Marin Team frame with unknown BB
glorified 5954
parts mixed by past owner .. its a loose ball BB square taper axle type..
You show the Adjustable cup + a lock ring.. Only show the drive side, ... from a distance ..
Bike shops will have the tools to remove it,* then you can put something of your choosing
in to replace it..
*so you don't have to buy them to use once..
in to replace it..
Quoted: 18320 Post(s)
Liked 4,489 Times
Hopefully everything isn't stuck.
A good "hook wrench" should take off the lock nut, and perhaps the fixed cup (once the adjustable cup is loose).
If the threads are loose, then any pin wrench should work, or if it is loose, perhaps simply using a punch to insert into one hole and turning (hopefully no pounding).
Park makes a couple of pin spanners to snag two holes at a time.
glorified 5954
Thanks for the tips guys. I picked up Park Tools SPA-1 and 2 yesterday and will work on the Bike again soon. Will try to post more pics of the BB.
You guys think this frame is worth saving? I am pretty sure that it is a Tange Ultimate Ultralight or similar. The wall thickness is ridiculously thin. I was thinking of having the bottle holder eyelets fixed by a frame builder that I know and then having the frame brushed again and chromed. Don't know though.
Steel is real
I've got a tool like this that would undo the lock ring on the left side
it might undo the drive side cup [looks the same] depending on how tight it is
{not forgetting it's left hand threaded]
Steel is real
in to replace it..
in to replace it..
yep.. i had to put a magnifying glass at the pic, looks like there's a lockring on the drive side too, once removed it needs a 6 notch BB tool
nope, there are definitely two notches i can see
OP, you really need to post a close up shot of that
Old fart
Quoted: 3571 Post(s)
Liked 3,368 Times
The lockrings look to be aluminum, so be careful if you use a single-tooth hook spanner on them. I'd prefer a lockring pliers for a more secure hold:
glorified 5954
Insane Bicycle Mechanic
Quoted: 788 Post(s)
Liked 688 Times
That looks like an aftermarket bottom bracket, possibly a Royce or Tune. High-quality upgrade part from the mid-'90's.
I bet you're going to need a tool that engages all six holes so you can apply some torque and break loose any corrosion. With luck whoever installed it used anti-seize.
Something like this Tune tool:
https://www.bike-discount.de/en/buy/...2-6-pins-31453
Jeff Wills
Jeff Wills
glorified 5954
No shop in the city of Zurich able to remove it? asked? (thus avoiding buying a tool used just once?)
glorified 5954
Yeah, I appreciate the tip, Bob, but I like to do things myself. And like I said, I like tools! Been looking at replacement BB's for this one as it is slightly damaged (check out the drive side where the square taper comes through the hole). So I may just end up getting another Tune BB or something similar. I really want to try a HQ cup and cone ST BB.
