Go Back  Bike Forums > Bike Forums > Utility Cycling
Beefier Innertubes?
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Beefier Innertubes?
Old 09-07-19, 02:11 PM
Hikaru1337
Question Beefier Innertubes?
So I have a Kona Ute I got sometime around 2011, and last year I installed a BionX motor on it. While I love what this bike can do, my rear innertube doesn't seem so happy with the arrangement. My rear innertube has failed twice in the last month, and once only a few months prior. As far as I can tell, going up and down curbs seems to be what ultimately caused the failure the last couple times. Does anyone know if there's a particularly robust kind of innertube I could throw on the back wheel that would hold up to the heavier stresses I'm putting on the back wheel? Or is there some trick to managing tire pressure for heavier bikes that I'm unaware of? The bike itself is 55lbs and I try to keep the pressure between 50 and 60 PSI, and the max pressure listed on the tire is 75PSI. I've checked the inside of the tire, and the inside of the wheel itself where the innertube rests, and couldn't find anything that could cause an issue with the innertube.
Any advice is appreciated! Thanks.
Hikaru1337 is offline
Old 09-08-19, 11:21 AM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times in 795 Posts
Where is the failure on your tubes happening?
Maybe go to thick thorn resistant tubes if you haven't already?
https://bicyclewarehouse.com/collect...-various-sizes
https://bicyclewarehouse.com/collect...sta-valve-tube
FiftySix is offline
Old 09-08-19, 09:58 PM
Hikaru1337
The last three times the hole has been in different places actually. The most recent break was on the inner portion of the innertube that rests against the wheel. the last couple before that were on the portion that's up against the inner side of the tire.
I'll have to check out those thicker walled innertubes you linked and see how they hold up.
Old 09-09-19, 10:28 AM
FiftySix
I'm the anecdote.
There were no holes through the tire on the last couple flats?
FiftySix is offline
Old 09-09-19, 11:21 AM
Hikaru1337
Nope! My tires were getting old, so even though I couldn't find anything wrong with them aside from worn tread, I replaced them after the second of the 3 recent flats, but the same kind of riding still got me another flat.
Old 09-09-19, 11:29 AM
FiftySix
I'm the anecdote.
I really don't have experience with utility bikes with electric motors. I do hope the thicker tubes work for you, Hikaru!
FiftySix is offline
Old 09-09-19, 08:20 PM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 190 Post(s)
Liked 41 Times in 32 Posts
I don't see the term in here, but commonly called a pinch flat. One solution, don't go up and down curbs.
That can happen with any tire/tube/rider if you hit a sharp edge wrong, it's not just you.
Oftentimes, you'll get two little cuts in the tube, not one.
I don't know that thicker tubes will solve that, either.
StephenH is offline
Old 09-10-19, 07:41 AM
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times in 974 Posts
Sounds like a pinch flat to me. My suggestions are:
-If you want same comfort and add durability, go up a tire size. More volume but at a similar pressure in the bigger tire you likely won't pinch flat as much. Otherwise, you'll just have to add pressure to avoid the pinch flats.
-Comort, speed, and durability.......that bike's specs online say it is a 700c. They DO sell latex tubes for cyclocross bikes that are 700c. I think they should work in a tire from 32 to 40ish in size. Latex is slightly less prone to pinch flats. If worried about thorns, just buy a type with the removable valve core and pour in some sealant to the tube. It's a utility bike, not a racer, but latex can still provide added comfort and durability despite its fragile reputation.
burnthesheep is offline
Old 09-15-19, 01:48 AM
MikeyMK
Cycleway town
MikeyMK's Avatar
Bikes: 2.6kw GT LTS e-tandem, 250w Voodoo, 250w solar recumbent trike, 3-speed shopper, Merlin ol/skl mtb, 80cc Ellswick
Quoted: 569 Post(s)
Liked 169 Times in 117 Posts
I got inner tubes 3-4 times the weight of bicycle ones for my tandem. They're thicker than the tyre, could almost use them without tyres...
I'd looked up moped tubes and I think they're for the front wheel of a Honda C90 or alike.
That's bearing in mind my rims are 50-559 and tyres are 60-559.
MikeyMK is offline
sjanzeir
Bicycle Mechanics
44
03-31-17 07:57 PM
GNS1310
Bicycle Mechanics
4
08-21-13 01:53 PM
Planemaker
Fifty Plus (50+)
3
06-02-13 09:13 PM
dannymctrance
Bicycle Mechanics
7
05-28-13 10:23 AM
budopo
Road Cycling
7
06-10-12 08:29 PM
