment of the bar/stem. Good news - I kinda like the looks of the bar, and if the perfect fit isn't there - back in the box it goes!
I'll dredge up this thread and post up after a few rides.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I'll take a personal day and ride with you guys too. Anywhere in North Georgia is fine by me. Let me know.
-Tim-
-Tim-
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Dislikes: color sux (grey/black only), Canyon USA does not offer the lever of service that Canyon EU does, You get a spec bike with no changes, while EU is much more flexible on the build.
I ordered the bike in two sizes, kept the one I liked and sent the other bike back.
It would have been interesting to order a Grail too and compare them back to back...
Surprises: Amazing attention to design and detail, that wierd kink in the top tube really works, nothing to upgrade on the bike (other than a second set of wheels). Its a conversation starter in a group.
Bonus: Raleigh seems to pack all of their bikes poorly and things get bent. Canyon knows how to pack a bike.
Liked 415 Times
Wider than 45s start causing problems:
A) Frameset clearance
You have to get very creative with chainstay geometry to even get to 45mm. Either a yolk like my Carver, or a droopy stay like the OpenUP
B) Drivetrain compatibility
Due to the wide tires, chainline gets to be a problem (chain clearing the tire and FD cage clearing too). Also for crank arms to clear the wide stay, you need an MTB crankset. There's also gearing problems as 73mm std based cranks aren't geared higher than 42T
And there's also the "is it worth the effort?" question....on my Bigfoot rig, the times I've found 44-45mm tires inadequate, I honestly would have wanted a 4" tire to enjoy the pea gravel. Above 45mm tires, I'd want a fat-tire rigid MTB.
Quoted: 479 Post(s)
Liked 277 Times
@chas58 - that was exactly my thought (and yeah, great reply @Marcus_Ti) - if I need bigger than 42mm, I have another bike for that. On that note, the Grail's not even here and I'm already shopping for another set of wheels - I want to ride the bike on road - the "slow" days - with the club, but do NOT want to do that on 40mm Schwalbe G-ONE Bite.
Love the idea of meeting up for a ride!
Quoted: 479 Post(s)
Liked 277 Times
Dredging thread as promised...
I've only ridden the Grail off-road once, for 56 miles. And, much of that was on less than ideal psi - the tubeless wasn't behaving. But, when it was working... it worked!
While a (gulp) roadie for most of my miles, my background is BMX then MTB. I fully expected a gravel bike on dirt to ride like a slightly more secure/stable road bike. Nope. This thing is so much more confidence-inspiring than I expected. Crossing the rough between the double-track at speed, mud, loose turns, etc., I found myself wanting to go faster - like tucked in an aero position on descents to get more speed! I had a $%&#ing blast on my first non-pavement ride on the Grail.
That "weird", "hideous", "deal breaker" of a bar - the HoverBar (which, admittedly, I like the looks of... I know) works great. I can't say the suspension aspect was terribly noticeable. Maybe that's the point - I rested my hands there, and was comfortable. But, the point where the cross member intersects the drop, creates that little ledge to hook your thumbs when in the drops. It's definitely a bonus. My hands felt more planted than on a standard drop bar... to the point, that I could see mimicking that notch on standard drop bars.
Sadly, all of my other rides so far have been on the road. I bought a second set of wheels (narrower rims; 28mm Contis) for the road - so I'd get more use out of this oh-so-needed latest bike purchase. On the road, the bike is great - just what you'd expect from a sub-19lb carbon frameset, Ultegra build. I've gotten in the habit of riding the Grail on "slow days", where the comparatively (to my Scott Foil) increased weight and relaxed geometry and longer wheelbase/chainstays don't make themselves apparent. It's close enough to a competent road bike (with that second set of wheels/tires) that, if had only one bike, the Grail would be it.
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 415 Times
Thanks! Like the picture, and the writeup.
I was bummed my bike (Inflite) was so dark and monochrome black, so I brightened it up a bit. Here it is with 28/32mm road guise below
(today it is wearing 40mm gravel tires for my next ride).
Sounds like you have the endurance version, I have what basically feels like a crit bike that takes fat tires - super fast and agile with road tires.
Liked 415 Times
The red and some of the blue is high vis reflective tape (3M). the 1/4" and 1/8" is pinstriping tape. The blue 1" is electrical tape.
Liked 415 Times
Interestingly I did a test on some harsh washboard yesterday with some 32mm tires on my Inflite
At 15-16mph the canyon carbon seat post just soaked up the harshest washboard. I didn't realize how hard I was punishing it until I put my weight forward gripped the handlebars - the front of the bike was getting the cr*p violently beat out of it. I quickly put my weight back on my saddle with a light touch on the bars.
I don't know how much was the bike and how much was the seat post, but dang, the back of this setup soaks up bumps. I do think that at speeds closer to 20mph+ that the bike would just violently skip across the tops of the crest of the washboard, but I haven't had a need to use the thudbuster since getting this bike/seatpost combination.
Quoted: 479 Post(s)
Liked 277 Times
I went with road pedals because the race (those 56 miles) included nothing technical - zero unclipping, running/walking, etc.
I'm new to the gravel scene, so I did check out what other guys were using. I was in the 3rd row at the start... with all the Cat-1s and 2s (lots of shaved legs and 5% body fat) and - while waiting for the start - did a bit of a survey of pedals. It seemed like at least 20% of the guys were using road pedals and shoes.
For anything technical, I'll definitely swap the road for mtb pedals.
Quoted: 1975 Post(s)
Liked 232 Times
Liked 415 Times
You'll love this review then
Review: Canyon Grail CF SL 8.0 SL | road.cc
It's a product of great engineering, not just the frameset but the Canyon components too. It's been designed as a complete package – you can call them gimmicks if you like, but wow, they all add up to an awesome ride.
The Grail is fast, smooth, comfortable, light and has great handling, but above all else it's masses and masses of fun.
This article does a great job of articulating the riding experience of our bikes (given that the Grail is endurance oriented and the Inflite is race oriented).
I have to say, most gravel bikes that I have ridden are rather boring. But the inflite at least (and apparently the Grail too) put a huge smile on my face and make me want to go ride more. I've ridden no other bike that is that smooth and yet accelerates so fast.
Quoted: 479 Post(s)
Liked 277 Times
Damn. That's about as positive of a review as I've read about any bike. Seems like the author works for Canyon ;-) It does line up with all the other reviews I've read, e.g. the "I think it looks ridiculous" comments from the guys who've only seen pictures and the "Loved the ride" reviews from those who've ridden it.
Thanks for posting that!
- Soli Deo Gloria -
Liked 736 Times
The world will never be without those who have never tried something telling those who have how things are and ought to be.
-Tim-
-Tim-
