Why are DT Swiss hubs so heavy?
Quoted: 24 Post(s)
I see that they're very expensive but also they're really heavy. I mean it contradicts Bontrager's Law and those are very good hubs. What's the thing with them?
Quoted: 4717 Post(s)
Liked 1,882 Times
White Industries hubs are even heavier.
Hubs aren’t a great place to try and save weight(or money)
BHS(Bitex) and Novatec hubs are lightweight and cheap, but they will never be as durable as DT or WI hubs.
Quoted: 28 Post(s)
This. I hated having to replace perfectly good Shimano wheels my bike came with because the races couldn't be replaced and it didn't make sense to buy new hubs. I want hubs to be bulletproof and 100% serviceable.
Quoted: 1332 Post(s)
Liked 398 Times
Heavy is good. Heavy is reliable. If it doesn't work, you can always hit him with it.
Did that actually happen or you just forget normal maintenance? I have "$20" Shimano hubs is service on my commuter for 10 years and they are perfectly fine. On the other hand my Fulcrum wheels from January this year, with cartridge bearings, are already slightly notchy. Sure I can replace them down the line, but I rather have a wheel that doesn't need the bearings replaced in the first place?
bike whisperer
Quoted: 1527 Post(s)
Liked 718 Times
Cups in loose-ball hubs should last basically forever if the preload is anywhere near correct.
Bikes: 2011 Cannondale CAAD10-4
Quoted: 12 Post(s)
More practical for a revolver; with a hub you'd at least have to take the time to remove the wheel from the bike, if not the hub from the wheel! Unless you just happen to have extra hubs laying around, in which case... why can't I have that problem?
They're genuinely reasonably light. There are lighter hubs out there, and many of them are just fine, but DTs have reasonable sized bearings, pretty large axles, and a very good reliability record. They are generally easy to service. They exist for nearly every standard and convert easily with end caps and different freehub bodies. For better or worse they're a well regarded brand name.
Quoted: 4802 Post(s)
Liked 3,923 Times
Replacing hubs is a lot of work plus there is often the cost of new spokes. I want hubs that simply work or at least all parts are serviceable or replaceable is a real plus if only to save the need to rebuild the wheel. Swapping rims is quick and easy. Swapping hubs is a complete rebuild, no easier than a wheel from scratch.
Ben
Ben
Quoted: 12 Post(s)
Ha! I had to seek to the ends of the earth to find a shop that had spare RS-10 spokes from c. 2011 to fix my wheel when I broke one last summer... there is no way that my wife would let me buy spare hubs!
But it sounds like you might have some extras laying around...
