Panasonic 1000 vs Schwinn Continental
New to cycling looking for some advice. Both the bikes listed above are for sale locally for around $75. Just not sure which would make a better starter bike. Any help is appreciated, thanks in advance.
Quoted: 634 Post(s)
Liked 444 Times
Edit: here's a basic guide to bike fit. https://www.rei.com/learn/expert-advice/bike-fit.html
Likes For tricky:
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
Not knowing your leg length I would bet that frame will be too small. I really doubt that at 6 feet you would stand over a 21 inch frame and only have an inch between you and the top tube. A lot of the modern charts for sizing seem to be for modern sloped top tube bikes. I am 6"2 and ride a 25 inch frame (63cm). Assuming you don't have unusually long or short legs I'd bet you are at least a 23 and possibly a 24 frame. The only way to check for sure is a test ride or a professional measuring. Personally I'd jump straight to looking for a larger frame size than a 21...
Pansonic 1000 vs Schwin continental
Bikes: Yes
Quoted: 301 Post(s)
Liked 15 Times
I’d say that the 1000 is a better bike in many ways. Lighter and probably faster with more modern components (though still old). The Continental is easier to work on with basic tools. But, condition is probably a big factor to consider.
Likes For Chrome Molly:
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
The Schwinn is a tank, the Panasonic is a bike.
Much depends on condition, how you will use it, and your expectations for it.
And, probably most importantly, size.
Likes For 67tony:
Quoted: 209 Post(s)
Liked 175 Times
I'm 5' 11", with a 32" leg length...measured barefoot, from the floor to the top of the crotch.
My sweet spot frame is 22.5". I agree that a 21" frame for a 6 footer is a hair too small - unless you are all torso with short legs.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,392 Times
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
Duplicate threads merged.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
I'm 5'8" with a 30" inseam and ride a 21.
Commence to jigglin’ huh?!?!
Quoted: 964 Post(s)
Liked 1,451 Times
Then that 25" Panasonic 1000 is the bike for you! As others say, the Schwinn is cool, and a tribute to midcentury American industry, but heavy and old-fashioned and the brakes won't work as well - nice to look at and talk about, but a bit of a pain to ride. The Panasonic is lighter and the rims will likely be aluminum which means the brakes will work better and everything in general on that bike is a bit more modern.
Quoted: 796 Post(s)
Liked 522 Times
+1 on 25" frame and doing a test ride, its all about fit first -pictures OP?
Quoted: 57 Post(s)
Liked 41 Times
I am within an inch or two of your height. Slightly more legs than arms. I ride a 21" road frame happily, and have since 1978 at 13 year old growth spurt. And I am now 55. Second the bike fitting you mattering most. That said, I am a Panasonic fanatic as I am also about Bridgestone and Miyata, the best production Japanese frames in this era.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times
The stand over height of a 25 inch frame should be close to 33.5-34 inches, depending on the tire size. That would be much closer to your size and could be fine tuned with adjustment to seat and handle bar height and reach.
